Roy2456 wrote:
I'm looking to you guys for your input as to why the bike seems to run poorly ie almost as if it is on full choke when you 1st pull away...but suddenly clears and pulls like a train....is this normal ?
That was normal for the the LML 150 engine I am replacing with a restored P200E engine but it's not supposed to be normal......and timing was the only thing i could never check due to damaged crankshaft threads.
Check timing and be careful with those threads.
