Splitting a V90/PV engine casing
1970 180 Rally, 1980 P150X and P200E
Sun Sep 13, 2020 1:25 am quote
When splitting or assembling a V90 or PV engine, the flywheel side casing always gets hooked behind the input shaft gears. Does anyone have a trick or method on how to do it the easiest way?
PK50XL,PK100S,ET3
Mon Sep 14, 2020 12:36 am quote
Take the clutch out, then the christmas tree can stay in the fly side when you split the casings.
Mon Sep 14, 2020 5:43 pm quote
Yes
I ALWAYS have to turn the rear wheel so the gear cogs line up ( in a fashion only they know)...and ALSO manipulate turn the shaft where the clutch mounts.. at the SAME time....then it satisfyingly slides in or out perfectly
Offer up (or separate) the fly side as far as it will go...apply very slight pressure to the fly side.....and then do the double wiggle of the shafts and smile as it all meshes and goes together or apart depending
good luck
also check the locating pin way down the bottom of the cases has not moved during disassembly and preventing (mostly) re assembly....it can stop the case closing the last 2cm
[ Time: 0.1461s ][ Queries: 25 (0.0244s) ][ Debug on ]
