Bogging at first 1/4 throttle [SOLVED with new motor]
Sat Apr 06, 2019 10:28 am quote
And this one's pulled from a working spare P200 motor I have around...
Sat Apr 06, 2019 10:32 am quote
SaFiS wrote:
This one is a points ignition flywheel that's why is different...
no it literally says electronic on the flywheel on the pic above plus....
Sat Apr 06, 2019 10:34 am quote
Also it cant be for points ignition, there is no lobe on the hub to open and close the points.
Sat Apr 06, 2019 10:42 am quote
SaFiS wrote:
I hope PP pulls through and get your money back...
Thanks, and thanks for posting. The nightmare continues.
Sat Apr 06, 2019 10:43 am quote
Tradspa wrote:
rowdyc wrote:
chandlerman wrote:
A P200 motor seems to usually go for about $800 to $1,200. They're just hard to find.
https://miami.craigslist.org/mdc/mpo/d/miami-piaggio-vespa-200cc-px-stella/6842996807.html $1200
They come up often but not a lot. It just seems not at the time when people think they want one. Patience is a virtue.
The listing states
"∑ Engine built on Pinasco master engine case. "
Haven't I been hearing bad things about those?
I should have bought this one. I talked to the builder, he is an old school dude from Italy living in the US now. Whats the deal with Pinasco Master cases though?
Sat Apr 06, 2019 7:28 pm quote
Your problems sound like a nightmare. If this is the wrong flywheel what is it supposed to fit?
How many degrees out is the timing? Did you measure with a strobe light? Is an option to forget the marks and move the stator to where the timing is correct (23 degrees).
Then you can move onto the 'what else is wrong in this motor' stage.
Sun Apr 07, 2019 6:40 am quote
i dont know. it doesn't run.
Sun Apr 07, 2019 7:37 am quote
Can you post a picture of the stator and a close-up of the crankshaft?
At this point, I'm thoroughly confused by what looks like a points flywheel, but a Ducati CDI.
I'd like to have a full inventory of relevant parts so we can figure this mystery out.
Sun Apr 07, 2019 8:16 am quote
I cant bear to even look at it right now. I am mentally exhausted with this. After dealing with a trash LML engine all last summer I am now out $2000 on another engine.... that doesn't run.
This makes 3 years of constant disappointments on Vespa. I guess its just not meant to be.
Sun Apr 07, 2019 9:00 am quote
Oh man, don't give up. I bought a scooter that I haven't even had to open it up for $2k. Well, then $$ to get it to me, then $$ to register and title, then $$ to make it mine. So, probably closer to $2,800. But still, I've ridden that scooter almost every day. Almost....Every...Day... Since I got it. Once they are sorted, they run quite nicely.
I have faith you can get things sorted. Your scooter looks fantastic! You got this! Don't lose hope!
Sun Apr 07, 2019 9:04 am quote
I don't know where you're located, but I'm sure that someone on this forum is nearby and would be happy to help. I'm in Chicago, if that's anywhere nearby, and would be more than willing to roll somewhere to help out.
Sun Apr 07, 2019 9:19 am quote
If I'm not mistaken, you are in NC right? Scooter Mercato is in Georgia and May be able to help. Also in the Ohio area is the guy that does thatscooterthing engine rebuild videos on YouTube. If you contact him on YouTube or Instagram he may be willing to help.
This is tragic to observe from outside and I'm impressed you have not given up!
At this point it may be better to just drive the distance and take your frame to one of these established guys and pay them in beer or cash to get the engine running and into frame.
Hoping your nightmare ends soon.
Mon Apr 08, 2019 2:06 pm quote
New flywheel keys showed up today. Dug out my old pointer torque wrench that was a gift to me from my father's childhood best friend. He gave it to me when I was 17 in 1988 and I dont recall ever using it on anything but the heads on my first 1967 VW Beetle (my first car)
Spec says 47 ft.lbs on the flywheel nut on this PX200E motor. it was damn scary putting it on that tight but hey....WW2 was won with a torque wrench, they didnt just say 'oh that's tight enough' so i spun it on around.
Yeah she fired up on the first kick. 23 degrees lined up nearly perfect with the strobe, couldn't get a pic of it though.
Leaking out from the exhaust flange is the only issue but I was told that would probably happen. Rode it about 1 mile and wew lad the power.
Thanks to everyone who helped and a word of advice to any noobs like me, when you buy a rebuilt motor no matter who it comes from, verify the torque on the flywheel nut BEFORE you crank it.
Cheers
Mon Apr 08, 2019 4:00 pm quote
Glad to hear that things are coming together after all!
Mon Apr 08, 2019 4:12 pm quote
Congrats man! Hopefully this nightmare is at the end!
Mon Apr 08, 2019 4:15 pm quote
thanks , its been a long road...now I hope to hit a longer one for real!! NC OBX!
Mon Apr 08, 2019 4:16 pm quote
So far so good Swiss, thank you for the encouragement!
Mon Apr 08, 2019 5:20 pm quote
Good to hear you got your timing sorted but kinda switching topic, another way I have found to determine if you have a P125 points flywheel verses a P200 is to look at the inside collar, not the outside like you posted. Youíll notice a lobe where the cam rides. Itís very subtle and P200 wont have it.
I dont have any pictures of it, but I recently rebuilt a P125 kitted to 170 motor for a friend. In addition to it not being properly jetted, it wasnít timed. Friend upgraded it to electronic ignition at some time prior and rode it, seized it and I was tasked with cleaning up the carnage. It started and ran, but timing was way off. With the stator turned as far as I could in the slots I was still a good 10 off.
Robot at Motorsports showed me the cam lobe on the inside and things started to make sense. I swapped it with a P200 flywheel I had lying around and things lined up on the strobe. Kit ran much better after that and no problems so far.
I still wonder if you could dremel the stator slots even more and get the stator eventually lined up for proper timing with the wrong flywheel? Anybody know?
Mon Apr 08, 2019 5:29 pm quote
you could absolutely do that yes.
Mon Apr 08, 2019 5:37 pm quote
Yea thatís what I was thinking but never tried it. It wasnít my setup so I gave him the right flywheel.
Did you end up buying a new flywheel or did yours work?
Mon Apr 08, 2019 5:51 pm quote
mine worked. all i had to do was make sure the flywheel nut was torqued at 45-50 ft lbs and it runs like a dream.....so far.
Mon Apr 08, 2019 5:59 pm quote
Killer. Dont forget to check the torque on your head nuts (16-19 ft/lbs) and the rear hub nut (55-65 ft/lbs, make sure thereís a cotter pin).
Mon Apr 08, 2019 6:43 pm quote
THANKS i'll do this tomorrow !
Tue Apr 09, 2019 9:05 am quote
So this happened first thing this morning.
The cheapo kick start stripped because it just clamps on, the bolt doesn't pass through the notch in the shaft like on a REAL Piaggio 174312
Tue Apr 09, 2019 9:41 am quote
Another win for OSC
Tue Apr 09, 2019 9:42 am quote
Well, you probably wanted to replace that kick start with a curved VBB-style kick start lever anyway.
Tue Apr 09, 2019 9:46 am quote
I do, but i'd have to split the case and install a vintage quadrant, because the vintage quadrants and P series quadrants are different. A Vintage lever wont fit on this P motor.
Tue Apr 09, 2019 10:04 am quote
You could spit the cases if you want the actual kick lever for a Sprint....or get the curved one for the the P.
https://www.sip-scootershop.com/en/products/kickstart+lever+vbb+style+_75122000
Tue Apr 09, 2019 10:11 am quote
Damn, looks like bump starting until you get a lever. Hopefully you don't live at the bottom of a hill.
Tue Apr 09, 2019 10:30 am quote
Oh that one, yeah I considered it but I dont want to wait, i just got a P one that should be here friday.
Tue Apr 09, 2019 2:56 pm quote
So i took this 'free' exhaust off and attached it to the flange first then used a jack to push it up so i could the the bolt through the swingarm. I was able to get it up a little more on the flange doing this but It's still spitting a little oil...but less now
my main concern is there is a bit of sideways pressure on the flange now....potential problem? could this bit of sideways pressure cause the cylinder to flex under high speed/heat and cause a soft seize?
Tue Apr 09, 2019 3:06 pm quote
Sadly youre not special with the exhaust pulling a bit. The quality control on exhausts is pretty low. My last 3 performance exhausts have all had something wrong with them. I think my last stock exhaust fit better than my $400 one.
And no sideways pressure on the exhaust flange wont warp your cylinder. Youíd need tons of pressure or something ridiculous to warp things enough for a seize. Break in correctly, jet accordingly and watch for air leaks. That will keep you from seizing.
Tue Apr 09, 2019 3:13 pm quote
the two exhausts that came with my stella were impossible to fit up flush on the exhaust stud of the cylinder. I sold the simonini and replaced the other one with a sip road xl. Surprisingly the sip road xl fit perfectly up to the cylinder head! It still leaks a bit of oil at the connection point.
Tue Apr 09, 2019 3:27 pm quote
okay thanks guys.
She running good, knock on wood.
Tue Apr 09, 2019 4:06 pm quote
what oil do yall use? i bought a bottle of this and have been using it but i dont like how its not blue...it doesnt change the color of the gas so sometimes im like....did i remember to mix this gas?
Tue Apr 09, 2019 4:20 pm quote
I've been using Motul 710. It's green: https://www.amazon.com/gp/product/B00C739LTY/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
edit: then again, im on automix stella. not sure if it's the appropriate oil for premix.
Tue Apr 09, 2019 4:27 pm quote
You should get in the habit of adding oil to the tank every time you add gas.
Tue Apr 09, 2019 6:40 pm quote
Damn good tip!
Tue Apr 09, 2019 6:43 pm quote
swiss1939 wrote:
It's green
so am I so this is a match made in heaven lol.... purchased!
Wed Apr 10, 2019 2:33 pm quote
What makes a vespa transmission change gears on its on under hard load?
[ Time: 0.2320s ][ Queries: 25 (0.0727s) ][ Debug on ]
