Seat sensor not bypassed, but engine starts when not seated |
Post Reply Forum -> MP3 Discussion |
Author | Message |
![]() Been looking into tilt lock not working and have found much info here but haven't found this anywhere to date. The new to me scotter (3 days ago) is on its stand and the tilt lock is off. I can start the engine standing next to it without any warnings and I can jump on and ride it. The seat connector is connected and never been bypassed, but doesn't appear to be working, but it also doesn't stop me from riding it. If I try to lock the fork, it won't lock and I get the warning light with a 5 sec beep and 2 seconds between beeps. Not sure if the 2 are related or not. I tested the micro switch continuity this morning and found the switch appears closed and not open like it should be. That may be the tilt lock problem or not, but the seat sensor baffles me because if it's not bypassed, but also not working so the bike shouldn't start.
![]() 2019 MP3 hpe 500 sport Advanced " Missy "
Posts: 288 Location: West Germany |
![]() Seat sensor
Hello Winterhawk. Sorry to tell you this, but the impie is supposed to be able to start even if your'e not sitting on it. It will just spit and splutter and won't go anywhere if your'e not sitting on the saddle no matter how much gas you give it. Once you on the saddle it closes the circuit and the scooter will be able to move. It's a safety feature.
![]() Okay, my mistake, but when not sitting on the saddle I can Rev the engine to any RPM I want. So now I know the starting is okay but why can it Rev above 2000?
![]() You can rev it when not sitting on the saddle when the tilt lock is off. If the tilt lock is on and you're not on the seat, the rev limiter to 2000 kicks in and it sputters and pops. This keeps you from revving the bike while tilt-locked and having it lurch away. If it's on the center stand, no problem with revving it. If you're sitting on it, revving it forces the tilt lock to unlock.
It sounds like everything is working properly with the rev limiter, it's just a problem with the tilt-lock. Has it ever been able to lock? |
![]() It doesn't matter if the tilt lock is on or off it still revs above 2000. I can put the the tilt lock on, stand by the bike and Rev above 2000 and the tilt lock turns off. At least the light turns off, but the tilt lock still doesn't work. I'm working on that now. I bought the scooter knowing it didn't work. The bike had been sitting for 2 years. Adding gas and a new battery and it started right up. It had been serviced with all new fluids just before being put it in storage. I need to change all fluids again, but would like to diagnose the tilt lock first. The seat sensor thing was one thing I was obviously very confused about. This is actually my wife's scooter, but by default I get to make it all work and be safe. Like many here I'm not near a dealer so that makes this forum very useful.
![]() Hello Winterhawk. You said yourself that you had a problem with a switch on the tiltlock. So if it`s not working properly then it may also revv with the tiltlock on. Change that Switch out. It doesn`t coust that much and is most likley the reason for your pain. If the problem still exists, then take it to a Piaggio werkshop. Maybe they can help you. Good luck!
![]() Hello Winterhawk. I just reread your first post and it looks like it is definitely that microswitch that is cause of your pain. Change it. Please let us know if it
that was the problem for future reference. Please do not do anything with the seat sensor until the problem with the tiltlock is ironed out. If the problem is still there, then we`ll talk about the seat sensor. Okay? One problem after the other. P.S. Please don`t this as a personal afront. I am only trying to help. Caio Bello ![]() |
![]() I agree with Hillbilly Fred- I think the rev limiter may fix itself once the tilt lock is fixed. A common problem is that the pressure switch leaks and then air gets in the hydraulic system, then nothing works and it blows the horn and causes all sorts of problems. Check for brake fluid around the pressure switch, and if it's leaking, then the switch needs to be replaced. Then you'll need to bleed the system, which is a PITA. It needs to be done by pushing fluid from the bottom on both sides, but once that's done, you're golden. Also make sure your battery is healthy; I've heard of problems in the tilt-lock system caused by a weak battery too.
![]() Squeazel wrote: I agree with Hillbilly Fred- I think the rev limiter may fix itself once the tilt lock is fixed. A common problem is that the pressure switch leaks and then air gets in the hydraulic system, then nothing works and it blows the horn and causes all sorts of problems. Check for brake fluid around the pressure switch, and if it's leaking, then the switch needs to be replaced. Then you'll need to bleed the system, which is a PITA. It needs to be done by pushing fluid from the bottom on both sides, but once that's done, you're golden. Also make sure your battery is healthy; I've heard of problems in the tilt-lock system caused by a weak battery too. Thanks to everyone! One more thing, an online search found several places to buy parts, but none showed the microswitch. Is it always best to buy from or contact the dealer first, or are there good suppliers in North America I can trust? |
![]() Try eBay first . You might get lucky and get it cheaper. Stranger things have been known to happen (Like finding a needle in a hey stack )
![]() I removed the microswitch this morning to test while not connected and removed from bracket. The switch works perfectly but the manual I downloaded here from Wiki has me confused (I get confused easily). Anyway it says "adjust the cable so the switch is pushed when the system is unlocked". The schematic shows that the switch is normally open, but is that normally open when locked or unlocked? I believe the switch is supposed to be closed when in the unlocked position and when the lever moves during the locking it's supposed to open. If that is the case I can move on from the microswitch and move to the geared motor as the possible problem. Thanks in advance.
![]() Hello Winterhawk. You'll have to do a trail and error on that one. I must grudgingly admit that I've never needed to do it myself, so I'm afraid I can't help you there. If you manage it though please post for future reference. Okay? Thanks.
![]() Now that the tilt lock is working I just wanted to say that the seat sensor works as it should as well. Everything is back to normal, new microswitch arrived today and is now installed, just need to put all the body panels back on. Only known issue is the right front tire loosing 5 psi per day. Will leak test it after all the panels are back on.
[ Time: 0.1440s ][ Queries: 25 (0.0356s) ][ Debug on ] |
