So I had some screwy stuff happen with my 6v stator and since I have this 12v stuff lying around I want to slap it on to see if that was my issue. The thing is the stator plate had only holes drilled no abilitie to adjust left to right. Do I make the holes larger and what position do I mount it? Also what will happen if you slight scrape one of the coils on the stator? Thanks
If you can get it to make spark and juice for the lites mounted on those holes, you can put a timing lite on it, figure out where it's at then drill new or elongate the old holes to get where you wanna be.
Should work, I have elongated the slots when putting a random stator on a random motor to get the timing moved enough, but have not seen just holes before.
All Content Copyright 2005-2019 by Modern Vespa. All Rights Reserved.
