ENGINE REPAIR HELP. Vespa ET2 2003
Vespa et2
Tue Jul 28, 2015 10:40 am quote
My engine made a POP sound driving down the road... And now i have very low compresion and bareley turns over. I can SEE the leak.. the Intake manifold sputers out oil n gas when i start it up. How would i fix this? a new gasket or intake manifold? pictures are attached to show leak
2016 Honda NC750XD, 2007 GTS (sold),
Tue Jul 28, 2015 10:42 am quote
You need to open that engine up and see what the piston and cylinder look like.
Vespa ET2. Engine blown? Help
Vespa et2
Tue Jul 28, 2015 10:51 am quote
Yea.. i will do that tonight.. hopefully the piston is ok... what tools will i need?.. beside ...obvious wrench/bolt.
Tue Jul 28, 2015 10:55 am quote
Good, the service manuals are here-
http://www.wotmeworry.org.uk/manuals/ET2/
They'll will tell you what's involved
Sponsor
Granturismo 218
Tue Jul 28, 2015 12:41 pm quote
If you have low compression, the piston and rings are not okay. Fortunately, the parts are pretty cheap. There is no gasket for the intake and a It's a fairly straightforward top end to take off. There are four studs after you get the shroud off. It's easier if you drop the motor, but can be done with the motor in if you remove the cover in front of the engine.
Check the play in the connecting rod before you throw a new top end on.
More than likely, you are looking at a top end, as well as a new manifold. Might as well go for a big bore kit, it's not a lot more than replacing the stock top end with stock parts.
et 2 50cc
Tue Jul 28, 2015 1:22 pm quote
I think, you'd better to give it to a (good) mechanic. This is not a very hard job, but without experiences it is too complicated for you.
Vespa et2
Tue Jul 28, 2015 2:14 pm quote
I will put on a new Intake manifold.. thats all thats needed... (almost certain. ) if that dosent work ..i will talk to a mechanic. i dont thinkanything is wrong with piston .. but i will find out tmrw when i open her up. wish me luck and thank you for advice
Tue Jul 28, 2015 3:37 pm quote
If you do need a new piston and cylinder, it's a good time to get a 70cc kit for it.....
Tue Jul 28, 2015 4:05 pm quote
Having been told that the original link to a file-sharing site for the huge workshop manual (~750MB) had failed, I've uploaded it again to a Dropbox account, the (split to avoid bots) link to which is here:
http://manuals.wotmeworry.org.uk/ET2/Workshop%20Manual.html
et 2 50cc
Fri Jul 31, 2015 11:13 am quote
I tried to download it, but when I wanted to open, it asked password.
Fri Jul 31, 2015 11:17 am quote
Here's the direct link - does that ask for a password? I didn't put one on.
https://www.dropbox.com/s/fqkdfn7loa907bo/manual.7z?dl=0
You might have to install the free version of Dropbox if it still asks for a password.
et 2 50cc
Fri Jul 31, 2015 11:22 am quote
I downloaded from dropbox, but when I tried to extract the zip file, that was encrypted. I tried to open with different softwares too.
Fri Jul 31, 2015 11:55 am quote
Ah, if the 7-zip file needs a password, that'll be VespaET2 .
Can someone confirm, as it appears to open immediately for me?
Fri Jul 31, 2015 12:01 pm quote
Yes VespaET2
is the password
et 2 50cc
Fri Jul 31, 2015 12:14 pm quote
Fri Jul 31, 2015 12:19 pm quote
Thanks - I've amended the web-page.
Moderibbit
Fri Jul 31, 2015 2:38 pm quote
Gas spluttering out of there likely means your reeds are toast. Your rubber manifold is probably fine - but underneath is the reed cage and you will likely find that one failed, allowing the engine's rotation to push fluid back up such that it seeps out at the seam you are pointing to.
If your compression is bad, however, you may need top end work anyway (even if the reed didn't destroy stuff in there when (if?) it failed).
Pass pics along when you get a chance! The good news is the engines are super simple to work on, the bad news is ET2 parts don't grow on trees any more
[ Time: 0.1695s ][ Queries: 27 (0.0451s) ][ Debug on ]
