How to adjust the air mixture scre on px200 disk?
Owned Vespa Rally 200, V90, Li150 series II...now a PX200
Fri Jul 05, 2019 8:40 pm quote
When my bike is at idle and I blip it, it bogs a little, so I'm thinking I need to adjust my air mixture screw? It runs fine otherwise.
It's the type that sticks out and you adjust it with a 7mm wrench.
The thing is I can't reach the screw because the starter motor is in the way. Any special tools to get in there?
Sat Jul 06, 2019 11:02 am quote
I had the same problem with my 2005 PX150. I bought a pair of 11 inch pliers with the tip bent at 45 degrees. This tool works fine.
https://www.homedepot.com/p/TEKTON-11-in-Long-Reach-45-Degree-Bent-Nose-Pliers-34404/206200670
I had the same off-idle bog and turning my idle mixture screw counterclockwise just a half turn solved the problem.
PX200, Moto Guzzi V7 Cafe Classic
Sat Jul 06, 2019 1:09 pm quote
Seen pictures on here of spanners bent at an angle to get in there. Probably stuck in a vice, heated and bent over.
Sat Jul 06, 2019 10:44 pm quote
Lots of options, been discussed lots of times.
Here's one idea, use search for others.
Sat Jul 06, 2019 11:41 pm quote
I always use the search function first. With all things vespa, things change. I thought maybe after a while someone would have come up with a proper tool.
Thanks for the help and picture though
[ Time: 0.1495s ][ Queries: 27 (0.0311s) ][ Debug on ]
