Indicator Relay On 2007 GTS250ie
Vespa GTS250ie
Sun Dec 09, 2018 9:17 am quote
Indicators not working, been told that the relay is built into speedo/instrument panel.
Is there a workaround ??
Can i just get a relay and wire to back off indicator switch, don't want an expensive job if i can help it.
Any advice gratefully received.
Sun Dec 09, 2018 11:16 am quote
Re: Indicator Relay On 2007 GTS250ie
You can add a separate two-pin indicator relay - the one for the 300 would work fine. Copy the 300 wiring.
Vespa GTS250ie
Sun Dec 09, 2018 12:02 pm quote
Just been looking at the wiring diagrams.
So is it basically a wire from a switched + to the relay
and then from the relay to the common connection on the back of the indicator switch.
Sun Dec 09, 2018 12:10 pm quote
That's it.
Vespa GTS250ie
Sun Dec 09, 2018 12:41 pm quote
Thank You, thought it was gonna be a costly dash replacement.
Hardly worth it on a 11 year old scooter.
Mon Dec 10, 2018 10:15 am quote
The turn indicator relay circuit is different than the gts. It has a real relay which of I remember correctly is behind the left knee pad on my 2009. Look at the gtv electrical diagram, not the gts which has the indicator signal originating from the ecu. Wiki has a pointer to Electrical diagram
Best. Miguel
Mon Dec 10, 2018 11:52 am quote
Best. Miguel
The GTS300 has a separate relay - and that is what we were referring too. Both the GTS250 AND the GTV250 have the turn signal pulses originating in the dashboard electronics. No need to refer to any GTV diagram.
Mon Dec 10, 2018 4:01 pm quote
jimc wrote:
Best. Miguel
Sorry, I misread and thought this was about a gtv250 but it's about a gts250. I was moving too far this morning
Miguel
[ Time: 0.1370s ][ Queries: 25 (0.0263s) ][ Debug on ]
