"Too high fuel consumption." |
Post Reply Forum -> MP3 Discussion |
Author | Message |
![]() 2019 MP3 hpe 500 sport Advanced " Missy "
Posts: 288 Location: West Germany |
![]() Hello out there in Impie land. I have a problem with my Matilda. She has been drinking way too much latley. Instead of getting at least 250 Kilometers to the Tank of Gas. I am getting only 150 to the Tank. I am kind of at a stalemate at the moment. Does anyone have an idea what might be causing Matilda's sudden bout of thirst. All imput would be hihgly appriciated. Thanks
![]() I have never done 250 km on one tank.
I usually do 160-180 km before the light comes "on" on the dashboard. The maximum I have ever done on 1 tank is 240 km. If you were doing 250 km on a regular basis on 1 tank...consider yourself lucky ![]() Clean the air filter, change the spark plugs, check the tires pressure, check the transmission to see if you can get back to your old mileage. |
![]() " Too high fuel consumption."
reticulum wrote: I have never done 250 km on one tank. I usually do 160-180 km before the light comes "on" on the dashboard. The maximum I have ever done on 1 tank is 240 km. If you were doing 250 km on a regular basis on 1 tank...consider yourself lucky ![]() Clean the air filter, change the spark plugs, check the tires pressure, check the transmission to see if you can get back to your old mileage. |
![]() ![]() 2016 MP3/500 Sport ABS, 2009 MP3/250, 2012 GTS Super 300ie
Posts: 4295 Location: Marietta, GA |
![]() Re: "Too high fuel consumption."
Hillbilly Fred wrote: Hello out there in Impie land. I have a problem with my Matilda. She has been drinking way too much latley. Instead of getting at least 250 Kilometers to the Tank of Gas. I am getting only 150 to the Tank. I am kind of at a stalemate at the moment. Does anyone have an idea what might be causing Matilda's sudden bout of thirst. All imput would be hihgly appriciated. Thanks What I have observed, the Fuel Mileage Killer is the Air Filter. Dirty, or maybe to much oil absorption... Some people put way to much oil on the Air Filter after replacing. Keith, Marietta, GA |
klaborde wrote: Hillbilly Fred wrote: Hello out there in Impie land. I have a problem with my Matilda. She has been drinking way too much latley. Instead of getting at least 250 Kilometers to the Tank of Gas. I am getting only 150 to the Tank. I am kind of at a stalemate at the moment. Does anyone have an idea what might be causing Matilda's sudden bout of thirst. All imput would be hihgly appriciated. Thanks What I have observed, the Fuel Mileage Killer is the Air Filter. Dirty, or maybe to much oil absorption... Some people put way to much oil on the Air Filter after replacing. Keith, Marietta, GA |
![]() ![]() 2008 MP3 500, 2013 BV350, 2020 Vespa Sei Giorni
Posts: 8716 Location: Ashburn, Va. Home to the Internet |
![]() I lke Piaggio recommendation, mix 50/50 filter oil and gas. Soak the filter in the mixture, squeeze the excess out and let air dry.
![]() WEB-Tech wrote: I lke Piaggio recommendation, mix 50/50 filter oil and gas. Soak the filter in the mixture, squeeze the excess out and let air dry. |
![]() ![]() The Hornet (GT200, aka Love Bug) and 'Dimples' - a GTS 300
Posts: 39324 Location: Pleasant Hill, CA |
![]() reticulum wrote: WEB-Tech wrote: I lke Piaggio recommendation, mix 50/50 filter oil and gas. Soak the filter in the mixture, squeeze the excess out and let air dry. ![]() |
![]() Sticky crap.
Actually I bought the oil over amazon. It was cheaper than buying it from the Dealer,but it`s sticky as hell and it gets all over and can also be hard to clean off. Well I guess you Live and Learn. I`ll never buy that crap again
![]() Re: Sticky crap.
Hillbilly Fred wrote: Actually I bought the oil over amazon. It was cheaper than buying it from the Dealer,but it`s sticky as hell and it gets all over and can also be hard to clean off. Well I guess you Live and Learn. I`ll never buy that crap again ![]() ![]() It is sticky because it is acting as a filter and collects more dirt than standard oil would. You are using the right product in the wrong way. Delute to a 50/50 mix oil and gas, soak, ring out, let dry. |
WEB-Tech wrote: Hillbilly Fred wrote: Actually I bought the oil over amazon. It was cheaper than buying it from the Dealer,but it`s sticky as hell and it gets all over and can also be hard to clean off. Well I guess you Live and Learn. I`ll never buy that crap again ![]() ![]() It is sticky because it is acting as a filter and collects more dirt than standard oil would. You are using the right product in the wrong way. Delute to a 50/50 mix oil and gas, soak, ring out, let dry. |
![]() I have K&N Air Filters in all my 4 Wheeler's.
So I use the same Air Filter Oil (Redish Looking), and mix with Gas and Soak and dry as explained earlier. I didn't buy anything special for the MP3's / GTS. I can remember years ago, I was riding with a friend who had a GTV/300. He was stopping for Gas way to much compared to my MP3/250 at the time. We opened the Air Filter, and it was a mess of Goo... He over did the Oil. Keith, Marietta, GA |
![]() Just the plain Rotella 5W-40 engine oil and gas here.
Dirty filter goes in a zip-lock bag with some gas - squish it about to clean it. Squeeze out the dirty gas, dispose of the remainder from the bag. Add some clean oil and gas (~50:50) to the bag, squish the filter around in it, remove it and squeeze out any excess then allow the remaining gas component to evaporate. Good for another 6000 miles if the air quality is 'normal' and not too dusty. |
![]() I used to be riding the fucco 2009 and now mp3 16.the old ride could go til 310km per tank and now its like only 240km til empty.
I was told the new ride is alot heavier and got bigger throtttle body. Really hated the range. Going to build an aux tank in the trunk! |
![]() echris108 wrote: I used to be riding the fucco 2009 and now mp3 16.the old ride could go til 310km per tank and now its like only 240km til empty. I was told the new ride is alot heavier and got bigger throtttle body. Really hated the range. Going to build an aux tank in the trunk! Keith, Marietta, GA |
![]() The eco mode didnt get much better and the riding feel sucks.i ride 50/50 city n high way.
![]() You really make me think that there is something wrong with my scooter from the beginning.
I ride on ECO 95% of the time and I have a very smooth riding. I'm 185 pounds and have a 2016 MP3 500. The maximum distance I did on 1 tank is 152 US miles which is 243 Km. I was getting 55 miles/US gallons. When you are mentioning doing 310 km on 1 tank it is about 193 US miles. Even my MP3 250cc was not able to do such distance on 1 tank. How do you do such distance on a 500cc ? Last edited by reticulum on Wed May 01, 2019 7:12 am; edited 2 times in total |
![]() Isn't 55 MPG what the MP3 500 is rated for?
It was for my 2008 MP3 500 |
![]() ![]() MP3 500, GTS 250 (both 2008 MY), 2012 Honda NC700 DCT, 2014 Can Am Spyder RT
Posts: 6331 Location: Madison, Wisconsin |
![]() WEB-Tech wrote: Isn't 55 MPG what the MP3 500 is rated for? It was for my 2008 MP3 500 See below.... |
![]() I did 310 km to a tank.that means that the tank is til almost empty.
That was on the fuccuo model .forgotten which year exactly was it. |
![]() Who cares about fuel mileage. Twist the throttle, have fun, and enjoy the ride. I know that I get about 220km on a full tank. I am hard on the throttle and enjoy the ride.
![]() new200guy wrote: Who cares about fuel mileage. |
![]() Great meeting you today. Hopefully air filter, or my suggestion of O2 sensor, solves your problem. Bridgestone Battlax tires are great. Very sticky but not a wet weather tire by any means. Have to drop my speed by about 15km/h in the wet.
![]() new200guy wrote: Great meeting you today. Hopefully air filter, or my suggestion of O2 sensor, solves your problem. Bridgestone Battlax tires are great. Very sticky but not a wet weather tire by any means. Have to drop my speed by about 15km/h in the wet. |
![]() ![]() Neutrino MP3 492.7 AK, 2013 Moto Guzzi Norge
Posts: 21712 Location: Harriman, Tennessee, Tn |
![]() I have used air filter spray for many years.
the trick is hold the can 2 feet away from the filter start spraying 4 inches before the filter and use a sweeping motion across the filter only 2 times like a lite mist of product and only on the outside surface of the filter. Then roll the filter up in a cake roll and unroll let dry in the sun for an hour. |
![]() 50/50 Filter
Hallo fellow Impies. I cleaned my Filter this Weekend and put 50% Filter oil and 50% Gasoline in it. It seems to be working so far. I plan on running a full Tank to see what Mileage I can get. I thank all of you for your advise and I will keep you posted on my progress.
![]() To High Fuel Consumption!
Hello again fellow Impies. Well I took Matilda out for her first good ride today and found that there is very little change to fuel Economy. I think I will the advice of new200guy and have her Lambda checked. I will continue posting my indeavers in the prevention of bad Fuel Economy.
[ Time: 0.1582s ][ Queries: 25 (0.0379s) ][ Debug on ] |
