VIN Help!
Not sure
Thu Jun 13, 2019 5:01 pm quote
I am trying to identify my Vespa. I bought this from someone who said they imported in from Germany. There was a plate that had the VIN.
The VIN says its a VBC Super 150. However, the Engine VIN says the bike is a VLA 150 GL.
I can't find the frame VIN underneath the frame cowl.
Thoughts?
Not sure
Thu Jun 13, 2019 5:03 pm quote
Additional picture
Where on here should the VIN be?
1980 P200E , 2005 Stella 177
Not sure
Thu Jun 13, 2019 5:15 pm quote
VIN Location
I think this picture tells me where to find it. My left side cowl is only removable after I unscrew 4 nuts. The engine VIN matched where I thought it should be based on this picture.
Thu Jun 13, 2019 5:34 pm quote
Hey Aerona - welcome to MV!
Here is a pic of mine. It's a 1962 though. Hmmm. Looks different than yours. Maybe under layers of paint?
1962 Allstate Cruisaire
Not sure
Thu Jun 13, 2019 5:37 pm quote
Help
Scott,
That is certainly helpful. Yes, it has been repainted. I will have to remove some paint perhaps.
I guess I'm just trying to solve the issue before I start restoring it. I need to figure out what I've got my hands on.
Aaron
Thu Jun 13, 2019 5:47 pm quote
Re: Help
aerona87 wrote:
Scott,
Aaron
Again I'm not sure cause I've never seen an old one like that in person but if they are to be the same, comparing the images, looks like your frame was cut and shaped with an upward curve more like the px frame in that area. If you compare the cross indent to the bottom of panel you will notice this because the side panel on yours doesn't go as far down as qa's and his is a straight line, not upward curve. So looks like your frame number was chopped off, either due to rust or due to something potentially nefarious. It does look from some of your photos that beneath the paint could be some rust bubbles or pitting, which could be why they chopped it below.
But someone with more experience here should confirm.
Thu Jun 13, 2019 5:54 pm quote
Welcome aerona.
Hate to be the bearer of bad news, but someone snipped a bunch of metal off the bottom of the frame including the part where the vin is stamped.
It looks like there’s about six layers of paint and a bucket of bondo on there. What’s underneath is anyone’s guess.
If you post a few pictures of the whole bike, I’m sure the folks on here will be able to better identify it.
Thu Jun 13, 2019 5:57 pm quote
EDIT: I'm with SoCalGuy. It looks like the frame has been trimmed. Sorry man - what a bummer.
I forgot to mention. Maybe check on the engine side, on the body next to the bottom edge behind the engine. Like on a 70's P. Who knows....
Maybe here? Who knows...
Thu Jun 13, 2019 5:58 pm quote
SoCalGuy wrote:
Welcome aerona.
That serial plate also looks suspiciously clean and new compared to the bubbling and pitting suggested below the layers of paint in the first image.
1974VLB 1979VSX 1974V9A
Thu Jun 13, 2019 6:04 pm quote
Let’s see the rest of this scooter.
Thu Jun 13, 2019 6:53 pm quote
A Super should have the number on the opposite side, near the rear cowl pin.
Just noticed the plate says "gesamtgewicht" (total weight) - 240kg!!! Something odd going on there, maybe the plate was added to make it look legit? Actual total weight should be less than 100kg.
Thu Jun 13, 2019 8:13 pm quote
Bajaj CDI and 12 volt regulator. Probably Indian / Pakistani restoration. Plate is probably generic. German type plates where rectangular from 55 - 61 and oval from 62 - 67. “Vespa GmbH Augsburg” was imprinted on all of them...
Not sure
Thu Jun 13, 2019 8:26 pm quote
Well, I guess it's all troubling to say the least. Here is a picture of the whole thing. The engine is a VLA.
What should I sell it as? How much? Engine still has compression and there is spark. Gas tank needs cleaned out for it to be a runner.
bare metal cafe racer
Thu Jun 13, 2019 11:38 pm quote
It’s total gross weight - so plus passengers and fuel etc...
https://en.m.wikipedia.org/wiki/Gross_vehicle_weight_rating
Thu Jun 13, 2019 11:43 pm quote
Isn’t that a German VIN? Maybe a motor swap in the past. Doesn’t look sea bodge imo.
Thu Jun 13, 2019 11:47 pm quote
Remember Germans like to mod.
Thu Jun 13, 2019 11:54 pm quote
My vbb doesn’t have a number stamped into the frame. Has a rounded rectangle of aluminum riveted on the rhs with 5 numbers. A lot depends on where they were made. I think my frame number style makes mine a Douglas Sportique. So actually imported from the UK. There was local production of Vespas in New Zealand - Airco. The import laws meant they had to make a certain % and assemble in NZ. Seats, racks, fairings...
Not sure
Fri Jun 14, 2019 2:45 am quote
Good to know. Maybe it's not as bad as I thought.
Not sure
Fri Jun 14, 2019 2:56 am quote
One question though, it's running on 10inch wheels. Super's had 8inch wheels. The VLA 150GL had 10 inch wheels. Is it possible to throw 10inch wheels on a Super frame?
Not sure
Fri Jun 14, 2019 2:59 am quote
Thanks for the info. That is oddly specific knowledge that you have. Is there a reference for that?
I'm trying to figure out how legit this is. Is it worth restoring in your opinion? I'm up for a project.
Not sure
Fri Jun 14, 2019 3:01 am quote
The 12volt system was put on by the guy who I bought it from.
I don't see Vespa GmbH Augsburg printed on my Vespa anywhere. Is that good news?
Fri Jun 14, 2019 3:17 am quote
Bought off Craigslist? Think I've seen this ad before.
Fri Jun 14, 2019 5:47 am quote
Looks like you got a bag of tricks there aerona87, but it looks pretty solid. Maybe take a look here for one possible solution: How to Guide- Apply for a Vermont plate
Numbers stamped into the frame and/or aluminum number plate???
As mentioned it's probably where it was made but I think also where it was sold. I checked 2 bikes with both and only the plate includes the max total weight limit which seems to be required in Germany and likely elsewhere. The white PX125 shows a limit of 250Kg and it's in English, numbers match the frame. My tuff little red German market '91 PK ups the ante w/ 290Kg , displayed in German on the plate which also matches the frame stamp and bonus decal.
240/250Kg for a largeframe but 290Kg on a smallframe? What's up with that?
So back on topic, did any bikes come with *only* the aluminum plate?
Not sure
Fri Jun 14, 2019 6:13 am quote
Is it worth the effort to restore? The engine is in good condition. It came with a title based on the Aluminum Plate.
Fri Jun 14, 2019 6:24 am quote
Tough question. How much time and/or money are you willing to put into it?
Not sure
Fri Jun 14, 2019 6:53 am quote
Well, I'm more than okay making a project out of it. I just want to make sure its legit. The guy before me put a few hundred miles on it. Just trying to make sure its not a Viet-bodge.
Fri Jun 14, 2019 7:14 am quote
It depends upon what you're definition of "restore" is. Some people think that a restore is installing new whitewall tires and rattle can painting over the existing rusty paint. If you wanted to restore by definition...you would need to do something about all the rust pitting that is going on. Also the front fender looks to be cut down as well, so you'll need a new one of those. The left cowl has some sort of "infinity" glovebox (there's no bottom to it), so you're have to fix that (maybe it was cut out to fit that [redacted] pipe?) You should also weld back the missing material where the VIN is usually located.
Sometimes restoring isn't worth it, and it's better to just get the engine in tip top shape, and enjoy riding it around for what it is.
Fri Jun 14, 2019 7:21 am quote
If by “legit” you mean “is it a Vespa?”, yes I’d say that’s a fair statement... if you mean “is it original,” no not even close.
Hard to tell from just three pics, but my guess is it spent some time in Asia (legshield glovebox). The pitting under the thick paint is a sign of some serious rust issues. It’s never a good sign when you see painted over bolts.
Might be worth the effort to get it running. Be careful before you get on it and start riding though. The only way to really tell what you have is to strip it all down.
Fri Jun 14, 2019 8:08 am quote
I'd probably go forward based on the one pic, but more pics would let us see if there are any problem areas that could kill any encouragement. You do have some rust going on, but hard to tell how deep. Look inside the tunnel with one of those little cameras or a penlite & small mirror. Get pics if you can.
If you have legit paperwork that matches the numbers and there's no serious cancer or severe bodgery, why not?
Not sure
Fri Jun 14, 2019 9:01 am quote
Voodoo, thats the sanity check I need from you guys. I appreciate it.
Body work is certainly an issue. I have looked at places that do acid dipping or media blasting.
I plan on doing the engine work myself.
In the tunnel
Underneath
In the glovebox
Underneath gas tank
Under front mud guard
Rear holes
Not sure
Fri Jun 14, 2019 9:04 am quote
A few more pictures. They were too big and had to resize.
Fri Jun 14, 2019 1:06 pm quote
This one isn't too encouraging. Can you pick at that scab so we can see what's underneath?
Fri Jun 14, 2019 1:19 pm quote
Since i'm a fan of the P series, i can appreciate the plastic rear P mud flap.
Fri Jun 14, 2019 1:20 pm quote
[quote="aerona87"]
The 'issue' is a culture clash. Three of them. German, American - and SEA got dragged in to the discussion as well. This bike has been modified - you know this. Likely in Germany - that's what they do. Unlikely in SEA (IMO) - as the modifications done there are bodgey and fairly typical/easy to spot. But now the bike is in the States and the culture there tends to favour US bikes restored to original specs.
IMO the hardest part to achieve is done - it has a title (despite a weird frame number). What do you want from the bike? A solid classic ride? A perfect original spec super? If the later is your goal then walk away.
How clean do you want the frame? Like panel and paint tidy? Cause that is where the biggest cost/time will be. Can't see any rust bad enough to need welding - need to check under the floor, but looks like the paint is coming away from superficial rust (rather than proper rot).
Do you like the colour?
If so... clean it, then Penetrol the crap out of it (inside and out). Done.
If not... then acid dip it and figure how to panel and paint from there. Time and $$$.
From what I'm seeing this bike looks pretty sweet. Yes 10" on a super is a done thing. Many would argue a good thing for stability and looks better (but others counter argue 8" are original, and many like the look and agility).
I think the odds are you did ok.
Fri Jun 14, 2019 1:28 pm quote
One last thing.. that little circular stamp on the frame. I've heard that it isn't seen on SEA bikes/bodges (Vietnamese anyway). I don't know how true that is... but FWIW.
P125x (P200 Motor)
Fri Jun 14, 2019 1:30 pm quote
[quote="pheasant plucker"]
I agree. It really depends on what you want out of it. You appear not to be afraid of some work, so it really depends on your expectations.
My 81 P125X is a certified 1 owner, but rusty. It looks about the same as yours overall, and my plan is to make it structurally sound, mechanically strong, and look nice. I'm not worried about a full restoration, but it will get fully striped, repaired and repainted. First Scooter, not my first project.
Not sure
Fri Jun 14, 2019 1:44 pm quote
I tried attacking it but it won't budge. I'm sure there is a bit of filler but it's not coming lose. Here's another picture of the area underneath the Vespa. It's a little up close.
Fri Jun 14, 2019 1:54 pm quote
Time to get out the coarse sandpaper and a block. Sooner or later it's going to have to be addressed. Rusty hole or poorly patched dent?
Fri Jun 14, 2019 2:33 pm quote
That’s really the question. If you’re just planning to putt up and down the street occasionally, it might be a fun project. If you’re looking for daily transportation or hoping to put serious mileage on it, go on tours and trips, etc. I’d think twice.
The glove box, the mismatched frame & engine, the chopped off vin, the inch thick cracking bondo/paint, the ripples, and rust pits all scream sketchy. I see $$$ and headaches downstream, but if you’re willing to take it on, go for it! There are a lot worse ways to spend your time.
[ Time: 0.1938s ][ Queries: 27 (0.0360s) ][ Debug on ]
