Should LX have ground lead from frame to belt cover?
Tue Jan 14, 2020 7:59 pm quote
My GT200 has a ground connection from the forward bolt of the belt cover to the frame just above.
My LX150 (also Leader engine) does not have this pigtail. I am wondering if it is missing? If there is no ground connection here, can someone tell me where it is / should be on the LX?
(I am chasing down an intermittent stalling issue, and wondering if it's a bad ground. I measure continuity between the frame and engine with an Ohm meter. But if I am missing a solid connection, I am thinking maybe that could lead to intermittent problems.)
Sponsor
Granturismo 218
Tue Jan 14, 2020 11:10 pm quote
Usually if you have a bad ground to the engine, the starter motor will barely turn the engine over when you try to start it.
An easy way to find out if you have a ground to the engine problem is to run a wire from the negative terminal to the engine. You can attach it to the same place it attaches on the GT, leave it on and ride around a bit. If the problem is gone, that was your problem.
Wed Jan 15, 2020 6:23 am quote
There are no electrical components in the transmission so I doubt the wire is part of the electrical ground. I'd guess that it's there to prevent the belt from becoming a Van de Graaff generator; to prevent build-up of static electricity.
Thu Jan 16, 2020 3:00 am quote
No trouble starting it, so maybe grounding is not the problem here. I was just struck by the difference with my GT.
Good tip on a test method - I think I will try that anyways. Thanks.
Thu Jan 16, 2020 3:02 am quote
I think it would amount to the same thing? The transmission is of course electrically connected to the main block since it's all metal?
Rallies Europe 2016   Vespa Wasp Pin Badges   Cool Ass scooter seat cover
[ Time: 0.1763s ][ Queries: 25 (0.0528s) ][ Debug on ]
