Michelin City Grip - 5,000km review
Post Reply    Forum -> Reviews Previous12
Wed Nov 09, 2011 6:57 pm quote
glasseye wrote:
No City Grip in 140/70 12.....
Deal killer for me.
R
yeah, whats up with that.
Lx 50 4T, GTS 250, S 150 (Missing in KS), Something Chinese, GT 200 (sold)
Tue Mar 13, 2012 9:30 am quote
Warning: Ressurecting somewhat old review thread!
My veredict: The CG lasted 7K. Now for my question. I didn't want to start my own thread because I am sure someone knowledgeable will pitch in and answer my question right away.
I have noticed that Michelin is now using the word reinforced on the CG and their advertising. Is this a new thing? Have they always been reinforced? And if not are the reinforced ones supposed to last longer? (Okay that was three questions
looking again
Tue Mar 13, 2012 10:40 am quote
aren't they using two kinda of rubber now?...hard for the centre and soft[er] for the side walls?
Wed Mar 14, 2012 8:22 pm quote
that is a different tire from michelin called the "power pure" . It is a dual compound tire.
The city grips do have some that are more reinforced than others. if you look at the michelin web site they have a fitment chart and they explain all the codes for the tires. speed ratings, weight ratings.
GTS 250
Sat Oct 20, 2012 10:22 am quote
city grips
Have 7000miles on mine and show only slight wear in the rear and barely any up front. But there is that "wobble" about 30 mph!
LX 150 year 2010(carb)
Tue Jun 25, 2013 11:53 pm quote
Just back from a 1186km trip on my newly installed michelin city grip front and rear. One word: awesome! Bought it from a shop in Singapore for USD104 for both front and rear, cash and carry.
Highly recommended! I did hundreds of curves during the trip to 3 highlands, City Grip never fails me even once!
1200km Tri-Highlands Ride in 3D2N
Get it !
2015 Vespa GTS 300
Sat Jul 06, 2013 3:35 pm quote
I have the City Grips on my 2007 GTS 250ie and I love them.
The front tire has over 8,000 miles on it so far and it doesn't look like it will need replacing for quite awhile yet. (I'm new to this forum and will try to post a picture later.)
The rear tire "had" only 3,100 miles on it when it got punctured by some road debris. But it was still looking and riding great at that point. I replaced it with another City Grip.
Previously, I had a Pilot City on the rear for about 8,400 miles.
Interesting note, When it came time to replace the Pilot City, I had wondered how much better ride the Michelins actually were that the original Savas. I though maybe it was just in my "head". But when I took my scooter in to get my (1st) City Grip for the rear I had a surprise. I had ordered the City Grip, but the shop didn't notice the note on the work order. Instead they mounted something else out of stock. I didn't bother to "check" the tire before I left, but I didn't enven get out of the parking lot! The scooter felt very squirrelly, like the tire pressure was very low. I got off to check and found they had not installed the City Grip I ordered. So now I was convinced of how good the City Grips are, at least compared to some others.
In the end dealer was very good about it though. I went right back to the service desk, they saw the note was on the service order and immediately took it back and put the CG I ordered on for me.
2015 Vespa GTS 300
Fri Jul 12, 2013 2:18 pm quote
Sorry everyone, I won't post a picture after all... All I can say is that after 8,000 miles on the front City Grip they "look" like they have quite a few miles left on them. But they do show noticeably less tread than the new City Grip on the rear.
Regarding the front "wobble", is this something people have experienced only with certain tires and at certain speeds? What I have noticed is that if I take my hands off the handle bars at "any" speed, and with "any" of the tires I've had the front wheel will begin a very serious wobble. I was very surprised by this the first time it happened. Prior to my Vespa I had only ridden traditional motorcycles and never had a wobble like that. I just chalked it up to the non-symetrical front shock. Maybe I'm all wet!
Piaggio Lt150
Mon May 19, 2014 3:31 pm quote
MarkTheBlue wrote:
Very encouraging. I put City Grips on mine (front and rear) when I got it a couple of months ago. Not done a lot of miles since but good to know what I can expect from them.
And I know it SHOULDN'T matter but they do look good on there...
Thanks Jim!
Mark
Hi! I just had my City Grips installed and noticed the front tire looks "backwards" as compared to the rear. The arrows are oriented facing forward but the tread pattern seems wrong. Any advice? BTW, the rear is CG also.
Thanks for any info.
Wed May 21, 2014 6:46 pm quote
Thanks Jim!
Mark
the arrows are correct.
Piaggio Lt150
Wed May 21, 2014 7:05 pm quote
old as dirt wrote:
Thanks Jim!
Mark
Sun Jun 15, 2014 10:41 am quote
Thanks Jim!
Mark
The backwards mounting of the front tire is probably just a trick to improve front braking. My circle of friends swear by it, but honestly I see no difference.
bv350 (sold) and now,'14 honda ctx700 dct
Mon Aug 25, 2014 6:59 am quote
howdy, I guess resurrecting an old post but I am speaking to the info asked for. I have the bv350 and have the head shake mentioned with the front city grip tires. there is noticeable cupping but the tire has over 13,000 miles and still good tread. one thing I would mention is that when I bought the scooter I ordered the tail trunk but it didn't arrive till I had a thousand miles or so on the scooter. there was absolutely no shake in the front until I took it in and had the tail trunk installed. that is when the shake began. I thought the mechanic had bent the front wheel because I saw the scooter up on the lift with no tie down other than the front tire clamp which is only as high as the tire itself and I felt that reefing on the bolts while installing the tail trunk may have torqued the scooter to one side and bent the wheel. now i'm thinking that the new shaking in the front was a result of the shift in weight and balance from installing the trunk. could that be? do all of us with the shake have a tail trunk installed?
lotsa miles and smiles to ya
ken
Used to have P150, GS180, P200 now GTS300
Sun Aug 14, 2016 6:49 pm quote
Tire life on city grip on GTS300
Got 8350 miles on rear, had some cupping, but smoothed out at 38psi..Still 50% left on front. nice handling with CGs..
GTS 150 3V ie
Mon Jun 12, 2017 5:51 pm quote
The city grip looks a lot better than my power pure after 10,000 km. Note the scalloping on the left side of the tire due to increased wear from Thailands crowned roads.
I did 23,000 km before puncturing the MOE Pirelli without noticing any unusual wear.
The photo was taken after the tire was removed. The squared off V profile and wear is much more noticeable when the tire is mounted.
Cannot recommend Michelin Power Pures.
2009 GTS 250ie
Mon Sep 24, 2018 2:48 pm quote
I just had a set of Michelin City Grips put on my 2009 GTS 250ie. I bought this scooter used about 4 months ago and figured I'd have to be changing out the original Sava tires. They passed the "thumbnail scrape" test, so I ran them for 3,000 miles, until the rear developed a bulge.
What a difference these City Grips make in handling: the GTS now feels sportier! The Sava tires seemed a big square(ish), the City Grips definitely have a rounder profile. I hope I get the kind of mileage that some are reporting in this thead.
2015 GTS 300 Super (Melody)
Fri Nov 16, 2018 9:20 pm quote
Checking in here with roughly 7100mi on the CityGrips that came on the bike new, and the rear tire is just starting to look like I should replace it before terribly long, but not exactly dog-eared. Toyed around for a hot five minutes with replacing them with Power Pures , but between my experience with CGs and doing a search on MV as a head-check, have decided to stick with the Grips.
Tue Dec 18, 2018 8:38 am quote
On my GTS, I was able to get 15K miles out of the CG front, about 8K miles on the rear. I'm not riding super aggressively, but I do get after it quite a bit.
I would say my riding is mixed with suburban commuting (aka Stoplight TT) and blasting down winding rural roads for fun.
Huge fan of the Michelin CG for grip and wear.
[ Time: 0.1541s ][ Queries: 25 (0.0402s) ][ Debug on ]
