Naked Handlebars
lml 2t 150 with sidecar, Vespa px cutdown 125cc
Mon Oct 12, 2020 9:53 am quote
Does anyone manufacture the above to fit the PX and also will earlier style fit if not.
Thank you
VNB VSC VBC VSX
Wed Oct 14, 2020 5:27 pm quote
Hmmm... Never seen it.
Wed Oct 14, 2020 5:43 pm quote
Think I've seen something like this but can't remeber where. Sounds like the sort of thing Beedspeed would sell. But if they do, don't buy it from them!
Wed Oct 14, 2020 5:49 pm quote
With enough cutting & welding anything is possible!
Wed Oct 14, 2020 6:02 pm quote
Sip sells the controls. Get some
Mountain bike bars and make a custom gooseneck and you’re set.
-g
Wed Oct 14, 2020 6:04 pm quote
What are the chances? I followed a link for something else and these guys have them! In Indonesia but probably the same thing sold by Beedspeed (if that was the place I saw them).
https://www.scooter99.com/
Wed Oct 14, 2020 6:41 pm quote
Probably a lot more common on cutdowns.
I tried it, but I didn't really like it and finally swapped for an early smallie headset.
P200E
Wed Oct 14, 2020 9:51 pm quote
How does a ET handle bar mount? Page 20 of the Post your ET in the Gallery has a cool looking bike with naked bars. Looks similar mounting in one of his pictures?
Thu Oct 15, 2020 1:08 am quote
Thank you all for your suggestions I shall do a bit of research now.
APE the handlebars on the et4 have a standard fitment as they came off a Vespa lxv.
Thu Oct 15, 2020 1:10 am quote
Sorry APE its a pinchbolt that hold them on the stem.
P Series / Li / LML / Motobi
Fri Oct 16, 2020 3:13 am quote
whenever i have made naked bars - i used one of these as the means of holding the bar to the column
https://www.sourcebmx.com/collections/steering?currency=gbp&_=pf&pf_pt_product_type=BMX%20Stems
then you choose the rest your way...
Fri Oct 16, 2020 2:37 pm quote
They look nicely made.
Here's one from the Scooter99 site
Sat Oct 17, 2020 2:05 am quote
here's a set of naked ET bars for ya
you could easily use the stock LH side cable actuated pull for the rear and then do whatever on the front (disc or no disc) and use a stock throttle pull with a modified cable or an aftermarket quick throttle. pinch bolt goes thru the front.
hth
(and let me know if you want a pair, i've got a few)
-g
Your Rally Here   DoubleGood Vespa T-Shirts   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.1406s ][ Queries: 23 (0.0279s) ][ Debug on ]
