GT/GTS Brake Upgrade
Post Reply    Forum -> Project Reports Previous12
GTS 250
Tue Jan 02, 2018 11:15 am quote
I found a good photo of the MP3 caliper carrier
GTS 250
Tue Jan 02, 2018 12:44 pm quote
This also looks like a 240mm disc, with a Frando F101 caliper
Sat Jan 06, 2018 12:17 pm quote
That disk looks like it may even be larger than 240, if those are 13" rims.
I got the MP3 caliper mount in the mail, but they sent the wrong side, grrr
GTS 250
Sun Jan 07, 2018 8:04 am quote
Does it look like it will work (if it was mirrored)?
GTS 250
GTS 250
GTS 250
Tue Jan 30, 2018 11:40 am quote
AnnDee4444 wrote:
The front caliper carrier on a MP3 looks very similar to the GTS... any chance this would be a direct swap for the larger disc & caliper? I can't seem to find any good photos of one.
Sort of answering my own question:
The MP3 caliper carrier (part # 2B0006085) will more than likely fit on a GTS, however the brake caliper bolts are at an angle (compared to the shock mount) and meant for non-floating calipers (rear GTS & front LX). I'm not confident that a 240mm disc with a non-floating caliper is an upgrade over a 220mm disc with a floating caliper.
I don't own an LX, but swapping to the MP3 carrier/disc(and caliper?) would be a way to use a 240mm disc on the front (with a 12" wheel). Stoppies anyone?
GTS 250
Sun Aug 19, 2018 8:55 pm quote
Sorry to bring this thread back from the dead, but I saw that the MP3 now has 258mm wavy rotors. 13" wheels are probably required for clearance.
https://www.cycleworld.com/2019-piaggio-mp3-500-sport-refines-three-wheels
Mon Aug 20, 2018 2:00 am quote
Interesting and nice!
Looks like they may be using the rear GT caliper to space it out by 10mm. Did the same on my LX to go from a 200 to 220 disk.
Here's the current MP3 caliper from the top of this page:
And a close up from the new MP3:
note the gap between the caliper and bracket
GTS 250
Mon Aug 20, 2018 6:46 am quote
Good catch! This should be a pretty simple upgrade for older MP3 owners. I also think it means that the 258mm rotors would work on a LX with the MP3 caliper carrier (and 13" wheels).
oopsclunkthud: Did you ever get the correct side MP3 caliper carrier?
Any idea how to determine if one of these 258mm non-floating caliper setups would be better than the stock GTS?
GTS 250
Mon Aug 20, 2018 8:52 am quote
I wonder how far off this bracket would be: https://www.sip-scootershop.com/en/products/adaptor+malossi+for+oversize_m189800
GTS 250
Fri Nov 16, 2018 7:20 pm quote
Here's a comparison of different caliper carriers. The MP3 caliper is definitely spaced further out from the axle.
Left to right: GTS ESS, LX, MP3
GTS 250
Sat Dec 22, 2018 6:46 am quote
SIP now offers a radial adapter & caliper kit for up to a 250mm disc (or 260mm?). The caliper is 4 piston @ 24mm each. https://www.sip-scootershop.com/en/products/brake+kit+sip+radial+front+_mvbrk002
There's even a kit for the rear: https://www.sip-scootershop.com/en/products/brake+kit+sip+radial+rear+_mvbrk004
GTS 250
Thu Dec 27, 2018 2:28 pm quote
SIP also now sells a complete caliper carrier conversion.
https://vespaforum.de/viewtopic.php?f=17&t=48005&sid=dd466792a3974a60dbd60f8777834ecf
GTS 250
Mon Feb 04, 2019 10:09 pm quote
I can confirm that the Aprilia SR-Max 300/Gilera Nexus 300 rear caliper does NOT fit with a 13" wheel. The SR-Max/Nexus both had 240mm rear disc, and the same rear caliper as the GTS front caliper (with an adapter bracket 649162)
Mon Feb 04, 2019 11:15 pm quote
funny, I've been trying to see if I can go to a smaller disk on the rear, like the 200mm from the LX front.
GTS 250
Tue Feb 05, 2019 2:29 pm quote
Yeah, there's no OEM small 5-hole rear hub that I know of either. Re-drilling should be possible though.
Just out of curiosity, do you want a smaller rear brake so that you can run a smaller wheel? This might be useful for Scomaldi type swaps.
Tue Feb 05, 2019 4:41 pm quote
wanted to do a smaller disk for less weight and don't really need more stopping force in the rear anyhow.
I think the hot setup for a scomaldi would be to base it on the 200 and use the lx gear case. gets the 10in wheel and a shorter wheelbase
Vespa T5 Mk.1, GTS218ie
Thu Jun 06, 2019 5:43 am quote
Hello All,
There is a very simple brake update for the GTS, if running 13" wheels, which cost about 170 (190/$215) depending on taxes, etc.
This will give you a 250mm front disc, standard caliper and use sintered pads.
not full Brembo, but cost effective for servicing and not overkill.
Parts have been available for a while:
BRAKING adapter bracket - POW44
MALOSSI (Galfer) brake disc - 6217150
The parts were designed by different suppliers to put bigger brakes on the Gilera Runner earlier performance 50, 125/180 models, but will fit the GTS.
Based on Oops previous calculations the increased disc diameter, combined with better pads and the LX master cylinder may give a real OEM+ brake upgrade, even with a 240mm disc.
I have the bracket and a machines late Piaggio MP3 front disc (258mm machines to 250mm) for the OEM+ look and I'm awaiting a quote from a reputable brake system manufacturer for some 250mm discs, other than the Malossi ones.
Additionally, I'm looking at getting a similar bracket CNC'd for a 240mm disc on the GTS for general fitment on 12 or 13" wheels.
In theory, the proposed bracket would allow the use of the normal 240mm MP3 disc on the GTS front, but also allow the Late 300-500 MP3 258mm disc to be used on the Gilera Runner ST models (which currently runs a 240mm disc.
GTS 250
Mon Jun 10, 2019 10:58 am quote
That open window in the bracket is a bad idea as most the force is in shear.
Mon Jun 10, 2019 11:42 pm quote
The bracket is quite heavy duty and machined not pressed.
Mon Jun 24, 2019 3:18 am quote
Additional brake upgrades - Rear
Hello All,
In addition to my ideas on available parts for cheap/simple OEM+ brake upgrades, I have just discovered a brake caliper bracket for the rear of the Leader/Quasar engine to allow 240mm brake discs (Gilera Runner ST /MP3 front) on the rear of the Vespa GT/GTS or any other which previously use the 220mm.
This would be a simple plug and play, bolt on disc and bracket. the part is used on the Giler DNA 125/180 machines and is part number 597326, I have a new one on order, so once I get chance I will add the pics of the 250mm front set up and 240mm rear.
GTS 250
Mon Jun 24, 2019 9:52 am quote
Re: Additional brake upgrades - Rear
lennymbsc wrote:
Hello All,
Any photos?
Mon Jul 22, 2019 11:37 pm quote
Sorry for the delay, been travelling for work and had to get some time in the garage.
So the front, the caliper bracket needed a little dressing as the disc bolts were fouling slightly on the back of the bracket (where the disc bolt heads pass) needed dressing as the material is quite thick.
But the brakes fit nice under the 13" rims and I just need to bleed the brake up (as used a recon'd caliper).
I haven't fitted the LX master yet a will see ho this feels first.
Mon Jul 22, 2019 11:39 pm quote
extra pics
Mon Jul 22, 2019 11:41 pm quote
more pics
Mon Jul 22, 2019 11:42 pm quote
Not sure whats happened with the forum, but I cant submit multiple pictuires and cant submit on my mobile phone, get Invalid errors ?
GTS 250
Tue Jul 23, 2019 1:32 pm quote
Do you know the part number of the rotor, or which bike it came from?
Sun Jul 28, 2019 1:07 am quote
The inital set up was done with an MP3 258mm rotor, which I had machines down to 250mm for the set up. There is a Malossi disc which will go straight on (and save grinding the bracket to cleat the disc bolts, as has counter sunk screws)
I need to follow up with EBC who were drawing up and quoting on some 250mm VR discs.
GTS 250
Mon Jul 29, 2019 9:16 am quote
Are you concerned with the outer hole's distance to the edge of the rotor? It looks to be very close.
I hope someday a company will make a bracket to use the 258mm rotor and OEM caliper. It seems like it would offer the best low-cost but OEM quality braking improvements.
Wed Jul 31, 2019 11:44 am quote
Hello,
The issue with is contact between the rotor mounting screws (the Malossi rotor has counter sunk ones) and the Braking bracket (as the material is quite thick.
I have dressed the back of the bracket and edges which contact the brake pad ( to ensure pad movement and zero contact with the rotor screw heads.
I also have a set of 250mm VR discs in manufacture at EBC, which work out at 45 each. I will need to purchase the MOQ (minimum order quantity) of 10 parts and they will become a purchasable part.
If anyone fancies a 250mm disc, let me know. I can also get the brackets for about 40.
A nice little upgrade.
I'll get the rear brake set up photographed next.
Vespa Sei giorni GTV300
Wed Jul 22, 2020 12:16 pm quote
i did all the front end
[ Time: 0.1881s ][ Queries: 27 (0.0411s) ][ Debug on ]
