CVT - Is this black wheel necessary? |
Post Reply Forum -> MP3 Discussion |
Author | Message |
![]() I wonder why Piaggio place that wheel between the variator and the clutch. I think it the couse of a slight buzz when the belt's lower lobs hitting it at some speeds. (mine at 50mph about). I do not see this thing on any CVT transmission like Honda, Yamaha etc. I'm considering removing it and wonder if anyone did that.
![]() ![]() GTS 250i.e.
Posts: 1368 Location: Sunshine Coast, Australia |
![]() Thats the belt support roller. It stops the belt hitting the belt, kinda necessary.
![]() GTdespatchcourier wrote: Thats the belt support roller. It stops the belt hitting the belt, kinda necessary. ![]() Here a mix of may CVT scooters whit no one have that thing |
![]() When you come off the throttle there is a chance the belt will come into contact with itself, supposedly.
![]() ![]() The Hornet (GT200, aka Love Bug) and 'Dimples' - a GTS 300
Posts: 37683 Location: Pleasant Hill, CA |
![]() Not just supposedly! When coming off the throttle at full speed, the clutch stays engaged with the belt fully inside the driven pulleys, and the belt can fall to the inside of the variator and driving pulley. With both radii at minimum, the belt can very easily catch against itself - doing damage to the inside teeth.
Remove the idler pulley at your peril. If it 'whirrs' then replace it (easier then just replacing the bearing). |
![]() jimc wrote: Not just supposedly! When coming off the throttle at full speed, the clutch stays engaged with the belt fully inside the driven pulleys, and the belt can fall to the inside of the variator and driving pulley. With both radii at minimum, the belt can very easily catch against itself - doing damage to the inside teeth. Remove the idler pulley at your peril. If it 'whirrs' then replace it (easier then just replacing the bearing). |
![]() Maybe other brands address the problem of 'Belt Whip' by some other means - but my reasoning is that if just 10 cents could be saved by leaving the idler pulley out of the design, then they would have done so.
If you closely examine the circumference of the idler, you will probably see where it has been contacted occasionally by the teeth of the belt. No doubt the outer edge of the belt will also contact the inner surface of the casing during 'Belt Whip', but this is nowhere near as bad as the teeth hitting each other whilst moving at high-speed in opposite directions! Some of those pictures above do seem to have something in the middle of the belt run (other than an idler pulley) to stop the teeth contacting each other during Belt Whip, but as an engineer I can appreciate why a pulley would be a better solution. |
![]() ![]() 2008 MP3 500, 2013 BV350, 2020 Vespa Sei Giorni
Posts: 7579 Location: Ashburn, Va. Home to the Internet |
![]() Duboiz wrote: jimc wrote: Not just supposedly! When coming off the throttle at full speed, the clutch stays engaged with the belt fully inside the driven pulleys, and the belt can fall to the inside of the variator and driving pulley. With both radii at minimum, the belt can very easily catch against itself - doing damage to the inside teeth. Remove the idler pulley at your peril. If it 'whirrs' then replace it (easier then just replacing the bearing). Replace the pulley or replace the bearing in the pulley. |
![]() I guess if you really want to try running with out that idler I would wait till its getting close to new belt time and remove it and go for some rides near to home.
That way if it does cause a problem you won't have to push the bike too far! That said I think that is the same design as say my wife's GTV and don't recall her mentioning any "buzzing sounds". I know the time I have rode her GTV I never noticed anything, but then I usually ride a Sportster or XS650 Yamaha so any thing else is smooth and quite to me! |
![]() I bet the original poster is STILL wondering why piaggio engineers put that pulley there.
I do agree with WEB-tech statement. there are plenty of videos of the CVT running through the gear ranges. from those videos I would say the belt can never slap so much during normal operation to contact itself. or even slap enough to need the center pulley. however what I would like to know is what happens when someone locks the rear brake at speed. that is the only situation where the pulley is likely doing something valuable. is someone finds a video of that post it up. |
![]() Some of those pictures above do seem to have something in the middle of the belt run (other than an idler pulley) to stop the teeth contacting each other during Belt Whip, but as an engineer I can appreciate why a pulley would be a better solution.[/quote]
Those are manual kickstart unit. Nothing to do with the belt |
![]() jerryd wrote: I bet the original poster is STILL wondering why piaggio engineers put that pulley there. I do agree with WEB-tech statement. there are plenty of videos of the CVT running through the gear ranges. from those videos I would say the belt can never slap so much during normal operation to contact itself. or even slap enough to need the center pulley. however what I would like to know is what happens when someone locks the rear brake at speed. that is the only situation where the pulley is likely doing something valuable. is someone finds a video of that post it up. |
![]() 2019 MP3 hpe 500 sport Advanced " Missy "
Posts: 250 Location: West Germany |
![]() Hello fellow impies. If do say so myself, some of those belts look shorter than the mp3 Belt and the longer something is the more flexible it is. That is possibly why the pulley is there
![]() although manufactures do install stuff that is not needed in my opinion, i do think that this roller should be there based on what others have said. besides...weight savings of a pound or two is not worth the test.
![]() ![]() BV350, Primavera 150, Yamaha Zuma 125
Posts: 2884 Location: The Twin Cities of Minneapolis/Saint Paul, Minnesota |
![]() Duboiz wrote: Some of those pictures above do seem to have something in the middle of the belt run (other than an idler pulley) to stop the teeth contacting each other during Belt Whip, but as an engineer I can appreciate why a pulley would be a better solution. Perhaps the kickstart bolt also serves the purpose of keeping the belt separated. If there is no kickstart then maybe a simple peg works as long as there isn't much friction there. Also, could there be a separating piece in the outside half of the belt case? |
![]() ![]() Modded Vespa 2017 GTV 300, BMW 2017 C650GT, Ural 2019 Gear Up
Posts: 5810 Location: Downtown Toronto |
![]() Like others have said. Why the hell would you even think about removing a part that the manufacturer put in to an important part of the bike that has the bits that make the thing move? Damn that just sounds dangerous to me and something that can win you a Darwin Award. It might not be done by many or any other CVT PTW manufacturer but it's also not the same engine. I get that maybe it annoys you but the answer there would be buy a bike that doesn't have it/
![]() ![]() 2016 Vespa GTS300ie abs/asr/ess Settantesimo '70'
Posts: 2247 Location: Starfleet Command, South Eastern HQ, UK |
![]() Well on the GTS bikes it has the same type of pulley, and it works! The pulley on mine has marks on it that indicates the belt is coming into contact with the pulley. From what you say, the noise on yours is being caused by your belt coming into contact with your pulley too. This shows the pulley is working. It's essential. Many CVT transmissions have this type of system.
Strongly recommend you don't remove this pulley because you will get trouble if you do. You don't have to take my word for it, just remove it and you'll soon see what happens! |
![]() Stromrider wrote: Well on the GTS bikes it has the same type of pulley, and it works! The pulley on mine has marks on it that indicates the belt is coming into contact with the pulley. From what you say, the noise on yours is being caused by your belt coming into contact with your pulley too. This shows the pulley is working. It's essential. Many CVT transmissions have this type of system. Strongly recommend you don't remove this pulley because you will get trouble if you do. You don't have to take my word for it, just remove it and you'll soon see what happens! ![]() |
![]() From what I see on this video it's function is to limit the play of the belt that can really oscillate a lot.
At the same time it explains this vibration/noise you have sometimes around 20-30 mph on the 500cc... the belt hitting the free wheel. |
![]() ![]() Neutrino MP3 492.7 AK, 2013 Moto Guzzi Norge
Posts: 21415 Location: Harriman, Tennessee, Tn |
![]() piaggio had a special deal from the manufacture on all those idler wheels so they just threw them in a bunch of scooters, no real reason just cause.
![]() ![]() 2016 MP3/500 Sport ABS, 2009 MP3/250, 2012 GTS Super 300ie
Posts: 4238 Location: Marietta, GA |
![]() Remove it and let us know?
Maybe worth a few bucks on ebay. I know of one person here on MV that had to replace his, so my guess it does get some use. Keith, Marietta, GA |
[ Time: 0.1517s ][ Queries: 25 (0.0291s) ][ Debug on ] |
