malossi variator + dr pulley sliders
VESPA GTS 300SUPERSPORT
Sun Apr 26, 2020 4:36 am quote
Hi i own a Vespa gts 300 super. I have an akrapovic sxhaust and Malossi Variator, Recentrly i have replaced malossi sliders with dr pulley 15g (weight)
It seema to be faster in acceleration, but so far i did not have the chance to drive out the city in a highway to check final spped.
Before this change i had 135-140 km/h top speed (depending weather)
I am not sure if the sliders weight is the correct, what i an looking for is top speed
Any suggestion how to play with sliders in order to gain some top speed km?
Sponsor
Granturismo 218
Sun Apr 26, 2020 8:12 am quote
Try different ones and see which ones make the bike faster where you live and ride. There is no correct size for all conditions.
Sun Apr 26, 2020 9:18 am quote
Heavier or lighter at least any idea?? I am willing to go lighter .. thanx anyway
Blue GTS300 Super 2015, White GTS300 Super 2018
Sun Apr 26, 2020 2:02 pm quote
When I installed Dr.Pulley sliders in my Polini variator I immediately got belt rubbing and destroyed the crankcase gasket below the variator. The combination made the belt ride too high in the variator. So check your setup for any signs of rubbing. You might need a fatter washer in the variator.
Mike
S 190. Custom VNB 150
Sun Apr 26, 2020 6:23 pm quote
What worked best for me was same weight as stock with the dr pulley. Make sure they are in the right way or you can break things.
Sponsor
Granturismo 218
Mon Apr 27, 2020 7:26 am quote
Mike
That's when you need a heavier contra spring, to keep the variator from pushing the belt that high in the front.
  DoubleGood Vespa T-Shirts
[ Time: 0.1308s ][ Queries: 29 (0.0443s) ][ Debug on ]
