Can both a 400's front wheels be removed at the same time?
MP3 400 "Merlin"
Tue Sep 08, 2020 7:58 am quote
I apologize if this has been asked before.
Can the 400's front wheels be removed at the same time for tire changes? If so, where's a good jack-up point?
Tue Sep 08, 2020 8:35 am quote
I use a regular automotive floor jack with a piece board on the pad to spread the load a little. Then just lift gently under the fuel tank. Not super stable that way but it gets the job done.
I suppose if you had the right facilities you could hoist it by the handlebars.
MP3 400 "Merlin"
Tue Sep 08, 2020 8:39 am quote
Thank you. We're doing it the one-wheel-at-a-time method but it's a half hour trip one way to transport the wheel to get the new tire mounted and balanced.
Moderatus Rana
MP3 250 (sold) MP3 500 (current)
Wed Sep 09, 2020 6:37 am quote
Another option is to have a spare set of front rims then you can get the new tires mounted and balanced and install them whenever you want to. I do this for the rear to minimize down time.
MP3 400 "Merlin"
Wed Sep 09, 2020 11:25 am quote
That very thought occurred to me during my second trip back to the shop.
Wed Sep 09, 2020 6:36 pm quote
yes you can do a double front removal. need to cut a 4x4 to fit between the axels of each somewhere around 22" , then using a floor jack under the 4x4 carefully lift the complete front end just so the fronts are barely off the ground.
2008 fuoco
Sun Sep 13, 2020 12:35 am quote
See my posting it's on the second page of the forum, titled, "lifting the front end safely.
[ Time: 0.1364s ][ Queries: 25 (0.0543s) ][ Debug on ]
