250GTS - Malossi pulley kit
250 GTS
Sun Jun 09, 2019 11:41 pm quote
HI Guys ,
a quick intro-
thanks for accepting me joining .
Rory from Wilderness SA
54 years old , ride mostly ADV riding and Dirt bikes.
Enjoy rebuilding bikes / working on them .
My 250 GTS is 8 years old , so i figures time to change the drive belt .
got a Malossi kit but need your advise please .
if i do speeds over 110 /120 km /h there is a smell of hot rubber (think the belt is rubbing somewhere ?
or drive pulley is pushing belt out too much ?
any ideas ?
thanks , and have a cool week .
Mon Jun 10, 2019 12:07 am quote
Fudmucker is in Pretoria and has a GTS. If it helps.
Go well.
250 GTS
Mon Jun 10, 2019 1:14 am quote
Thanks , ill PM him and ask .
have a good one .
Sponsor
Granturismo 218
Mon Jun 10, 2019 6:30 am quote
If it's coming from the variator area, open it up. Something is definitely wrong, and you need to figure out what it is right away.
250 GTS
Mon Jun 10, 2019 7:01 am quote
yip
the variator is squeezing to far closed and the belt is rubbing against the motor casing .
i put the lighter weights in and its a completely different bike - really CRAP .
bike reves at 9500 rpm , no acceleration or top speed .
there is a spacer washer between the two halves of the variator that if i put in a thicker one ....... should solve this ?
250 GTS
Mon Jun 10, 2019 7:04 am quote
sorry -
to add -
going to replace the 15g weights
the 14 gram weights take the problem away ........ but cant live with the bike like that ....only slightly faster than my honda GROM .
250 GTS
Mon Jun 10, 2019 1:57 pm quote
HI Guys,
my belt is obviously climbing out running too high on the variator ,
i will have to shim it to stop thr two halves squeezing too close together .
a use full link below
thanks for all the input .
Sponsor
Granturismo 218
Tue Jun 11, 2019 5:41 am quote
Did you change the spring in the clutch?
What belt are you using?
250 GTS
Wed Jun 12, 2019 10:04 pm quote
HI ,
yip , spring was changed , (included in the Malossi kit ) and yesterday 15 gram rollers were put back in , after trying the 14 g rollers.
15 g hold the rpm right in its torque peak .(6000-6500)
The 14 Gram are not worth trying . revs are way too high (9000- 9500 rpm )
resulting in lower acceleration and lower top speed.
the STD set up is even lower rpm and not as smooth variator action as the Malossi
using an OEM belt .
I spoke to a mate that has the same GTS250 and he also has the problem of belt slightly rubbing when riding it hard at 130kph or over .
Also a smell of hot rubber when riding a long distance at high speeds .
So... will stay with it as it is now and not hammer it over 120 kph.
have a cool day .
regards
Rory
Wed Jun 12, 2019 10:12 pm quote
Just curious. Are you using a different counter spring. With Malossi and smoke and mirrors it comes with a white spring.
Maybe why the recommended 14 doesn't work for you.
[ Time: 0.2691s ][ Queries: 27 (0.0798s) ][ Debug on ]
