Akrapovic....yea or nay....?
2016 GTS Nero; 2018 GTS Super Sport, matte yellow
Sat Nov 07, 2020 12:18 pm quote
Hello all....I’m a bit dismayed by the rather poor quality of the OEM muffler/exhaust, GTS 300 Super Sport. The black paint fades, not a Premium look for premium brand.
Am considering buying an Akrapovic replacement. Recommended or not?
Too showy...?
I know the quality is superior.
Opinions?
GTS300 Super HPE, Primavera 125, S 50 4T
Sat Nov 07, 2020 12:39 pm quote
It’s a matter of taste. When I bought my HPE I had the OEM exhaust replaced by an Akrapovic and still love the look and the sound. Not extremely loud but a bit more beefy. So my answer would be definitely yea.
2014 Commuter BV350(45,000)/2015 Scoot Life BV350(11,000)/2010 El Diablito SH150i(30,000)
Sat Nov 07, 2020 12:53 pm quote
I don't know about the GTS but on the BV, it's easier to access the dipstick and adjust the shocks with an aftermarket exhaust. You also eliminate the graphite manifold/silencer bushing failure.
Down side is that it's a PITA to separate the manifold pipe from the silencer when changing a rear tire.
2013 GTS300ie
Sat Nov 07, 2020 6:21 pm quote
My Vespa guru doesn't recommend the Akropovic.
He says he found it places stress on the stock exhaust manifold, leading to cracking or stud shear.
We have one rider in our group with an Akropovic pipe. He is told to ride at the back because he make too much noise.
Sun Nov 08, 2020 12:50 am quote
Apart from the high price it is aesthetically more beautiful but the original fits better into the line; then ... the noise changes, who likes it and who doesn't and you must hear it before buying. However there are many models of many brands, please consider well. There is a topic here on Modern Vespa with various photos and impressions, ask if they put the link.
Sun Nov 08, 2020 3:00 am quote
My Commuter BV has a Malossi exhaust with +30,000 problem free miles on it. The only reason I don't have one on my Honda is rear drum brakes. Makes no sense to modify the Honda when the brakes have a hard time stopping a stock bike.
Sportcity 350ie
Sun Nov 08, 2020 1:32 pm quote
Pro: With Akrapovic you would shave 4 kilos of weight from engine in my case (non damped mass!). Rear shock absorber would apreciate this.
You get 0.5~1hp and almost same amount of torque with more narow power-rorque curve for few hundred revs what means slightly increased top speed.
Hexagonal shape give you few more ° of lean angle if OEM exhaust was limited it.
You could simpla remove slip-on by unscrewing two bolts and releasing two springs.
Contra: Noise patern would be changed. Deeper sound on idle and during acceleration. When keeping same speed no significant increasement. After 80kmh i hear only air-to-helmet noise what mean's it's not annoying (for rider) during inter city trip or highway.
Sun Nov 08, 2020 10:17 pm quote
balki wrote:
Pro: With Akrapovic you would shave 4 kilos of weight from engine (non damped mass!). Rear shock absorber would apreciate this.
You could simpla remove slip-on by unscrewing two bolts a d releasing two springs.
Contra: Noise patern would be changed. Deeper sound on ie and during acceleration. When keeping same speed no significant increasement.
It's just an aesthetic factor ... and expensive.
2020 GTS 300 Super
Mon Nov 09, 2020 12:20 pm quote
That could be said about the Vespa in general. There are certainly many 2-wheeled conveyances available that will get you there and back for a lot less money. I suspect most of us chose the Vespa because of its aesthetics. It's not flawless to some of us though and "expensive" is in the eye/wallet of the beholder. Me, I'm a yea Akrapovic kinda guy - or anything else you think personalizes your scoot for you.
Mon Nov 09, 2020 7:10 pm quote
Touche'...
Sponsor
Granturismo 218
Tue Nov 10, 2020 10:27 pm quote
There's always that one guy that can't resist pissing in everyone else's cornflakes. What the Guru found directly contradicts the experience of thousands of satisfied Akro owners. I don't sell Akro (and don't want to get started as to why not,) but it's a very good, well designed and well made pipe. How long has the Guru been involved in scooter racing, and what class does he compete in or build for, because it sounds like he's some sort of expert in modern Scooter performance?
GTS 300 HPE
Wed Nov 11, 2020 1:53 am quote
I'd be interested in replacing the standard silencer on my GTS at some point if the replacements removed the need for the graphite bush, but not at the expense of broken exhaust studs! It seems reports of the graphite bush failing after only 4000 miles are quite common.
The Akropovic silencer I fitted to my BV350 used springs to tension the silencer where it fitted to the downpipe presumably to allow some movement. Does anyone know it this allows enough movement to prevent undue stress on the exhaust header studs?
John
2015 GTS 300 Super (Melody)
Thu Nov 12, 2020 6:38 pm quote
Well, I just shaved a few pounds off Melody by (finally) jettisoning the entire EVAP system (which was failing badly anyway). Found a clean OEM pipe a while back that replaced the original (which will get repainted with a more-durable coating). The cost of an aftermarket pipe would pay for a a proper suspension upgrade, which to my mind is far more worthwhile from a performance standpoint, and will be Melody's first major upgrade sometime next year.
typhoon,pgo metro
Fri Nov 13, 2020 4:56 pm quote
Consider this....tecnigas make high quality pipe, you can also choose in black
https://www.racingplanetusa.com/vespa-tecnigas-performance-exhaust-4scoot-maxi-system-tecnigas-vespa-300ie-vespa-modern-touring-scooters-p-173697-1.html
Sportcity 350ie
Fri Nov 13, 2020 11:44 pm quote
This would be my 2nd choice after Akrapovic:
https://www.mivv.com/en/moto/piaggio/vespa-gts-300/
*I edited my previous post above and add two more argument pro;-)
Yellow GTS 300 Super, Black GTS 300 Super Sport
Sun Nov 15, 2020 1:34 am quote
Does anybody have an English translation of this article which reviews a whole stack of mufflers for the GTS and compares them with dyno charts.
[url] https://issuu.com/scooter-center.com/docs/auspufftest_vespa_gts_scooter_center_motoretta/5[/url]
This was in another post but thought it might be useful in the old muffler discussion.
Also how do you read the dyno charts it has in it?
Sun Nov 15, 2020 6:25 am quote
Removal of evap,control hardware in U.S.....?
Firstly, thank you all for your friendly and knowledgeable,responses!
Some of,you in the U.S. reference removal,of,the problematic evaporative emissions controls.
Can anyone please share details on the procedure,maybe a useful video, please...?
GTS 300 Super
Thu Nov 19, 2020 5:03 pm quote
Sound Matters
Depends on whether you're OK with the sound of the stock exhaust. I like the sound of the Akra and have one on my GS as well. Picked up a used slip on here so the cost was not too much. Improved the sound greatly on the GTS. Performance wise, hard to tell. Your decision should be based on look and sound.
Vespa Supertech
Thu Nov 19, 2020 5:06 pm quote
I have the Arrow exhaust on my Supertech. (I chose the black one - not in picture on their website)
Malossi rebrands this and is more expensive for simply a badge change
https://www.arrow.it/en/assembled/1652/Piaggio-VESPA-GTS-300-HPE-2019
[/img]
Wed Nov 25, 2020 7:21 pm quote
Re: Removal of evap,control hardware in U.S.....?
Wellll, it's like this: there are several online sources purportedly showing you how to remove the EVAP system from a particular Vespa…
Trouble is, these instructions involve carbureted bikes: your GTS, like mine, is fuel-injected, and the hose arrangement is therefore different, as you're dealing with just two hoses, as opposed to three for carbureted engines. In this case, you might want to check the instructions for removing the EVAP from an MP3, as mentioned in this thread:
Removal of Evap Canister on BV 350: how-to guide
A bit of a headache to sort out, but now Melody is running nicely.
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   DoubleGood Vespa T-Shirts   AF1 Racing Vespa Austin
[ Time: 0.2424s ][ Queries: 27 (0.0511s) ][ Debug on ]
