New battery not charging in bike
2008 MP3 400
Mon May 06, 2019 10:03 am quote
2008 400
What possible parts could have failed and what is the most probable?
I metered across the battery and revved to 5000 with no change in voltage.
All fuses are good.
Mon May 06, 2019 10:12 am quote
30 amp fuse under the seat.
Pull off the engine access panel in the engine compartment, get a flash light and look for a Relay on the right side (Passanger side in the US) mounted in a black rubber mount with battery cable size wires going to it. You can pull the whole thing off the mount and pull the wiring harness off (one clip on each side) and pull the 30 amp fuse that is under the connector and see if it is good. Pull the fuse, don't just test, I made that mistake.
If it is like mine was you will be buying a new relay as mine over heated and melted the fuse.
Mon May 06, 2019 10:13 am quote
All fuses? Including the 'hidden fuse'? The 400 has one, fuse 13 (30A) located on the starter relay.
2008 MP3 400
Mon May 06, 2019 10:32 am quote
I had pulled the 30A fuse; it was good.
Mon May 06, 2019 10:58 am quote
Just checking you didn't check the spare - and that you *did* check the connections of the fuseholder itself to the main terminals. There can be hidden corrrosion inside. BTDTGTTS...
If the starter relay (and its connections) is in good condition then I'd be checking the stator to regulator connector - the big fat brown one with yellow wires into it. Those are notorious for going high resistance and in at least one case setting fire to the bike.
MP3 400
Mon May 06, 2019 11:20 am quote
I had this problem - it was a wire corroded at the regulator. Easy fix
Mon May 06, 2019 11:27 am quote
bet you checked the spare and not the actual fuse.
2008 MP3 400
Mon May 06, 2019 12:49 pm quote
Here is the fuse I pulled and checked.
Is this the 'spare'?
I didn't know there was one.
Mon May 06, 2019 1:06 pm quote
Pull that red connector off, it is under it. Right under where the side clips are.
Mon May 06, 2019 1:53 pm quote
yeah the one you see that visible is the spare. the other is hidden under the connector, that's why its called the "hidden fuse"
2008 MP3 400
Mon May 06, 2019 1:56 pm quote
Well...what a relief!!
Thanks to all of you I'm good again.
Did a rev/voltage test...14.8 @ 5000 rpm.
Gotta love this site...you guys made my day!!
Mon May 06, 2019 2:44 pm quote
glad you up and running again.
Mon May 06, 2019 10:54 pm quote
well done to you all.
Kymco AK550
Tue May 07, 2019 12:09 am quote
That fuse was probably blown because you or somebody else made a mistake while investigating the battery problem. Most likely reversed the polarity or possibly tried to jump start with another bigger vehicle with the engine running.
Your excellent picture clearly shows that it melted though its not so easy to say how quickly. It probably saved your electrics from far more serious damage. But in the very unlikely event that it blows again you will need to look for a bad short circuit.
Tue May 07, 2019 2:06 am quote
Just replace mine, it is a common issue on the MP3 500.
2008 MP3 400
Tue May 07, 2019 6:13 am quote
This post is an (unplanned) continuation of my previous thread
stabilizer lock light flickering with buzzing sound
My bike had died away from home after 50 km of riding. That was how far it went on battery power alone with a disabled charging circuit (unknown to me at the time). I called my wife who picked me up with the dead battery; I charged it at home for a few hours, came back, installed it and rode home.
All this from a quick reverse connection. I've certainly learned my lesson!
Question: What are the issues with getting a boost from a car battery?
Is there a proper way to do it or not?
Dennis
Tue May 07, 2019 7:42 am quote
Jump start is fine, see below. However to boost a bike battery from the car, it's really advisable to remove the bike battery from the bike. Then you can connect it to the car battery and start the car. Half an hour on a car alternator should be quite enough to charge the bike battery.
To jump start:
Do not have the car engine running.
Connect the positive lead first. Double-check it's on the right terminals...
Connect the negative of the car battery to the frame of the bike.
Start bike.
Remove negative lead first.
Remove positive lead last.
Rallies Europe 2016   Vespa Wasp Pin Badges   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.2190s ][ Queries: 27 (0.0460s) ][ Debug on ]
