piaggio 500 in scomadi 50
300 gts
Fri Jan 24, 2020 11:47 pm quote
New project , Just to see if it can be done really, seems to going pretty good, got some frame reinforcments to make as yet, but up to know things are looking workable.
Gilera Runner 500cc.
Sat Jan 25, 2020 10:55 am quote
Go for it!
If you want a dual front disk, but not a verry expensive 13 inch front wheel.
Or a big 16 inch Beverly wheel.
You can also use a 14 inch Peugeot Satelis 500 front wheel.
Piaggio delivered the Master engine to Peugeot, and they installed it on the Satelis.
The rear wheel of the satelis is also 14 inch.
300 gts
Sat Jan 25, 2020 10:58 pm quote
front wheel
Front forks wont take a bigger wheel, however a mte has a twin front disc specially designed for scomadi race scoots.
300 gts
Sat Jan 25, 2020 11:15 pm quote
Mounts on
engine mounts now fitted and tensioner bar almost ready to be fitted.
300 gts
Sat Jan 25, 2020 11:17 pm quote
loop tried
all fits nicley under the loop
Sun Jan 26, 2020 3:32 am quote
Cool!
300 gts
Sun Jan 26, 2020 11:46 pm quote
engine all mounted
engine mounts are now fitted, i still have a little fabrication to do as yet . will post more as i go.
Vespa Gt 200 '03
Mon Jan 27, 2020 4:37 am quote
incredible crazy and funny
go go go and please keep taking pictures
thank you
Kawasaki Z1000, Yamaha R1, Honda SH300i, Gilera DNA180
Mon Jan 27, 2020 5:11 am quote
Top stuff
Mon Jan 27, 2020 5:34 am quote
Just a question.
why don't you use a Scomadi TL125, and convert that to a 500cc.
Then you can get that registered as a heavy bike, because it already is a small bike.
This way it is road legal.
Here in the Netherlands that is the way to go.
Don't know exact how it works in your country.....
300 gts
Mon Jan 27, 2020 8:20 am quote
125
A tl 125 frame and a tl 50 frame are exactly the same, the difference between a tl 125 scooter and a tl 50 scooter is about £1,200. plus the 50cc scooter has twin shock mounts and the tl125 only has 1. most of the bigger engines use 2 shocks, not a mono shock, so for me a 50cc is a no brainer.
Mon Jan 27, 2020 8:34 am quote
Re: 125
But never road legal then?
In holland you cant go from a 50cc to a 125 or more.
From a 125cc to more is possible and legal.
300 gts
Fri Jan 31, 2020 10:19 pm quote
Road Legal
I have converted many 50cc into 300,s all have been registered with no problems what so ever, ive built a 400 burgman based scomadi , and several lambretta series 2 with gts engines also fitted. The last lambretta done was adapted for a guy who only has one arm, so hydraulic rear brake lhs throttle and switches etc.
Extreme mod
300 gts
Sun Feb 02, 2020 10:38 pm quote
fabrication near the end
most of the fabrication is done now, just mounts for regulator ecu etc. I have a small problem with the throttle body catching the frame work, I have ordered a mp3 500 intake which is made from alloy, so it can be cut and welded.
piaggio hexagon
Wed Feb 19, 2020 11:34 am quote
Very impressive work.
300 gts
Tue Mar 17, 2020 10:18 pm quote
resumed work.
Had to put the 500 on hold while i built a lambretta auto for some one, but back on it again now. been busy modding parts to work in this frame, ie the throttle body was catching the frame,and being made from hard rubber could not be altered, i found an alloy mp3 one which allowed me to cut shape and weld.
300 gts
Tue Mar 17, 2020 10:20 pm quote
Tank
i have also modded the alloy fuel tank,and put a tunnel in it so the throttle body is clear of it, also welded a threaded ring in it for the fuel pump. will post some more pics when ive fitted it.
Tue Mar 17, 2020 11:04 pm quote
Derby. Must be a RR man?
300 gts
Wed Mar 18, 2020 10:12 pm quote
RR Man
I am self employed builder, this is my hobby.
Thu Mar 19, 2020 5:11 am quote
Do like your work
300 gts
Thu Mar 19, 2020 7:39 am quote
My work
Many thanks, i enjoy it, keeps me out the way of the grankids.lol
300 gts
Thu Mar 19, 2020 9:59 pm quote
Fuel tank
Fuel tank is ready to be fitted now, As you cure one problem another occures lol, i need to mod the battery box so it still fits.
Thu Mar 19, 2020 11:17 pm quote
I am using a mutch smaller Lifepo 4 battery for my build.
And you can mount it any way you want.
300 gts
Fri Mar 20, 2020 8:15 am quote
Battery
I could use a lion but no need i still have room fro a mottobat i have to move it to the rhs slightly , If need be i cold mount in the toolbox also, but thanks any way.
skipper st125
Sun Mar 22, 2020 4:51 am quote
I like to read and look at your projects.
Great work as ever.
Robbie
Vespa GTS 150 3v SUPER. Vespa V100 x 1. Lambretta Li150 x 1. Px 125 x 2. Px 200 x 1 (red bull special) T5 Classic x 1. Vespa Cosa x 2.CF moto 650mt
Tue Mar 24, 2020 10:24 pm quote
Quality....
Amazing skills and abilities. Can't wait to see the finished result. Kudos to you having the balls to take on such a project.
Rallies Europe 2016   Vespa Wasp Pin Badges   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1731s ][ Queries: 27 (0.0383s) ][ Debug on ]
