leak around presure sencer on tiltlock,
Red Mp 3 500
Tue Nov 05, 2019 12:47 am quote
Going to order new one tomorrow, pulled old one, very easy. I've been told to bled it from bottom up but not how to do It, any help would be welcome. also need a spell right, any suggestion would be helpful.
Tue Nov 05, 2019 12:55 pm quote
If you hadn't pulled out the old one you could have just swapped them out real quick and bleed it at the pressure sensor using the tilt lock. Now that you have drained a ll the fluid out of the top half of the system, push it up from the solenoid at the shock with a syringe. I use a 60 or 100 cc
2009 MP3 400
Tue Nov 05, 2019 3:48 pm quote
Go to your local farm supply store and pick up a big 100ml syringe. They're not very expensive. That plus a piece of tubing jammed on the end will let you push fluid in to the bleed nipples. Remember to do the nurse/doctor thing and get the bubbles out first so you're not pushing them in to the line.
You can get most of the bubbles out, attach to the bleeder and then suck a little fluid out of the bleeder to get that last bubble, then push it in.
[ Time: 0.1262s ][ Queries: 23 (0.0181s) ][ Debug on ]
