Tilt lock gremlin
MP3 500 Sport
Sun May 12, 2019 4:12 am quote
Hello 3 wheeler friends.
My 2015 MP3 500 has developed an issue with the tilt lock.
I can activate and de-activate the tilt lock using the handlebar switch but not when I sit on the saddle and twist the throttle. The red tilt lock light warning stays on when I sit on the saddle and the warning light does go out when I deactivate the tilt lock via the switch.
I purchased a second hand saddle after being assured that the seat occupancy sensor was working but after swapping the saddles this has not cured the problem.
Has anyone else on here experienced a similar problem and identified a solution? I would be grateful to hear.
Happy ridings .
Sun May 12, 2019 9:01 am quote
check the cable and plug
MP3 500 Sport
Sun May 12, 2019 12:08 pm quote
Thanks 🙏🏻 for the tip will do that
MP3 500 sport abs 2014
Sun Jun 02, 2019 10:39 pm quote
hi
i have my MP3 in bits so no seat so i used a 3.3k ohm resistor with the two wires pushed in the connector plug
if you want a resistor i have some extra i can post one to you
MP3 500 Sport
Sun Jun 02, 2019 11:58 pm quote
Thanks so much 🙏
Hiya.
Thanks so much itís now fixed. there were some broken wires where the connector was. Should have looked there in the first place as I went and bought a second hand seat thinking itís the seat sensor.
[ Time: 0.1361s ][ Queries: 23 (0.0299s) ][ Debug on ]
