LX 125ie Cylinder Kit
Sun Jul 06, 2014 3:31 pm quote
I own a Vespa LX 125ie, and I would want to know if it possible to install the original Piaggio 150cc cylinder kit, if it is plug&play.
Sorry for my poor level of english.
Thanks in advance!.
Sun Jul 06, 2014 10:47 pm quote
Sorry not the answer you want was wondering the same think also will it make much difference to performance
LX190
Tue Jul 08, 2014 12:09 am quote
25cc isn't much of a bump, if its a 2valve go with the malossi 190cc kit.
'04 ET4 190 +hotcam, Scorp Exhaust, Stereo. SPEED HOLES!
Mon Jul 14, 2014 11:12 am quote
yeah the 190 kit is essentially a bolt-on for that bike. Do your research and watch:
It helps a ton.
Tue Jul 15, 2014 12:49 am quote
As above - install the Malossi 190 kit. Top it off with some Dr Pulley sliders and you're golden.
Sponsor
Granturismo 218
Wed Jul 30, 2014 9:02 am quote
The 150cc top end should be plug and play, and if you get the Malossi, make sure you get the kit for the IE bike, otherwise the bike won't run right.
Primavera 125 3v 2014
Sun Aug 24, 2014 12:21 am quote
can this modification works on primavera 125 3v to 150 3v?
Fri Sep 14, 2018 6:57 am quote
Hello again, could anybody tell me all the parts I need to buy for tbe 125 to 150cc conversion?.
My Vespa is the 125 ie 2 valve engine.
Thanks!!!.
Et4
Wed Sep 19, 2018 11:49 am quote
Hi, I have a complete 150 barrel, piston and cylinder head which I removed to install the 190, itís off a low mileage motor if your interested
Vespa LX 125
Tue Jun 25, 2019 2:32 am quote
Hi
Do you still have it?
Vespa T5 Mk.1, GTS218ie
Tue Jun 25, 2019 4:50 am quote
Why not do it properly and use:
https://www.scooter-center.com/en/1844113/cylinder-piaggio-200-cc-piaggio-ac-leader
(I like to play with this one as it has slightly lower compression, but may run well with the injection set up as standard)
or
https://www.scooter-center.com/en/p1400215ie/cylinder-polini-198-cc-piaggio-ac-leader-ie-euro-3-injection-engine-incl.-polini-ecu-vespa-lx-125/150ie-euro-3-lxv-125ie-euro-3
(you can buy it without the ECU override)
as an alternative to the Malossi
https://www.scooter-center.com/en/m3111393/cylinder-malossi-190-cc-piaggio-ac-leader-carburetor-engine-vespa-et4-125/150-4t-lx-125/150-4t-s-125-4t-euro-3-m444m-s-150-4t-euro-3-piaggio-fly-125-4t-euro-2-3-m422m-fly-150-4t-euro-2-3-m422m-liberty-125-4t-euro-3-m389m-liberty
The 2 valve head is restrictive, you could just use the 125cc as is, put a less restrictive air filter in (mod the air box for flow), put an iridium spark plug in and as the o2 sensor is the 4 wire unit, use a fatduc unit to get it running a little better.
Vespa LX 125
Tue Jun 25, 2019 11:55 pm quote
or
Much cheaper! But wouldnít you need the ECU to adjust the fuel?
2005 et4
Fri Jun 28, 2019 6:55 pm quote
The Malossi 190 kit has been the gold standard for upgrades to the 125/150 and has years of successful use. It's what I purchased for my LX150
[ Time: 0.2418s ][ Queries: 23 (0.0602s) ][ Debug on ]
