Replacing Rally 200 wiring loom
'76 Vespa Rally 200
Fri Jun 22, 2018 1:43 am quote
After ten years with my Rally I know every inch of it, and having rebuilt the engine and suspension, the wiring is now the worst part of it. I've had a couple of electrical issues over the years, and managed to fix them, but I know where all the bodies are buried. It's only a matter of time before this 42 year old wiring strands me, and I'd rather get ahead of it. I think it's time for a new wiring loom.
SIP has a variety of looms for sale, and I've confirmed with them that this one is the best fit for my Rally. Mine is in original configuration, with Femsa ignition and US indicators. I'll have to modify this loom slightly to add leads for the rear indicators, but otherwise in theory it should be plug and play.
https://www.sip-scootershop.com/en/touch/Details.aspx?ProductNumber=87001410#Recommendations
Just wondering if anyone else has experience using these looms or other ones. I'd like to do this replacement over the Aussie winter.
79 P200E ; 61 VBB
Fri Jun 22, 2018 8:01 am quote
I replaced mine in my double yellow p with the SIP worked great only difference was the color of one wire on the turn signal circuit and an extra ground terminal near the battery. Everything works great.
Fri Jun 22, 2018 3:36 pm quote
I hope it comes with a diagram as I see there's not one on the page. Also I hope it's absolutely perfect in every way as I've just ordered a SIP loom for the smallframe.
'76 Vespa Rally 200
Fri Jun 22, 2018 3:46 pm quote
It hadn't occurred to me that they would use different colors from the stock harness, so I thought the wiring diagram from Scooterhelp would be sufficient.
vespa 125 vnb1t
Sat Jun 23, 2018 2:14 am quote
iv'e done two 12v loom conversions on primavera's one with indicators both sip looms didnt have wires for the front side/parking light
each came with a diagram but in german
Sat Jun 23, 2018 4:58 am quote
I got a SIP loom for one of my 70’s Soops. Ended up not needing it, and gave it away, but it was good quality and all the connections were there. The wire color differences are not a big deal ... once you lay it out it’ll be clear where everything goes. If not just get out the multimeter...
'76 Vespa Rally 200
Mon Sep 03, 2018 10:55 pm quote
Picked up the new loom today. The diagram in German is serviceable, although it looks like it is a fifth-generation photocopy... oh now I've just realized, I think this must be from a factory repair manual. Anyway I translated the colors into English and matched everything up, it looks good. I forgot that, in addition to the indicators, there is one other slight difference - Euro Rallys had the high/low beam, horn, and kill switch all on one switch. US ones had the indicators and kill switch on one, horn and high-low beam on the other. It looks like this loom is wired for a separate indicator switch, so I will just need to route the kill switch lead over to that branch. Shouldn't be too horrible. I hope...
I also just realized that this loom doesn't seem to have leads for the front brake light switch. I'll have to look into that.
Tue Sep 04, 2018 6:14 am quote
well, you can always Tee a pair of wires down to your rear brake light switch so that you can activate the brakes lights via the front brake lever.
And since you have had the harness in your hands, does it feel like SIP uses quality wires and terminal ends?
'76 Vespa Rally 200
Tue Sep 04, 2018 4:08 pm quote
Yeah, I am expecting to have to feed some additional wires around, so I just need to tally them up.
I'm happy with the quality of materials used. I know from experience that this wiring diagram is accurate for the US bike, and I can see that the new loom uses some different colors for the switches and indicators. Probably correct for the Euro bike. So I will just need to use the multimeter to trace things out. I'll document this for future generations.
I am a little disappointed about the quality of the connector crimping. Almost all of them look like this. The rear tabs should enclose and grip the insulation, for strain relief. I'm going to have to fix these up myself.
'76 Vespa Rally 200
Sun Nov 04, 2018 7:41 pm quote
I'm trying to figure out how I will modify the new wiring loom to run the rear indicators on my bike. I know the current setup, as on the P series bikes, powers them through the pins on the cowls. But where/how are the electrical connections made inside the openings in the chassis that the pins go into? Can anyone show me a picture of this, or describe it? I wonder if those wires even run through the main loom, or if they were wired separately because they only went on the US bikes. Then again that wasn't the case from the P series onward, so you'd think those would have integrated these leads into the loom.
Sun Nov 04, 2018 8:20 pm quote
Hey Auto - I don't know if this is going to answer your question or not, but hopefully this will help you figure it out. I've got a 79 P200 US version. The cowl pins are the hot wire to the blinkers. Brown for left, and Blue for right. The cowl catch is the ground (Black wire). All three of these wires go into the wire loom and connect at the block under the horncast. I'm going to post a pic of the inside under the tank, and a wiring diagram. I hope this helps!
The Brown wire (Left blinker) goes to the cowl pin and the black wire at the end of the spring is grounded through the loom at the connector block under the horncast.
Wiring Diagram...
'76 Vespa Rally 200
Sun Nov 04, 2018 8:24 pm quote
That is *perfect!* So I would be able to get at this from under the tank - I've had mine out once in ten years, to put in a new rear shock. I didn't look too closely back then at what else is under there. OK so I will need to feed two more wires down to that point in my harness. Hopefully I can manage that! Thanks a lot
Sun Nov 04, 2018 8:32 pm quote
Yup - under the tank. This picture was taken just a few days ago. I put in a CHT and ran the wire up to the horncast. I ran an extra green wire and a couple of spare "stringers" from weed whacker string for future use or just in case.
You can just see a bit of the brown wire, and the black wire on the end of the spring. They both feed into the loom and up to the junction block under the horncast.
Oh, and while you have the tank out you might as well replace the fuel line.
And I'm glad I could help! Keep us posted when you get it all sorted!
'76 Vespa Rally 200
Sun Nov 04, 2018 8:53 pm quote
Good point on the fuel line, I even have a spare length ready to go from a previous effort that I ended up aborting.
I'm surprised that they bother to run a ground wire from the spring through the chassis. I would have thought they would just ground to the chassis itself right there somewhere.
How did you fish the new leads through the frame without removing the old harness? I'm intending to tie pull strings or wire of some kind or other to the old harness and feed them through as I remove it, and then use those to help pull the new one into place.
Sun Nov 04, 2018 9:58 pm quote
Check out this thread: P200e - this time for real! (Page 6)
Basically I ran an electricians fish tape from the horncast area to the tank area, then gently pulled it back through with the bundle of wires taped to it. It wanted to hang up around the rear brake area - it got kinda tight, but I just pulled a bit harder and it popped through. I've got pics in the thread above.
What you're going to do sounds like it'll do the trick and you won't need to use an electricians fish tape.
'76 Vespa Rally 200
Sun Nov 04, 2018 10:17 pm quote
Thanks a lot! Just gives me an idea of what to expect when I get my stuff apart. Much appreciated!
PX200E
Fri Nov 09, 2018 11:13 pm quote
Done it did not enjoy it
Years ago replaced a Rally 200 loom and still have the scars. This was pre SIP days and used a Beedspeed one. The biggest challenge was there is a welded plate in about halfway to the rear brake that has two holes cut through for cables and loom. My loom kept getting caught on that point and had to stick my hand deep inside the body to get a draw wire through.
That hole is pretty tight and ended up having to remove the side cover clips and springs even then I could only just get my hand in.
Out of interest why keep the indicators? Pre 76 should just squeak into the "none required"ADR rules same with the front brake.
Do you have a neutral light? Recall a Victorian Rally that had one back in the day that had been a private import.
'76 Vespa Rally 200
Sat Nov 10, 2018 1:31 am quote
Re: Done it did not enjoy it
I have small hands that can get into tight spaces, I've done work at the back of my Porsche engine that everyone else says you need to drop it to accomplish. I also have a flexible inspection camera, and I'm planning to pull a gear cable through when I remove the old one, to use as a guide/pull wire. With all that, I think I'll manage, but yeah not looking forward to it. I didn't think the blockage had holes in it, I thought it was two fences, one welded to the top and one to the bottom of the tunnel, so you had to go over one and under the other. Maybe that's a different model.
I like the fact that my bike is bone stock except for the pipe, and the indicators work fine, so why not keep them? It doesn't have a neutral light, I've never seen that on a Rally.
PX200E
Sat Nov 10, 2018 5:21 am quote
A camera and small hands will make the job a bunch easier; wish I had them as it would have saved hours of garage time!
Might be wrong but the US Cali Rallys required a neutral indicator by law. My Rally had had bar end indicators but they had got "lost" between delivery and being acquired in the late 80's. Was registered with none as a pre compliance version.
Someone imported at least 1 Rally from the US. It used to turn up at national meets in the early 90's and had the US indicators and sensor on the gear selector box.
'76 Vespa Rally 200
Sun Jan 06, 2019 4:02 am quote
OK, I need some help from the brain trust. I spent some time earlier today mapping out what is different from the Euro wiring loom that I got from SIP, and my stock US wiring. I had thought it was just the indicators and kill switch, but now I'm going down a rabbit hole having discovered that the wiring from stator to regulator to the rest of the bike is also different, and I can't quite wrap my head around why. I would really like to understand this so I can figure out how the new loom is going to hook up (with or without further mods).
Attached is a scan of the wiring diagram I received with the loom (if anyone can share a clearer copy of this, I would appreciate it - looks like it is from a service manual or something), and the diagram from scooterhelp.com which matches what is in my bike. I will refer to these as the US vs. Euro wiring.
The US wiring has two yellow leads running from one coil of the stator, through the junction box on the engine, and into the regulator/rectifier. The Euro wiring has only one yellow lead. Question: why two leads vs. one? I think I will need to add one to work with my rectifier.
The US wiring has a pink lead coming from the rectifier, through a fuse to the battery, and also jumpered at the fuse into a red lead which goes to the key switch. The Euro wiring just has a red lead which goes straight to the battery (and testing my harness indicates it does not go anywhere else). Question: I must be missing something, but how is power getting from the battery into the rest of the circuit in the Euro wiring?
This is where I am really baffled. The US wiring has a purple lead coming from the rectifier to the indicator flasher, which is jumpered to a green-and-white lead which goes to the keyswitch and then to the horn. From the horn it appears to jumper to a green and black lead which then goes to the hand and foot brake light switches. The Euro wiring has a purple lead which goes from the rectifier directly to the key switch. The Euro indicator flasher seems to get power via a yellow lead from the foot brake switch. So in the Euro system, it seems that one output from the regulator JUST charges the battery, and the other goes to the key switch and then to everything else. But how does the battery power anything? Is there also a jumper at the regulator so that battery voltage can flow through it to the other output?
If your head is swimming after trying to read this, look at the diagrams. If it's still swimming, you will see where I'm at. I'm not sure how I am going to wire my stator, regulator, and indicators with the current harness. It seems like the difference in regulator design may impact a few things. If anyone has insight about that, it might be useful!
euro rally wiring loom.pdf
 Description:
Download
 Filename:  euro rally wiring loom.pdf
 Filesize:  966.47 KB
VSE1.wKey.Batt.Blinks.B1977.pdf
 Description:
Download
 Filename:  VSE1.wKey.Batt.Blinks.B1977.pdf
 Filesize:  22.36 KB
Sun Jan 06, 2019 9:28 am quote
Electrical stuff can make you crazy. Before getting too wrapped up in wiring diagrams and wire colors, the first thing you need to do is figure out your “end game”.
Are you trying to re-create the stock US electrical wiring on your Rally? Or are you doing the Euro wiring? Or some variation?
If you’re just trying to add flashers to your US bike, take both harnesses out and lay them side by side. Forget about colors for now... figure out what connections are missing from the new harness and just add them.
To answer your questions:
1. Why two yellow leads vs. one? US battery bikes used a “double yellow” off the stator for rectification. Euro’s are rectified differently. You’ll need to run a second yellow wire from the terminal to the US rectifier.
2. How is power getting from the battery into the rest of the circuit in the Euro wiring? Through the key switch.
3. Is there also a jumper at the regulator so that battery voltage can flow through it to the other output? Basically yes. That’s a diode AC/DC converter. It’s the Euro equivalent to the US rectifier.
Hope this helps.
Sun Jan 06, 2019 11:01 pm quote
I guess another option is to re-create the original loom? More work but less brain pressure!
With the old loom pinned down on a board and unwrapped, it ought to be pretty easy to copy. Just need a decent stripper and crimper, and of course some good quality connections and wire of the right colours.
I looked for some wire last year and finally found some that is sold with a trace colour - though I see there is only a few in your diagram that needs a trace. Anyway this seller has lots on ebay of varying thicknesses -
https://www.ebay.com.au/itm/Selection-of-6-x-5-m-3mm-AUTO-WIRE-20-Amp-TYCAB-AS-PER-LISTING-F-POST/152733133813?hash=item238f9aabf5:g:Z14AAOSwuMFUalz5:rk:14:pf:0
'76 Vespa Rally 200
Mon Jan 07, 2019 12:11 am quote
Thanks SocalGuy, that helps! I'll definitely add a yellow lead for the regulator, and knowing that current can flow back through the regulator from the battery to the key switch in the Euro setup helps clarify things. It's interesting that the Euro setup does not seem to have a battery fuse.
Ginch, I definitely think laying them out will help, but I think I can make do with what I have for some things. It may not be practical to try to replicate the US harness exactly.
'76 Vespa Rally 200
Mon Apr 29, 2019 5:31 pm quote
These wiring harnesses are doing my head in. If I had known how different the Euro harness was from the US, I would have just copied my US harness from scratch. There seem to be some fundamental differences, and I am hesitant to try and use the new/Euro harness without making it match the old/US one.
Part of the problem is possible that I keep trying to understand what the hell is going on in the old harness. What is this purple lead running from the rectifier to the indicator flasher, where it is jumpered to a white and green wire that runs to the horn?? Rectifier, indicator, horn?? WTF? And why does the green and black lead for the brake light switches also run through the horn? Whyyyy???
Whereas the leads for the brake switch in the Euro wiring harness are white, yellow, blue. It's not even clear how I would wire that into my switch. Raaaaa.
Mon Apr 29, 2019 6:47 pm quote
I feel your pain. It's questions like that that made me do my own loom and go all DC.
I think that often these connections are jumpered for convenience... I mean to avoid a dedicated wire to the horn etc. That's how I see it anyway.
'76 Vespa Rally 200
Mon Apr 29, 2019 7:44 pm quote
It's like every time they changed something, they just took the loom from the previous model and added a wire here or there.
Tue Apr 30, 2019 12:33 am quote
Didn't you know? In English Piaggio translates as "random"...
Maybe before doing anything to the new loom, you could sell it as new and make your own using the original as a template. Craig just told me about an automotive electrical supplies business in Bayswater that he's used previously.... here it is - https://jaydeeautocables.com.au/
'76 Vespa Rally 200
Tue Apr 30, 2019 3:36 am quote
It seems unlikely anyone would happen to need a Euro Rally harness. I had thought about trying to return it to SIP, even if only for credit, but it seems unlikely they would take it. I bought it ages ago.
Thanks for the tip on Jay Dee, that might come in handy.
Tue Apr 30, 2019 5:01 am quote
Get 25ft of this and some connectors and make your own.
https://www.wirebarn.com/16-GAUGE-6-CONDUCTOR-TRAILER-CABLE_p_635.html
Tue Apr 30, 2019 6:49 am quote
Auto-
Forgot your name but you hooked me up with your 6V tender before you left. Give me a bit to read up but hope I can help.
I’d second what others have said and just use that SIP harness as best as you can and then wire in the rest. Time wise, buying a correct one is the fastest, then Frankensteining one, then building your own from scratch.
So from reading up, youre having problems with the regulator wiring, turn signals, no fuse at the battery and no front brake switch?
Regulator- does your original regulator/rectifier work or did you replace it with something different? I’m thinking you can run another yellow wire from the stator to your regulator (if its OG) otherwise, you can ground one yellow stator wire and get 12V AC out of the other yellow wire.
Turn Signals- Did the 77’s have the 2 post or 3 post turn signal relays? Hopefully two like the euro diagram so you can just make jumpers for the rear end.
The aluminum stalks that hold up the pods on US Rally’s can cause grounding problems. I’d recommend running a dedicated ground wire through the stalk to the pod. I did that with Modkuo’s 100 sport donor frame build a few years ago and the lights work every time, full brightness. You’ll have to disassemble the headset so you can unscrew the stalks from the headset but since the headset will be coming off for a harness swap, now will be the time to run the grounds and not just rely on the mounting bolts to do the grounding.
Inline fuses are easy to find and you’ll just need to solder one in. Make sure you dry fit it before soldering as the battery box has a few bends and curves you’ll need to account for when mounting.
The front brake switch I’d say run two wires from the front switch to the rear switch like the US diagram shows.
Let me know if you have any other questions. PM works
[ Time: 1.1019s ][ Queries: 25 (0.1099s) ][ Debug on ]
