Setup 2007 Stella with DR177 DR 177, Sito +, 22 Tooth Clutch
Post Reply    Forum -> Not-So-Modern Previous12345Next
2007 Stella 150
Sat Feb 01, 2020 6:35 am quote
jocco wrote:
swa45 wrote:
Most of the reading/research that I did several years ago suggested that a 60mm crank is not a good companion for the DR177 kit. Maybe try a 1.5mm head gasket instead, or 0.5mm base and 1.0mm head.
Thanks for the reply Swa45, I considered adding a thicker head gasket, but then what do I do about the squish?
I know some metal needs to be taken off either the head or the cylinder, but will this be wise to do, cause I dont think there is a lot of meat on either?
I think Jack is referring to removing material from under the cylinder by using a thinner packer of 0.5mm. This will lower your timing numbers and leave the top of the piston protruding above the top of the cylinder by 0.7mm if my math is correct. Giving you exhaust and transfer timings of around 168 / 122.
This should also lower your squish if it is as high as mine and others here, but still greater than 1.0mm with no gasket.
The top of the top ring in my kit is 3.2mm from the top of the piston, even with 0.7mm sticking out of the top, the top ring still isn't going to be above the top of the cylinder.
Sun Feb 02, 2020 8:06 am quote
Wow, thanks for the all the help guys.
And thank you Christopher for clearing out a few things.
I never thought that its OK for the piston to be protruding a little from the cylinder, I always thought that was bad.
I can work with this new info now. will take new measurement tonight.
Nice job on on the porting Christopher, I think I went a little too far with opening the cylinder. Now I'm also considering cutting the piston so it fits the openings on the cylinder.
Also has anyone other then Geekspeed drilled a DR177 piston?
First measurements
went through :). lucky i used some JBWeld
To cut, or not to cut the piston?
Was thinking drilling a hole here on both sides
2007 Stella 150
Sun Feb 02, 2020 9:47 am quote
It'll be interesting to see what someone says about cutting the side of the piston. Mine looks like yours but I didn't open up the piston opening, wasn't sure what that would do to the structural integrity. If I find out people are opening it up I'll open mine up.
My parts are sitting while I wait on my new piston rings, SIP was out, but rings are back in stock and shipped I hope.
If you do have some piston sticking up, make sure you measure the head squish band inner diameter, to make sure you have clearance for the piston. My squish band diameter is only 60mm ID. A 63mm piston will not fit into that spot. That is where you will need a head gasket with a 63mm or slightly larger ID to offset the 0.7mm you'll have protruding from the top. Make sure you fit the head gasket so it won't interfere with the piston with the play you'll have on the four studs.
Then that will get you back to having a larger squish band than you'll want most likely. Then you'll need to do like I did and take some material off the head.
I have the calipers set at 63mm and you can see they are wider than the squish band area.
Tue Feb 04, 2020 5:28 am quote
Did some measurements on the DR I'm working on.
The squish is between 2.1mm and 2.22mm
Looks like the piston will fit :)
Got lucky. All I need now is to find some aluminium to cut a base gasket
2007 Stella 150
Tue Feb 04, 2020 5:49 am quote
DR177 Cutting Side Skirt Opening Wider to Match Port
I never heard back from SWA on what his results were with cutting the side skirt to match the port opening in the projects forum. He may not have seen it, sent him a PM asking about it.
Your large squish measurements are similar to mine, removing 1mm will get you down to a better squish.
Tue Feb 04, 2020 7:25 am quote
Oops, sorry I missed that PM. I used a Pinasco Magny Cours base gasket as a template to port the crankcase, then matched the DR cylinder base ie. I removed the 'shelf' on the other side of the gates. This resulted in the cylinder spigot windows opening up considerably to follow the shape of the transfers, so I matched the piston windows accordingly. Did this part make much difference to performance? Not sure. The kit served me well with a stock DR piston (modified), a set of Grand Sport rings and a Polini 177 head (tighter squish), but the engine now runs a BGM 177.
P Series / Li / LML / Motobi
Tue Feb 04, 2020 9:44 am quote
Re: DR177 Cutting Side Skirt Opening Wider to Match Port
I have cut many a piston on the skirt to get a good match, as long as you round the edges and corners you will be fine. as to drilling the piston, again i have done this many times in the past to allow some cool gases to wash over the cylinder wall - in line with the barrel studs - to reduce the risk of heat seizure.
Honda elite
Tue Feb 04, 2020 10:11 am quote
Interested to know more about this. My apologies in advance my intention is not to hyjack but learn more about adding a hole to the piston.
In my recent seizure I'm noticing two polished area's on the cylinder wall about the size of a US dime. Both spots are on each side of the exhaust on the stud path. In my case it looks like the piston seized on the clutch side exhaust stud. Is there more heat retention and less air cooling here? The seizure did not occur directly over the polish spot but next to it closer to exhaust port. The opposite side has no damage just a polish spot.
Was wondering if a hole on the clutch side stud path might be an option? Just one or both sides of exhaust?
two dark area's on each side of exhaust port after 800 miles in line with cylinder studs
2007 Stella 150
Tue Feb 04, 2020 2:13 pm quote
Thank you for the update, I read your old projects thread and had a few ideas from that. With my LML case, I opened up the cylinder, to match the transfer ports in the LML case. The LML transfer ports with reeds, appear to be a lot larger than the Vespa PX transfer ports, from pictures I've seen. The only port I enlarged in the Stella case was the boost port or middle port by a few millimeters to match the DR177 boost port. My Stella case had a 23mm port and the DR177 cylinder had a 25 mm port. Going to open up the cylinder skirt also now, while I have it apart since others haven't had issues with it.
Going to keep my SI 20/20 carburetor for now, I have a venturi setup for it and would like to give that a try. I have seen mixed reviews about using a SI 24/24, and will save that for when I get bored, and want to see if it helps my setup with the way I use it. I'm mainly worried about highway riding at the moment. If I find I spend a lot of time at wide open throttle then I will give an SI 24 24 a try.
2007 Stella 150
Tue Feb 04, 2020 3:01 pm quote
I would be nervous about that tight of a fit. My cylinder head could move 0.3mm to one side when bolted to the cylinder. Id be tempted to use a rotary tool with a sanding drum and open that up a bit more. How much I have no idea without studying it for awhile.
Tue Feb 04, 2020 3:53 pm quote
I've opened up DR pistons pretty extensively and never had a failure from it. I always open the port gates, then match the piston to those. I'll also add extra porting to the piston on a Malossi to allow additional cooling and that's never blown up on me (yet), either.
As noted above, just make sure the corners are rounded and you're not cutting into the reinforcing webs on the interior of the piston and you'll be fine.
2007 Stella 150
Tue Feb 04, 2020 5:16 pm quote
Pictures of Bottom Side of DR 177 Piston
This is what the bottom side of my piston looks like. Should I open it up or leave it?
Looking at the area that would be coming off, kind of gives an idea of I go straight down.
Tue Feb 04, 2020 6:02 pm quote
I'd open it up.
I did similar work to the Polini on my SprintV here and on a DR here.
Thu Feb 06, 2020 4:45 am quote
O.P.
YES open it up. just make sure as mentioned above, it is smooth and rounded rounding off the sharp edges actually "adds" strength back to where the metal was removed
Hijacker
Drill all sides of the piston in line with the studs - you can additionally notch an "x" into the hole to allow 2-stroke to "grab" in the grooves. a 2mm hole should be sufficient - then deburr and lightly countersink the hole (spinning a drill bit backwards by hand should be enough to clear and counter the hole
2007 Stella 150
Wed Feb 12, 2020 4:18 pm quote
Rings Finally Came In
I have two sets of rings now, measured the ring end gaps in each set. The GS for a Polini piston end gap is 0.009" or 0.23 mm. The DR set is 0.10" or 0.25mm. Going to be installing the GS set, better looking finish and a tighter fit.
2007 Stella 150
Wed Feb 12, 2020 4:33 pm quote
DRT Air Box Spacer and Hitting Frame.
What do I do with an air box cover that is hitting the frame, with a DRT spacer installed? If it didn't look terrible, I would adjust the box corner with a ball peen hammer. Might look better than trying to cut the corner off with a Dremel. Eventually I want to fit a venturi, after I get the air filter close.
Also a few pictures in case anyone is having trouble finding pictures.
Wed Feb 12, 2020 6:54 pm quote
Depending on how much and where the airbox is hitting the frame, you may be able to resolve it by:
1. Replacing the rear engine rubber mount
2. Replacing the top rear shock mount
3. Using a longer rear shock spacer
Look at those before you start pounding on the airbox or the frame.
Wed Feb 12, 2020 8:34 pm quote
Since it's just a Stella, take a hammer to it. Yes, a shock spacer will give you the extra clearance...until you hit a bump in the road. There's very little room to work in there in the first place, and that spacer will no doubt cause fouling out issues with the frame. Just make sure that you don't pound the frame into the shock spring. I'd at least remove the carb box before i started hammering away at it though. A rubber mallet would be leave less visible witness marks than a steel hammer though. If you do need that much clearance, i would just cut the sheetmetal then.
Wed Feb 12, 2020 11:43 pm quote
Why is keeping the stock filter so important?
2007 Stella 150
Thu Feb 13, 2020 3:50 am quote
I don't have to keep the stock air filter, I would eventually like to remove it in favor of a venturi or T5 air filter. That is why I was looking for ideas on how to fit a spacer for a bit more room. I'm under the impression there not a lot of room in there and a bit more room helps with the venturi and air flow.
Only keeping the stock air filter, until things warm up outside. That way I can get a few miles on her to make sure she running fine. Then go to a venturi up jet and start to dial her in better.
2007 Stella 150
Mon Feb 17, 2020 5:11 pm quote
Would you grind a piston up like this?
Freaky sent me a few pictures of his pistons, this one is a DR piston. Would you grind around the pin like this? I'm hesitant to do it, I can't wrap my brain around grinding that center section down and moving that much more mixture. The transfer ports in a LML motor are pretty big. I opened up my piston skirt back to the web and stopped.
I'm basically to the point I'm going to put copper sealant on my parts and put it back together. Trying to decide whether to grind it or leave it.
Then I'm on to the clutch.
Tue Feb 18, 2020 12:20 am quote
If you can be bothered yes but lots of other parts have to be adjusted well for it to make any noticable difference.
Wed Feb 19, 2020 4:20 pm quote
Wow, nice pics you got there Christopher.
I was planning to do something similar to the DR Im working on, this piston is still less grinded around the pun then a stock malossi 166 piston.
2007 Stella 150
Sun Feb 23, 2020 1:52 pm quote
It lives
Put the top end back on, wanted to see if she would start. Started up with a Little choke and seems to run fine again.
Now to figure out how to upload a video of link to youtube.
https://youtu.be/rGBErf3kzzs
Checked the cranking compression and it's 148 psi, I was told something around 140 psi is good for pump gas. Not sure if that will go up as the rings seat themselves with use. Top end fit isn't as tight as it could be either, the ring end gap is well within tolerance, but not so tight that I had to take anything off a new set of rings. The side gap for the piston to cylinder wall is also on the medium side. It does rev better to 5500 rpm with the 1mm base plate spacer and ported exhaust port. Didn't want to rev it to much with new rings until they seat.
Next up is going to be the clutch, I have a DRT 23 tooth gear to install. I know it should be to high of a gear, but it works on a Stella Fireball with a factory 150 cylinder. I Want to see why it grabs figure if I need parts I want to get them on order while it is still cold here. Once it warms up I want to be ready for tuning and riding.
2007 Stella 150
Mon Feb 24, 2020 5:46 am quote
My list of changes so far
To help me keep track, of changes I've done so far, will add to as I go along.
The day I test drove it and brought it home it was cold below freezing. I rode it wide open in 4th and couldn't get over 50 MPH or 80 KPH.
Boyesen Reeds
Cut the center support out of the reed block
Blended the parts in the carburetor reed block stack to flow better
55/160 Idle Jet 160, Be3, 110 main jet
Drilled heart in air filter
Cleaned up carburetor, installed new gaskets, drilled hole from fuel bowl to main jet to 2.0 MM and blew out all openings with compressed air.
Started and ran on center stand at this point, to cold and snow on the ground didn't do anything else. Since it still seemed to run fine on the stand I moved on to other projects
Opened up the DR cylinder base, two large ports on the side to match the LML case openings.
Opened up the LML third small port in the case from 20 mm to 25 mm to match DR cylinder.
Cleaned up exhaust port and moved it up 0.50 mm, on accident mostly just material removed to clean up casting around port.
Reduced squish from 2.77+ mm to what should be 1 MM by removing material from head. With the shape of the DR head it is hard to measure squish, with no real squish band.
Installed a 1.0 mm base gasket to set squish at 1.00 mm and increasing port timings.
Started and ran on center stand at this point, to cold and snow on the ground still, didn't do anything else. Since it still seemed to run fine on the stand I'm moving on to the clutch.
I have a 23 tooth gear the same as the Stella Fireball mentioned earlier in this post, to install while inspecting what I have for a clutch.
TO do at some point:
I have a kytronix waiting to be installed.
I would like to establish Top Dead Center and timing marks and install a Kytronik. Looks like I can install it set it to "0" initially make sure it works and set it to a conservative 6. I like the idea if having a timing curve the same as vehicles have had since the early 1900's. After I get things dialed in better I can push the limits more on the timing, I figure a conservative something should e better than nothing.
https://www.kytronik.com/collections/kytronik/products/smart-booster2016-2
Last edited by Christopher_55934 on Mon Feb 24, 2020 8:03 am; edited 2 times in total
Honda elite
Mon Feb 24, 2020 6:48 am quote
When the snow melts try doing some WOT tests in 2nd gear. Get a large main jet and find the point where it's too rich, find that first. It will be sputtery but clear out if it's still too lean when it's sputtery up into the high rev then you can stop and begin working back down. The main jet and since you have drilled the supply to 2mm has an effect on fuel supply to the pilot and you'll start dialing that in. The atomiser can be dialed for the transition from pilot to main. Also plug chops will help.
Yesterday I read something on adjusting the air fuel screw on the let's talk atomiser thread. I found this very useful: copied and pasted from jamesjohn 6/20/2013
To set the mixture screw correctly, here's what you need to do :
Start the scooter and go for a 1-2km run to warm the engine up.
1. With the engine running on the stand, take the engine side panel off. Turn the idle speed right up, the long screw with the flathead screwdriver fitting that pokes out of the carb box top, turn clockwise in.
The engine will be racing now!
2. Immediately turn the mixture screw on the back of the carb all the way in, the engine will get choppy and the idle will drop. On PX200 models it will require an 7mm spanner, there's not much room in there.
3. Immediately then turn out the mixture screw from closed in 1/4 turn increments, the idle will increase and the engine will start to smooth out. Take a few seconds wait between each 1/4 turn out. Count the number of turns as you open the fuel screw out.
4. You'll get to a point where the the engine will have smoothed out and the idle stops increasing when you turn out the mixture screw. This is close to where it should be set.
5. Adjust the idle speed back down to an acceptable running level. Then listen to your engine when you blip the throttle.
6. If the engine 'bogs' and feels flat when you blip the throttle it is probably set too rich. If the engine 'hunts' and takes more than 2 seconds to come back to a steady idle after blipping the throttle, it is probably too lean. A lean idle that 'hunts' the revs will make a 'pip, pip, pip sound.'
You should be able to blip the throttle, the engine should rev. clean and it shouldn't either bog, or 'hunt out the setting'. It should rev. and return to a good idle within 1-2 seconds.
7. Make a small adjustment here if neccessary. Then adjust the idle speed slightly.
8. On tuned Vespas, if it takes more than 4 complete turns, then pop in a richer idle jet, and repeat. This is the smaller jet on the left. The PX200 runs a standard 160/55 idle jet. The T5 runs a richer 100/50. The richness of the idle jet is the ratio of the two numbers, the lower the number, the richer the idle jet. The 100/50 is 2.0, the 160/55 is 2.9. The 100/50 is therefore richer.
If it takes less than 2 turns on a tuned Vespa, consider popping in a leaner idle jet and repeat.
Mon Feb 24, 2020 11:16 am quote
That 23 tooth clutch will be just fine in 1st through 3rd gear, but in 4th, your power is going to drop off big time...unless you have a slight downhill and tailwind. Just because the Fireball came with an upgear, doesnt mean it was a good thing. Ive played around a bunch with 21, 22, and 23T gears before, and if youre one tooth off, it makes a whole world of difference. I personally think a 22 tooth would be spot on for your build.
2007 Stella 150
Fri Feb 28, 2020 2:07 pm quote
Initial Clutch Inspection
I rode Stella a few times the day I bought her and that was it. I thought the clutch was horrible. I couldn't gently let it out in each gear, felt like I was trying to pop wheelies and the clutch was on or off no real in between. I expected the clutch to look pretty bad when I took it apart, doesn't look bad to me
I did find this washer disc to be completely worn out with a few slivers remaining. There are a few options need to figure out which one to get.
https://www.sip-scootershop.com/en/products/washer+disc+clutch+_59108000
I expected it to be much worse, I think I'm just going to replace what needs replacing for now until I figure out what I'm going to do. I don't have a reference to know if the clutch is normal for a Stella or not. If it is I'm going to get a better clutch.
Anybody have a reference for clutch plate thickness? Going to do some more looking but my Google search didn't turn anything up quickly.
Fri Feb 28, 2020 2:38 pm quote
What sort of shape are the cush drive springs in? If theyre weak or broken, it can cause what your describing.
Fri Feb 28, 2020 3:24 pm quote
Thickness on what? Cork plates or metal plates? I can measure mine for you.
2007 Stella 150
Fri Feb 28, 2020 3:34 pm quote
I haven't split the cases yet to know, I just read about how to take a crush drive apart and inspect it. I was trying to avoid the process of splitting the case halves for now. Sounds like I may end up doing it anyway, or ride it knowing the springs probably need replaced.
2007 Stella 150
Fri Feb 28, 2020 3:37 pm quote
break
Both, I'm used to rebuilding clutch packs and having a specification min and max for each plate and an overall thickness. Sometimes we would buy three or four sets of plates so we could mix and match to get maximum plate and pack thickness. I can't find any of that information so far.
2007 Stella 150
Sat Mar 07, 2020 5:33 pm quote
Clutch Feels A Lot Better
Clutch feels 100% better today, first ride since the day I brought Stella home. Didn't really do a lot to it, that I thought would have fixed the grabbing issue.
Replaced the thin bronze spacer, it was pretty much gone.
Put in new springs, they were cheap and they would fit in the small flat rate box with the shim.
Put in a new plunger, cheap and would fit in the box, it was actually worn a bit, the gap at least was wider then the old by 1mm.
Bought a new Clutch, Bush, Brass Clutch Spacer Bushing, everyone pretty much says replace it your in there. I measured the old and new one and the new one was 0.02mm larger in diameter. I didn't waste the bushing or my time changing it.
New DRT 23 tooth gear, created more play, the original 21 tooth gear, fit tighter. I did slide the new bushing inside the new gear, to check the fit and it wasn't any better.
I did soak the clutch plates in synthetic gear oil, then filled the gear box with 20w50 motorcycle oil. I use it in my motorcycle, so I had some on the shelf.
2007 Stella 150
Sat Mar 07, 2020 5:47 pm quote
Updated Default Jetting
Took her for a few mile ride this afternoon, with vortex installed. Wasn't expecting a 128 main jet, had to move up more than I thought. Glad it brought temperature into check, it is the biggest in the set. Rev'd to 7650 rpm, 1,2 and 3rd temperature got to about 300F or 148C. Might be a bit on the cool side, but that's ok until I get an air / fuel mixture gauge installed. Would like to see a peak around 325F, a day warmer than 45F will most likely bring it up a bit.
SI 20.20
55/160 idle
160 AC
BE3 mixer
128 main jet
2007 Stella 150
Wed Mar 11, 2020 6:13 pm quote
Kytronik establishing a baseline
With safe temperatures, next I should install my Kytronix. What minimum and maximum timing should I aim for? 23 or 24? How about retarded timing degrees 16, 17 or 18? So start at 24 and retard 6 to 18? Start at 23 and retard 6 to 17? 24 retarded to 16? I would think 18 is a compromise for high and low rpm and loads.
Hopefully I'll get the baseline timing done then I can get the jetting dialed in better. Didn't want to spend to much time on jetting until I have timing at least started. Figure changing timing will change fuel burn rate etc so off would change jetting.
Wed Mar 11, 2020 7:47 pm quote
Double check your temps on a long run to make sure first. As Jack says, 300F all day on highway should be where you are at.
Wed Mar 11, 2020 8:55 pm quote
As Swiss said. Once the jetting is stable at 300F max, even after 10 miles at WOT, then the set up can move to the next step. The 20/20 came with an AC140. I would put this back in quite urgently.
Kytronic at 24 degrees and curve 2 is a very safe place to start and can be easily switched up to much stronger curves, without taking the flywheel off.
2007 Stella 150
Thu Mar 12, 2020 2:37 am quote
I can put the 140 AC back in no problem, the jetting was stock from what I remember with a slightly larger main jet when I changed them out. Is the idea here to richen her up a bit? Which should in theory mean I can use a smaller main jet or what I'm currently using will be closer to what I need?
Dont worry, I'm going to continue to keep an eye on the temperature while adjusting the jets, and timing. The runs were only a few miles at higher speeds to coincide with the eye watering low temperatures.
Last edited by Christopher_55934 on Thu Mar 12, 2020 9:01 am; edited 2 times in total
Thu Mar 12, 2020 7:26 am quote
Id definitely stay on the richer side. With the Vortex installed thats leaning you out a ton and the weather will be warming up so Im sure that will affect cylinder temps. Im about to throw one on my PX project with a 24/24 carb and I was told by a reputable shop to start with a 140 main jet.
As far as the timing goes, Ive had good luck going 24-17. No difference going 18 but definitely no less than 17*. Ive got the latest one installed on my touring P with the smart spark booster thing added in. I dont know if the Kytronic does anything to your burn temperatures but you may have to jet for that.
2007 Stella 150
Thu Mar 12, 2020 3:14 pm quote
Re: Updated Default Jetting
SI 20.20
55/160 idle
160 AC
BE3 mixer
128 main jet
Put the 140 AC back in, put my full face helmet on and went for a ride to a small town 6 miles away on a back rode. She seemed to be breaking up a bit more at lower rpms while accelerating, but still didn't stutter at wide open throttle in second or third. I could pull the choke and she didn't stutter or miss. Temperature never got above 280F. The odd thing is on the way home about 10 miles into the round trip, I think she was getting hot, and may have started to seize. She shut down back tire didn't lock up, but she wasn't running, I pulled the clutch in, pulled the choke out, popped the clutch and she started up again.
Need to do two things one is get a wide open throttle plug chop, second is get my air fuel ratio meter here and installed.
This is on its way, need to locate where I want to mount the sensor temporarily while tuning. I bought one of those temporary clamps from AEM to use. Figure I can weld the hole shut later or just put a plug in the clamp sensor hole. My Sito plus is 1.75 inches OD from the exhaust stub to the inlet to the chamber.
https://www.aemelectronics.com/products/wideband-uego-air-fuel-controllers/no-weld-o2-sensor-mounts
https://www.plxdevices.com/SM-AFR-Gen4-Wideband-AFR-with-MultiGauge-Link-p/897346002870.htm[/url]
[ Time: 0.2019s ][ Queries: 27 (0.0378s) ][ Debug on ]
