2007 Mp3 250 fuel pump install
mp3 250
Sun Jan 26, 2020 11:57 am quote
Install new pump for MP3 250 help
Sun Jan 26, 2020 11:48 pm quote
Follow instructions in the factory service manual
Mon Jan 27, 2020 6:27 am quote
Re: 2007 Mp3 250 fuel pump install
Here's the location of the Manuals.
I have changed before on the MP3/250, the difficulty is getting all the Body Panels off to get to it. Installing the New Pump, not that hard.
https://manuals.wotmeworry.org.uk/Piaggio/Piaggio%20MP3/MP3%20250/
Keith,
Marietta, GA
mp3 250
Mon Jan 27, 2020 10:40 am quote
Thanks Keith for the follow up.
MP3 250 & T Max
Sun Feb 23, 2020 6:42 pm quote
Keith,I am echoing Mike in needing help.
Winston-my 2007 MP3 250- cranked over beautifully-as usual-this morning but no response from engine. Plug 'dry'.
Pulled the plug-big fat spark, removed top left relay, checked ok ( also swapped to be sure). Still dead motor. Can't see any leaks around fuel lines. Suspect the fuel pump. Are there any other checks I should do prior to strewing plastic everywhere?
I was hoping to order a pump-if required-prior to removing the suspect one but note that during 2007 pumps came in 1 & 2 hose variations. Is this important- and any recommendations on 'after market' pumps.
As per the Service ManualI page 311 the part No: for 'Item 7 is #004073 is this relevant?
Thanks.
Sun Feb 23, 2020 10:10 pm quote
There was a recall on many of the '07 - '09 250s regarding the fuel pump. It would be worth checking to see if your bike is covered and/or if the replacement had already been done. Any dealer can tell you if you give them your VIN number.
Mon Feb 24, 2020 12:14 pm quote
If you can hear the fuel pump 'whirr' for a couple of seconds upon first switch-on, then you know the fuel pump is working. If you can't, and the 'injection loads relay' is working (a multimeter or test light will tell you) then a new fuel pump is the answer. But check your VIN for the recall!
MP3 250 & T Max
Mon Feb 24, 2020 7:18 pm quote
Thank you fellow enthusiasts,
Electrics check out ok, but no 'whirr'. Will see if agents have any info re years and recall. But I'm not holding my breath.
Next is availability and price
Ciao.
[ Time: 0.2431s ][ Queries: 25 (0.0528s) ][ Debug on ]
