Posts: 4109 Location: Veria, Greece |
Posts: 289 Location: Cary, North Carolina |
quote
SaFiS wrote: This one is a points ignition flywheel that's why is different... |
quote
Also it cant be for points ignition, there is no lobe on the hub to open and close the points.
quote
SaFiS wrote: I hope PP pulls through and get your money back... |
quote
Tradspa wrote: rowdyc wrote: chandlerman wrote: A P200 motor seems to usually go for about $800 to $1,200. They're just hard to find. https://miami.craigslist.org/mdc/mpo/d/miami-piaggio-vespa-200cc-px-stella/6842996807.html $1200 They come up often but not a lot. It just seems not at the time when people think they want one. Patience is a virtue. "· Engine built on Pinasco master engine case. " Haven't I been hearing bad things about those? |
Posts: 4409 Location: London UK |
quote
Your problems sound like a nightmare. If this is the wrong flywheel what is it supposed to fit?
How many degrees out is the timing? Did you measure with a strobe light? Is an option to forget the marks and move the stator to where the timing is correct (23 degrees). Then you can move onto the 'what else is wrong in this motor' stage. |
quote
Jack221 wrote: Your problems sound like a nightmare. If this is the wrong flywheel what is it supposed to fit? How many degrees out is the timing? Did you measure with a strobe light? Is an option to forget the marks and move the stator to where the timing is correct (23 degrees). Then you can move onto the 'what else is wrong in this motor' stage. |
Posts: 9335 Location: Nashville 108 Days Since Last Explosion |
quote
Can you post a picture of the stator and a close-up of the crankshaft?
At this point, I'm thoroughly confused by what looks like a points flywheel, but a Ducati CDI. I'd like to have a full inventory of relevant parts so we can figure this mystery out. |
quote
chandlerman wrote: Can you post a picture of the stator and a close-up of the crankshaft? This makes 3 years of constant disappointments on Vespa. I guess its just not meant to be. |
Posts: 4159 Location: Florence, OR |
quote
Tradspa wrote: I guess its just not meant to be. I have faith you can get things sorted. Your scooter looks fantastic! You got this! Don't lose hope! |
quote
I don't know where you're located, but I'm sure that someone on this forum is nearby and would be happy to help. I'm in Chicago, if that's anywhere nearby, and would be more than willing to roll somewhere to help out.
Posts: 4110 Location: Staten Island, NY |
quote
If I'm not mistaken, you are in NC right? Scooter Mercato is in Georgia and May be able to help. Also in the Ohio area is the guy that does thatscooterthing engine rebuild videos on YouTube. If you contact him on YouTube or Instagram he may be willing to help.
This is tragic to observe from outside and I'm impressed you have not given up! At this point it may be better to just drive the distance and take your frame to one of these established guys and pay them in beer or cash to get the engine running and into frame. Hoping your nightmare ends soon. |
quote
New flywheel keys showed up today. Dug out my old pointer torque wrench that was a gift to me from my father's childhood best friend. He gave it to me when I was 17 in 1988 and I dont recall ever using it on anything but the heads on my first 1967 VW Beetle (my first car)
Spec says 47 ft.lbs on the flywheel nut on this PX200E motor. it was damn scary putting it on that tight but hey....WW2 was won with a torque wrench, they didnt just say 'oh that's tight enough' so i spun it on around. Yeah she fired up on the first kick. 23 degrees lined up nearly perfect with the strobe, couldn't get a pic of it though. Leaking out from the exhaust flange is the only issue but I was told that would probably happen. Rode it about 1 mile and wew lad the power. Thanks to everyone who helped and a word of advice to any noobs like me, when you buy a rebuilt motor no matter who it comes from, verify the torque on the flywheel nut BEFORE you crank it. Cheers |
quote
chandlerman wrote: Glad to hear that things are coming together after all! |
quote
swiss1939 wrote: Congrats man! Hopefully this nightmare is at the end! |
Posts: 5059 Location: Oceanside, CA |
quote
Good to hear you got your timing sorted but kinda switching topic, another way I have found to determine if you have a P125 points flywheel verses a P200 is to look at the inside collar, not the outside like you posted. You'll notice a lobe where the cam rides. It's very subtle and P200 wont have it.
I dont have any pictures of it, but I recently rebuilt a P125 kitted to 170 motor for a friend. In addition to it not being properly jetted, it wasn't timed. Friend upgraded it to electronic ignition at some time prior and rode it, seized it and I was tasked with cleaning up the carnage. It started and ran, but timing was way off. With the stator turned as far as I could in the slots I was still a good 10 off. Robot at Motorsports showed me the cam lobe on the inside and things started to make sense. I swapped it with a P200 flywheel I had lying around and things lined up on the strobe. Kit ran much better after that and no problems so far. I still wonder if you could dremel the stator slots even more and get the stator eventually lined up for proper timing with the wrong flywheel? Anybody know? |
quote
MJRally wrote: I still wonder if you could dremel the stator slots even more and get the stator eventually lined up for proper timing with the wrong flywheel? Anybody know? |
quote
Yea that's what I was thinking but never tried it. It wasn't my setup so I gave him the right flywheel.
Did you end up buying a new flywheel or did yours work? |
quote
mine worked. all i had to do was make sure the flywheel nut was torqued at 45-50 ft lbs and it runs like a dream.....so far.
quote
Killer. Dont forget to check the torque on your head nuts (16-19 ft/lbs) and the rear hub nut (55-65 ft/lbs, make sure there's a cotter pin).
quote
MJRally wrote: Killer. Dont forget to check the torque on your head nuts (16-19 ft/lbs) and the rear hub nut (55-65 ft/lbs, make sure there's a cotter pin). |
quote
So this happened first thing this morning.
The cheapo kick start stripped because it just clamps on, the bolt doesn't pass through the notch in the shaft like on a REAL Piaggio 174312 |
quote
Tradspa wrote: So this happened first thing this morning. The cheapo kick start stripped because it just clamps on, the bolt doesn't pass through the notch in the shaft like on a REAL Piaggio 174312
Positive
quote
Well, you probably wanted to replace that kick start with a curved VBB-style kick start lever anyway.
quote
chandlerman wrote: Well, you probably wanted to replace that kick start with a curved VBB-style kick start lever anyway. |
Posts: 1345 Location: Deep in the heart of Texas |
quote
Tradspa wrote: chandlerman wrote: Well, you probably wanted to replace that kick start with a curved VBB-style kick start lever anyway. https://www.sip-scootershop.com/en/products/kickstart+lever+vbb+style+_75122000 |
quote
Damn, looks like bump starting until you get a lever. Hopefully you don't live at the bottom of a hill.
quote
rowdyc wrote: Tradspa wrote: chandlerman wrote: Well, you probably wanted to replace that kick start with a curved VBB-style kick start lever anyway. https://www.sip-scootershop.com/en/products/kickstart+lever+vbb+style+_75122000 |
quote
So i took this 'free' exhaust off and attached it to the flange first then used a jack to push it up so i could the the bolt through the swingarm. I was able to get it up a little more on the flange doing this but It's still spitting a little oil...but less now
my main concern is there is a bit of sideways pressure on the flange now....potential problem? could this bit of sideways pressure cause the cylinder to flex under high speed/heat and cause a soft seize? |
quote
Tradspa wrote: So i took this 'free' exhaust off and attached it to the flange first then used a jack to push it up so i could the the bolt through the swingarm. I was able to get it up a little more on the flange doing this but It's still spitting a little oil...but less now my main concern is there is a bit of sideways pressure on the flange now....potential problem? could this bit of sideways pressure cause the cylinder to flex under high speed/heat and cause a soft seize? And no sideways pressure on the exhaust flange wont warp your cylinder. You'd need tons of pressure or something ridiculous to warp things enough for a seize. Break in correctly, jet accordingly and watch for air leaks. That will keep you from seizing. |
quote
MJRally wrote: Sadly youre not special with the exhaust pulling a bit. The quality control on exhausts is pretty low. My last 3 performance exhausts have all had something wrong with them. I think my last stock exhaust fit better than my $400 one. |
quote
what oil do yall use? i bought a bottle of this and have been using it but i dont like how its not blue...it doesnt change the color of the gas so sometimes im like....did i remember to mix this gas?
quote
Tradspa wrote: what oil do yall use? i bought a bottle of this and have been using it but i dont like how its not blue...it doesnt change the color of the gas so sometimes im like....did i remember to mix this gas? edit: then again, im on automix stella. not sure if it's the appropriate oil for premix. ⚠️ Last edited by swiss1939 on UTC; edited 1 time
Posts: 7054 Location: So Cal |
quote
SoCalGuy wrote: You should get in the habit of adding oil to the tank every time you add gas. |
quote
swiss1939 wrote: It's green
Positive
