here's a set of naked ET bars for ya
you could easily use the stock LH side cable actuated pull for the rear and then do whatever on the front (disc or no disc) and use a stock throttle pull with a modified cable or an aftermarket quick throttle. pinch bolt goes thru the front.
hth
(and let me know if you want a pair, i've got a few)
-g
