Flat battery: need to open seat. MP3 350, 2017
MP3 350 2018
Sun Aug 02, 2020 9:19 am quote
Hi folks,
I left my MP3 350 2018 model connected to an Optimiser when I traveled. Came home to find it disconnected and the battery flat so, of course, I need to open the seat.
I've searched around but I still haven't found a solution. My ignition key does not push in and rotate anti-clockwise as with some models. Clearly there must be a straightforward way to do this, but I can't find it.
The Optimiser shows 0 volts and 0 amps after three hours, so I need to get to the battery.
Thanks in advance.
Sun Aug 02, 2020 9:55 am quote
Refer to your owner's manual, but the key should open it in the same manner as opening the fuel door flap except you need to turn the key in the other direction
MP3 350 2018
Sun Aug 02, 2020 12:10 pm quote
Thanks for the reply. I'm away from my manual and the key doesn't turn anti-clockwise when pushed in.
Sun Aug 02, 2020 4:40 pm quote
Try fishing up underneath at the side for the cable. Then give it a tug.
Sun Aug 02, 2020 5:49 pm quote
I don't have an MP3 so just guessing here. Is there a lever behind the "glovebox" or leg shield door?
MP3 350 2018
Mon Aug 03, 2020 6:17 am quote
Thanks.
All resolved. I took the junk off the keyring and persevered with pushing and turning.
[ Time: 0.1316s ][ Queries: 25 (0.0301s) ][ Debug on ]
