Fuzzy Washer Mod
GTS 300 Super
Wed Jan 30, 2019 9:55 am quote
Has anyone done the fuzzy washer mod and still had the belt rub?
The mod is to put an extra washer before the outer half of the variator, I guess so the two halves won't squeeze together too much, and the belt won't ride too high. I assume that will take care of the belt rubbing issue, but I wonder if there have ever been cases where the belt has rubbed even with the washer in there.
I'm running 21x17 14 g rollers in a gts 300.
Wed Jan 30, 2019 1:33 pm quote
With standard size rollers in the standard variator you don't have to worry about belt rubbing. With sliders or an after-market variator you might. Depends on the thickness of your washer.
50cc Beo, BigBeo
Thu Jan 31, 2019 11:35 am quote
Also if you buy "100% compatible" belts from a Greek seller on ebay. At least, my belt for 250cc mp3 was longer, thus made lots of noise.
GTS 300 Super
Fri Feb 01, 2019 7:54 am quote
Clarification
I'm using Dr pulley sliders (the odd shaped ones not the round ones) and the washer is the same size as the one that is already in there.
I don't think anyone has ever had the belt rub with an extra same sized washer in there.
But its a little ridiculous, if you think about it. The Dr. Pulley makes the variator halves close more tightly than they otherwise would; and the washer makes the variator halves close less tightly than they otherwise would.
2008 Vespa GTV 250 1962 VBB 1965 VBB
Sat Jul 06, 2019 4:16 am quote
I have a malossi variator, 13g Dr sliders and two stock washers and had rubbing on deceleration from 100 km/h. Three washers needed to get no rubbing.
[ Time: 0.1263s ][ Queries: 25 (0.0251s) ][ Debug on ]
