Best, fastest, easiest way to remove rust from chrome. Video
Tue Jan 14, 2020 5:04 pm quote
Rust on your scoot? The absolutely the best,fastest and cheapest way to remove surface rust from chrome. Two different ways shown here.
(In case your browser hates you) www.youtube.com/watch?v=RCB6QGpQZDc
Tue Jan 14, 2020 6:56 pm quote
Steel wool will work well on hard chrome, not the cheap stuff. I use a little oil rather that water on the pad. It keeps the rust away a little longer and the pad won't rust away quick. Works for me.
Wed Jan 15, 2020 8:06 am quote
What type of oil Tierney?
Wed Jan 15, 2020 8:22 am quote
A piece of aluminum foil works well on removing surface rust and will not scratch the surface.
Yamaha Tricity 155 Urban 2019 - MV Agusta 125 RS 1956 - Moto Guzzi Airone 250 Sport 1951
Wed Jan 15, 2020 9:39 am quote
It is better to specify, there are products that simply polish and there are others that are also abrasive and are used to remove the rust spots: the first can be used with vigorously rubbing with a cloth while the second needs a rotating polishing disc.
To protect the chrome parts i give a brush stroke of vaseline oil (... for industrial use ... ), it seems strange but it works.
Wed Jan 15, 2020 12:25 pm quote
The 1001st use of the 1001 uses for Vaseline, obviously.
Wed Jan 15, 2020 1:09 pm quote
When he says steel wool will not scratch your chrome finish heís not entirely correct. There are many different Iíll call grades of chrome plating thatís possible, and steel wool can scratch it. A 40-year-old motorcycle handlebar can handle the steel wall better than something from the past couple of years, due to the more stringent more recent environmental regulations on the use of chrome plating. Thatís why todayís chrome plating isnít as good as plating from long ago.
Steel wool DID scratch the finish on the chrome muffler of a BMW motorcycle of mine when I was trying to remove a melted plastic bag from it.
Wed Jan 15, 2020 1:11 pm quote
Never Dull works without scratching.
Wed Jan 15, 2020 3:42 pm quote
What grade steel wool did you use? Iíve never had any issue with #0000 grade (which I call for in the video). Anything more coarse and you may be right.
LX190, Primavera
Wed Jan 15, 2020 10:55 pm quote
[quote="Jet Peddler"]
+1
0000 from the furniture shop is great for waxing wood too.
Thu Jan 16, 2020 12:35 pm quote
Coke and steel wool does a great job of removing rust.
300 GTV
Thu Jan 16, 2020 3:03 pm quote
I use #00000 Steel Wool and WD-40. It works great on all but the most rusted chrome.
Thu Jan 16, 2020 5:19 pm quote
Yeah, once the rust has eaten through the chrome and has reached the underlying metal, most all hope is gone for the ol' steel wool.
Fri Jan 17, 2020 3:37 am quote
I canít swear it was 0000. It may have been 000 but nothing coarser.
Fri Jan 17, 2020 8:58 am quote
Another vote for Never Dull wadding polish. works well and after a final wipe with a clean cloth, it leaves a slight amount of oil on the surface to protect.
I use it a couple times a year on my chrome bars and that's all that is needed.
[ Time: 0.1484s ][ Queries: 25 (0.0340s) ][ Debug on ]
