GTS Knocked Over...Now Won't Start |
Post Reply Forum -> General Discussion | 12Next |
Author | Message |
![]() Some weenie knocked over the GTS last night. Who cares how. Luckily, no physical damage, but it won't start. The dash lights flash, the fuel pump kicks in, but when I hit the button...nothin'.
![]() ![]() 2018 GTS300 Super Sport - Donatello Vespace
Posts: 1450 Location: Toronto, Ontario Canada |
![]() Bastards! Did you check the oil, gas, etc? Please keep us updated. Thank you.
![]() Soul Surfer wrote: Bastards! Did you check the oil, gas, etc? Please keep us updated. Thank you. It fell on its right side, maybe the kill switch or starter button was damaged? |
![]() I commented on your FB post about this with a GIF but man, how FRUSTRATING!
Hopefully you can get her to kick over. I'm learning more on the mechanics of these machines from the forum here. I hope it's just a simple thing like a flooded line that's easy to clear. Awaiting other posts with helpful suggestions. |
![]() does your model have a safety switch/ tip over switch?
if so it needs to be reset...look in your owners manual also might have vapor lock...open your gas cap to vent |
![]() Mikey007 wrote: does your model have a safety switch/ tip over switch? if so it needs to be reset...look in your owners manual also might have vapor lock...open your gas cap to vent I disconnected the battery for a minute and that didn't work. |
![]() I feel like my blood pressure immediately rose upon seeing that picture! Maybe check to see if the starter relay got knocked loose?
![]() everytimeidom wrote: I feel like my blood pressure immediately rose upon seeing that picture! Maybe check to see if the starter relay got knocked loose? I did check the relay and wiggle it around...no dice. |
![]() We have had a few bikes flopped over. It was due to wind catching the cover and using it like a parachute. My blood pressure goes up every time I look at your picture.
![]() ![]() 2009 LX 150, 2008 GTS 250
Posts: 766 Location: Birmingham, Alabama, USA |
2020 Vespa GTS 300 Touring, 2018 SYM Fiddle III 200i
Posts: 4 Location: Las Vegas, NV |
![]() OP says when he hits the starter button, he gets nothing at all. He didn't mention a starter motor sound but no engagement. So that's not a fuel issue. "Nothing at all" is electrical. Sounds like something important upstream of the starter motor got disconnected. The good news is that it should be a simple and inexpensive fix. Should be easy to diagnose too.
But damn that's a shame what happened. So sorry. Makes me cringe. |
![]() ^^^ this. I betcha it is electrical problem. Kill switch, brake switch, relay, or maybe a simple fuse.
![]() Tierney wrote: ^^^ this. I betcha it is electrical problem. Kill switch, brake switch, relay, or maybe a simple fuse. |
![]() Good man, buy a simple tester if you don't already have one. Still, I'm bummed for you.
![]() ![]() Vespa GTV250:: Et4 150
Posts: 237 Location: Huntington Beach, Ca. |
![]() my heart goes out to you!!!
hope it simple once you get to take a longer look at it !! |
![]() ![]() 2006 GT200L "Lone Star"-Sold, 2006 Yamaha Majesty YP400
Posts: 651 Location: Texas |
![]() Re: GTS Knocked Over...Now Won't Start
Big Daddy SnakeOiler wrote: Some weenie knocked over the GTS last night. Who cares how. Luckily, no physical damage, but it won't start. The dash lights flash, the fuel pump kicks in, but when I hit the button...nothin'. Maybe somebody tried to steal it and the chain jerked them up short... Good luck. |
![]() ![]() 2009 GTV250 (Gone), 2003 Inder trailer, 2001 BMW R1100RT
Posts: 4656 Location: Santa Cruz California |
![]() Big Daddy SnakeOiler wrote: Tierney wrote: ^^^ this. I betcha it is electrical problem. Kill switch, brake switch, relay, or maybe a simple fuse. ![]() Best Miguel |
![]() Most, if not all, Vespa side stands are self retracting so no switch is present.
![]() ![]() 2008 GTS250, 2009 S150, 2017 GTS300Super, 2006 GT200
Posts: 277 Location: Houston |
![]() Always hate to see photos like this. Happy your bike suffered no damage and that you figure out the no start thing quickly!
How do some people live with themselves?? Too bad there’s no camera to see who did it. |
![]() ![]() 2018 GTS 300 Touring Rosso Vignola, 2020 BV 350 Matte Green, 1956 VL3
Posts: 874 Location: Herriman, Utah |
![]() rob g wrote: Too bad there’s no camera to see who did it. |
![]() Check that the battery didn't get knocked loose and that the cables are tight.
![]() NightWing wrote: Check that the battery didn't get knocked loose and that the cables are tight. |
![]() Gotta be the connection to the starter yeah? If there's no action at all when you hit the button?
Reseat connection to spark plug. Are the oil bubbles on airbox full of oil? Did all the gas spill out and evaporate overnight? lol. |
![]() Miguel wrote: Big Daddy SnakeOiler wrote: Tierney wrote: ^^^ this. I betcha it is electrical problem. Kill switch, brake switch, relay, or maybe a simple fuse. ![]() Best Miguel |
![]() Big Daddy SnakeOiler wrote: rob g wrote: Too bad there’s no camera to see who did it. |
![]() Thanks for all your concern and great responses. I haven't really had time to figure out what's going on other than knowing it's an early electrical problem. Maybe a solder broke somewhere.
I'm probably going to have to take it to the shop. |
![]() ![]() 2008 MP3 500, 2013 BV350, 2020 Vespa Sei Giorni
Posts: 8716 Location: Ashburn, Va. Home to the Internet |
![]() Several people have asked if you checked the kill switch and I don't see a post that you replied yes to that question.
![]() WEB-Tech wrote: Several people have asked if you checked the kill switch and I don't see a post that you replied yes to that question. I've been wanting to adjust the throttle play anyway, so it will be worth it to pull it. |
![]() Have you flipped the kill switch on and off a few times?
I doubt it is a broken wire, bet it is something simple. |
![]() hewl35 wrote: We have had a few bikes flopped over. It was due to wind catching the cover and using it like a parachute. My blood pressure goes up every time I look at your picture. OP-do you have a wet cell battery? |
![]() [quote="WEB-Tech"]Have you flipped the kill switch on and off a few times?
Yes, also wiggled everything I could get hold of. Sealed battery. |
![]() [quote="Big Daddy SnakeOiler"]
WEB-Tech wrote: Have you flipped the kill switch on and off a few times? Yes, also wiggled everything I could get hold of. Sealed battery. |
![]() The evap container is full of fuel. Drain it or wait a long time for the fuel to evaporate.
![]() SCTLVR wrote: The evap container is full of fuel. Drain it or wait a long time for the fuel to evaporate. |
![]() SCTLVR wrote: Maybe I should be as blunt as you, but I won't... |
[ Time: 0.1923s ][ Queries: 25 (0.0305s) ][ Debug on ] |
