MP3 Engine management light on |
Post Reply Forum -> MP3 Discussion |
Author | Message |
![]() Hi I have a MP3 lt 300 2011 with a Engine management light on ! Where is the code reader plug 😅
![]() If any of you good people can help in any way ! Engine management Light just came on bike running fine , it had been sitting for two months as the fuel pump went ! Also is there a way to clear it without a code reader ! I have one just can’t find where the socket is on my bike or if I need special lead , any help would be amazing
Thanks 😀 |
![]() ![]() The Hornet (GT200, aka Love Bug) and 'Dimples' - a GTS 300
Posts: 39226 Location: Pleasant Hill, CA |
![]() Does it stay on all the time - or only when revving above idle? Regardless, the first step is to monitor your battery voltage at idle and then at higher revs - the usual culprit is a regulator that's given up its smoke, and is sending out a voltage that is far too high.
![]() Morning
Ok thanks it stays on all the time, what should the voltage be I think it said 13.5v on idle ? Thanks for your help 👍🏻 |
![]() Hi also is ther a code socket you can plug into like on a car ?
Thanks |
![]() Robrjh wrote: Hi also is ther a code socket you can plug into like on a car ? Thanks Voltages (with a known good fully charged battery): at idle, anywhere above 12.6V, at 3,000 rpm or higher over 13.8V but less than 15V. Higher than 15V means a bad regulator, as does less than 13V at high revs. |
![]() Thanks for your help I will check tomorrow! If the voltage is ok what should I look at next , maybe get it on a code machine
Thank |
![]() ![]() Piaggio Medley 150 iGet and Drive Easy Rider Scooter
Posts: 140 Location: Brisbane, Australia |
![]() jimc wrote: Does it stay on all the time - or only when revving above idle? Regardless, the first step is to monitor your battery voltage at idle and then at higher revs - the usual culprit is a regulator that's given up its smoke, and is sending out a voltage that is far too high. The machine has only done 6800km and should not need a regulator transplant surely? But, as I have found out to my chagrin, these things are like petulant little children and the complaints never end. |
![]() Robrjh wrote: Hi mines the same runs fine but the light is always on |
![]() ![]() Neutrino MP3 492.7 AK, 2013 Moto Guzzi Norge
Posts: 21694 Location: Harriman, Tennessee, Tn |
![]() jimc wrote: Robrjh wrote: Hi mines the same runs fine but the light is always on |
![]() old as dirt wrote: jimc wrote: Robrjh wrote: Hi mines the same runs fine but the light is always on |
![]() Wait, bluetooth OBD2 transceiver works with Piaggio's connector. I bought an Fiat's adapter and installed a program to my Android phone, and it connected and showed some data.
![]() ![]() 2008 MP3 500, 2013 BV350, 2020 Vespa Sei Giorni
Posts: 8716 Location: Ashburn, Va. Home to the Internet |
![]() Jah wrote: Wait, bluetooth OBD2 transceiver works with Piaggio's connector. I bought an Fiat's adapter and installed a program to my Android phone, and it connected and showed some data. |
![]() Going by your location, if you can get to two wheels ahead in Croydon they charge £30 to hook it up to the diagnostic machine and they seemed pretty honest when they done it to my yourban.
I’ve been quoted by other piaggio dealers £80 for that pleasure. |
![]() Hi everyone
I have an abs fault on my MP3 where is the best place to start Thanks Rob |
![]() Hi the fault code is U1705 as says
ABS NODE CAN line diagnosis - no node Help please please 😜 |
![]() Robrjh wrote: Hi the fault code is U1705 as says ABS NODE CAN line diagnosis - no node Help please please 😜 |
![]() My mp3 dose not have abs they didn’t put it on till 2016 , there is. No fuse or no abs light ?
![]() ABS fault (no ABS) on a bike with no ABS is puzzling. In my mind that's not actually a fault. Maybe the code is different for that year? Or somebody replaced the ECU with a different one from an ABS bike? Or there's a wire missing/broken/disconnected that tells the ECU that there's no ABS on this model?
![]() Not shore it was at a garage but they agreed I don’t have abs so have no idea got it booked in at another garage in Croydon now
![]() I take it you’re taking it to in moto? Someone who has worked on my bike has said good things about them.
![]() Hi all I’ve been told my MP3 not well if your not sitting on the seat and Rev the bike would move of ie the cut out sensor dose not work so the bike is not talking to the other ecu can anyone help
Thanks |
![]() So it’s to do with the Electronic parking unit.
If it’s a break in the wire loom then that could be a really expensive job unless you can find the fault yourself. Did they say much more as I’m sure the more information provided, someone could give you a pinpoint response to the problem. |
[ Time: 0.1383s ][ Queries: 25 (0.0282s) ][ Debug on ] |
