charlieman22 wrote:
Lifted cylinder requires me to shift up to front of seat and lean over handle bars.
Said that to Chandlerman when in Nashville.
Response: "what's your point - isn't that normal?"
LOL! I'd forgotten about that. You don't even realize you're doing it after a while, until you jump on a bike that *doesn't* have that much power and just feel silly-looking as you throw your weight forward for no reason.
charlieman22 wrote:
Seriously y'all - these things are pretty damn rugged.
Hat tip to vespa engineers and their Italian vino.
Not only are they rugged, but if you look at them in the context of being something that was going to be cast, then finished by a machinist, you realize all the subtle design decisions which boiled down to, "Do we make this optimal from a performance perspective, or design it so that some guy standing at a drill press all day will get it right almost every time?"
The Vespa engineers did a really good job of that, IMO. I compare it to the 1962 vintage outboard that came with my boat. I opened it up a little bit and realized that the thing was designed with no consideration whatsoever of the fact that people might need to work on them at some point down the road. And don't even get me started on the abomination that is non-metric measurements...
charlieman22 wrote:
Jack - others - pipe up on the following:
All the tuners seem to end up with reed valve option.
What are the negatives/tradeoffs of going reed?
Low RPM torque?
Noise?
Whats the gig?
Jack already answered, but the trade-off's of reeds are:
- more potential surface area, and thus airflow, torque & HP
- less blowback
- more moving parts -- reeds wear out and have to be replaced periodically. Rotary valves last effectively forever, so long as you don't gouge them too bad
- higher cost
- more crank options
- no intake timing to worry about/tune for
They have a slightly different sound than a rotary, which is noticeable when the cowl is off at idle, but it's pretty minimal. Some people say they're noiser, but that could be blaming the reeds for the result of the reeds (more flow and more power), so take that with a grain of salt. In my testing, the difference between a reed and a rotary on 187's was 104 vs 201 dB, so well within the margin of error, I'd say.
