whodatschrome wrote:
A Crapsman socket was donated...
First full restoration project.. 1980 P200E |
Post Reply Forum -> Not-So-Modern | Previous12345678Next |
Author | Message |
![]() Vespas 1964 GS160, 1965 SS180, 1977 V9A1T, 1983 PX150E
Posts: 1668 Location: Siam |
![]() whodatschrome wrote: A Crapsman socket was donated... |
![]() ![]() 1979 P150X, 1983 P200E, 1988 T5, 1995 PX200E, 2011 Yamaha Fazer 600 S2
Posts: 2214 Location: Veria, Greece |
![]() Same money will get you the SC clutch (same, as all are based on the MMW design) with the CR plates and the 24. The 23 isn’t available for now...
https://www.scooter-center.com/en/clutch-bgm-pro-superstrong-2.0-cr80-ultralube-type-cosa2/fl-for-primary-gear-64/65-tooth-vespa-px200-rally200-22-tooth-bgm8322?number=BGM8322 |
![]() ![]() VSX, Stella 177, VNX1T, V9B1T
Posts: 2901 Location: Staten Island, NY |
![]() SaFiS wrote: Same money will get you the SC clutch (same, as all are based on the MMW design) with the CR plates and the 24. The 23 isn’t available for now... https://www.scooter-center.com/en/clutch-bgm-pro-superstrong-2.0-cr80-ultralube-type-cosa2/fl-for-primary-gear-64/65-tooth-vespa-px200-rally200-22-tooth-bgm8322?number=BGM8322 |
![]() ![]() 2007 Stella 225
Posts: 1557 Location: Rochester, Minnesota |
![]() Swiss,
I was a bit surprised on how far I opened my exhaust port to clean it up and even it out. I was using various diameter sanding drums so nothing aggressive. Once you get it cleaned up, I wouldn't be surprised if you pickup some more overlap. I had to laugh, Jack made fun of my exhaust port work the first time around. I thought it was pretty good, and better than what I started with. Needless to say I had to try again and redeem myself with the scooter gods. I'm not familiar with those transfer ports, is the angle, the way there supposed to be or is it the rough casting? For some reason I'm thinking mine were angled also. I'm jealous, looks like fun by the way, makes me want to buy one just to clean it up and see what I can get out of it. I have to work on heating my garage so I can get some tinkering time in. swiss1939 wrote: ...and for Jack/anyone else interested in the port mapping of the stock piaggio 200 cylinder. More accurate measurements taken from the trace: Exhaust - 38.77mm Transfers - 47.98mm Exhaust Arc Width - 40.98mm As you can see from the exact trace of the ports, they are extremely rough shaped from factory. Jagged edges everywhere. Updated port timings with 1mm base gasket: Exhaust - 166 Transfers - 126 Blowdown - 20 Trying to remind myself of the exhaust width target... 60% of the Bore diameter... 68mm? Which would be 40.8mm. So I am fractionally wider than 60% with my measured arc. So no more widening. |
![]() Hibbert was asking me about the difference in sealing lip on clutch side of p200 crank compared to 150 crank, so his query got me out in the cold garage pulling the parts out to take pictures and post for him here. Mostly looks similar but slight differences i can see. If anyone knows more please share. I'll quote hibbert below with his original questions.
Quote: Have you noticed on P2 cranks there is a lip on the rotary side that seals the pad off a little deeper than on 125/150 cranks? Reason I'm asking is the Polini crank looks thicker there at least the photo's look like the design might be a little different have you compared that to your stock crank? ![]() Lml on left, polini 60mm 200 middle, stock p200 right ![]() Stock 200 ![]() Polini 200 ![]() Lml stock 150 ![]() p200 stock other side ![]() Polini other side ![]() lml other side |
![]() I'm easing back into this rebuild. One or two small things a day instead of trying to rush to do it all at once. Tonight I cleaned up some of the leftover oil and dust in cracks from the sand blasting on cases. Also took the cover off my Px125 bench seat that I'll use for this p200. Someone put a replacement seat cover over the original seat cover, and both were decaying and cracking. Gonna have to treat the rust on the seat frame and respray black to protect it for the next 40 yrs.
Regarding cases, I noticed some pitting next to the oil drain hole which are just on the inside surface of the case, no marks on the outside. Wondering if this is something I should worry about for structural issues or just ignore it? Also saw similar pitting on the sealing surface for the cylinder base. Should I deal with this pitting next to the right port? Finally, why do they have the side port indents on the case if there are no port openings on the cylinder skirts of these stock p200 barrels? ![]() pitting near oil drain hole. ![]() pitting on the mating surface at the top most port in this photo. Thinking I'll leave it alone. ![]() why have these left and right indents in case when there aren't matching transfer port openings in the stock skirt? ![]() no transfer port openings in skirts ![]() bench seat frame from px125 ![]() rusty ![]() ![]() ![]() ![]() ![]() |
![]() ![]() 62 VBB1T Round Tail W/ leaner sidecar
Posts: 2191 Location: california |
![]() Swiss - looking good.
That pitting is minor - and not a concern. Even on a sealing surface - a thin layer of sealant under your gasket will ensure no leaks. So nice to work on such clean cases. Interesting point about the side transfers. Looks to me like they were made for a cylinder with multi ports? Will be interested to hear what others have to say about why and when they were added. Perhaps it was to plan for the future... |
![]() PX221 Malossi, O tuned PX200 and some motorbikes
Posts: 2705 Location: London UK |
![]() Side transfers up inside the piston work well enough. When the base ports are opened up it makes no noticeable difference, without many more changes. Which then, is more work, than its worth. My PX200 is running a extremely modified (20bhp) stock cylinder. So much work I won't be doing another one anytime soon. Buying a kit (and tuning that) is way easier.
![]() One of my lesser favorite tasks... getting the damn engine bushing mounts installed. One went on relatively fast. The other one is refusing to go on straight and keeps getting bunched. Heated case, lubed up the hole and plug with tons of soap. Still won't go in straight! Sounds like a personal problem
![]() Save that one for another day. BTW, I just swallowed hard on a damn expensive SIP order to get the rest of what I need for this engine rebuild. Closed my eyes and pressed purchase. ha! |
![]() How close are P200 cases to the earlier P150 cases? I've often wondered if the port locations were a hold over from them. But if that were the case why is the boost port in the correct spot?
Are you going to do some o tuning and put in case ports? If you've got another cylinder you want to put on later now would be the time to cut them in. |
![]() ![]() 74 50s x3 78 P200 x2 84 Cosa PK50XL2 58 AllState 68 Sprint 80 50special '66(?) Super125
Posts: 8121 Location: seattle/athens |
![]() The cases are much the same from crank centerline down, but much different for the top half. I think.
For your messy motor, you're on the right track IMO and looks like there might have been a deelux upholstery kit included when you clicked BUY? ![]() Good! ![]() |
![]() swiss1939 wrote: One of my lesser favorite tasks... getting the damn engine bushing mounts installed. One went on relatively fast. The other one is refusing to go on straight and keeps getting bunched. Heated case, lubed up the hole and plug with tons of soap. Still won't go in straight! Sounds like a personal problem ![]() Save that one for another day. BTW, I just swallowed hard on a damn expensive SIP order to get the rest of what I need for this engine rebuild. Closed my eyes and pressed purchase. ha! https://youtu.be/2Qjk_TuMEKs https://www.homedepot.com/p/Everbilt-1-in-x-36-in-Zinc-Plated-Punched-Square-Tube-803037/206939549 |
![]() I do basically the same but using a sip bearing puller tool on one side and washers on the other side. But the bushing is not going in straight and one edge keeps getting hung up. If you try to push it through it's just gonna rip the bushing apart.
V oodoo, i didn't buy anything for the seat. I need to figure out a new cushion for the bench seat cause the original way rotted away and stiff. Don't see anyone selling the cushion, only covers. |
![]() swiss1939 wrote: I do basically the same but using a sip bearing puller tool on one side and washers on the other side. But the bushing is not going in straight and one edge keeps getting hung up. If you try to push it through it's just gonna rip the bushing apart. V oodoo, i didn't buy anything for the seat. I need to figure out a new cushion for the bench seat cause the original way rotted away and stiff. Don't see anyone selling the cushion, only covers. |
![]() Here's my installer and puller. And you can see the problem where this one edge of the rubber gets hung up and won't go in. I'm thinking I'm gonna have to sand the rubber down just slightly around that inner edge of bushing to get it to start off correctly seating as it gets pulled in.
![]() Parts on way include SIP fast flow fuel tap, same exact 24/24 carb I got on my stella (cause the bike came with a 20/20), VAPE DC Variable ignition, SIP Cosa 2 Ultrastrong with 23T cog and CR80 plates, and I went with the SIP Road 3 exhaust cause it was cheaper than the polini and everything I found online seems to suggest they are very similar in performance. Also got tubeless rims and Heidenau K62 tires which I'll throw on the stella and use the current tubeless on this p200 to start. Did not go with 11" tires/rims cause going with them just seemed a random decision until I hear more about their benefits.
I also just realized I did not get everything I need to complete this engine as I believe I need a new primary gear for the christmas tree cause the existing one has a slight gouge going around the whole gear down the middle of all the teeth faces.. and I should probably rebuild the christmas tree with new springs anyways. Might even need a whole new Christmas tree cause i can see more indents on the face of some of the gear teeth pictured below. Or maybe it's so minor that it didn't matter. So I guess I'll have another order coming this month to get this engine built. ![]() ![]() Last edited by swiss1939 on Sat Nov 21, 2020 12:00 pm; edited 1 time in total |
![]() Nothing wrong with your primary. Those gauges are normal and they’re there to carry oil...
Positive
![]() SaFiS wrote: Nothing wrong with your primary. Those gauges are normal and they’re there to carry oil... |
![]() That’s a great list of SIP parts!
For the engine mounts, maybe put them in a pot of boiling water for 5 minutes? It will soften them up quite a bit. Also get the case hot enough that you don’t want to touch it with your bare hands, put some grease on everything, then use a mallet to hammer them in. |
![]() whodatschrome wrote: That’s a great list of SIP parts! For the engine mounts, maybe put them in a pot of boiling water for 5 minutes? It will soften them up quite a bit. Also get the case hot enough that you don’t want to touch it with your bare hands, put some grease on everything, then use a mallet to hammer them in. |
![]() Greasing them up and twisting in by hand normally gets them in half way. They're not that tight.
![]() Tried that as well. My cases must be tighter tolerances cause these things aren't easy to get in or out.
![]() swiss1939 wrote: Here's my installer and puller. And you can see the problem where this one edge of the rubber gets hung up and won't go in. I'm thinking I'm gonna have to sand the rubber down just slightly around that inner edge of bushing to get it to start off correctly seating as it gets pulled in. |
![]() thats not a spacer, thats the metal tube the rubber bushing is attached to. Photo is of the puller tool loose after I backed off from trying to get it in, so everything is just sitting freely and the bushing was still stuck in.
![]() swiss1939 wrote: thats not a spacer, thats the metal tube the rubber bushing is attached to. Photo is of the puller tool loose after I backed off from trying to get it in, so everything is just sitting freely and the bushing was still stuck in. |
![]() as far as i know these original bushings the metal tube doesn't come out of the rubber, they are attached so you gotta put them both in together. Its similar with the lml original bushings. I tore one of those up last year and they have some metal ring on the outside of the tube which the rubber is molded over, which helps hold the rubber to the metal tube. I'm assuming from the way this rubber is molded over the tube it is the same basic construction on the piaggio original bushings.
I should have taken a picture of it when I pulled it apart. |
![]() Shouldn't be that hard, I've had to file or Dremel a chamfer in the edge of the hole and use lube and a big hammer to swat it in to start, then draw it all the way in like you are. Maybe some luck was/is involved. Therefore... Good Luck.
![]() swiss1939 wrote: as far as i know these original bushings the metal tube doesn't come out of the rubber, they are attached so you gotta put them both in together. Its similar with the lml original bushings. I tore one of those up last year and they have some metal ring on the outside of the tube which the rubber is molded over, which helps hold the rubber to the metal tube. I'm assuming from the way this rubber is molded over the tube it is the same basic construction on the piaggio original bushings. I should have taken a picture of it when I pulled it apart. https://www.claussstudios.com/store/p765/Vespa_PX125_PX150_Polyurethane_Engine_Mounts.html |
![]() Working on this engine in my living room cause it's damn cold out! Doing all the mockups inside and anything dirty out in the garage.
Got those bushings installed finally. The one I was struggling with was warped and not gonna go in. New one installed with much less effort and a combination of all your suggestions. Got the plastic bearing dummies and set up the crankshaft with piston to do measurements of the rotary timings. Rotary opens at: 42.78mm Rotary closes at: 26.77mm I measured these by shining light into the case up through the rotary valve and spinning the crankshaft until it either cut the light out or let the light through the valve. Trying to understand what the goal of tuning the rotary inlet is. I understand it in regards to the same concept as a camera shutter speed, so by widening the rotary inlet, I am letting more air in which will still have to compress to the same end volume at max compression.. which means more power. But I'm still trying to decipher what are good targets in terms of amount of time open and when it opens or closes in relation to the cylinder timings. Just watched a few FMP videos and it seems he targets 200 degrees for admission timing, and through grinding the rotary pad on the open side wider, and the crank cheek on the closing side, he expands the inlet open and close and admission to suit his targets. From what I'm watching it seems the important targets at least for his tuned engines are concerned.. 200-210 degrees admission is a goal.. and 8 degrees of overlap between transfer and inlet opening. Now I'm not entirely sure how a 200 degrees admission and an 8 degree overlap equates to rpm or torque similarly to how I get the exhaust, transfer and blowdown relate to the same in cylinder timings. Does it relate similarly? Or is tuning the rotary timing purely a process of ideal intake volume or instead ideal open/close in relation to cylinder timings? If I were to try to target 200-210 admission and 8 degree overlap on my current numbers, this means I would need to grind out the intake opening 10mm earlier than current on the rotary pad, and leave the crankshaft closing cheek on the crankshaft where it is currently at. This would give me a 206 degree admission with 8 degrees overlap of the rotary opening to the transfer port times. EDIT: Tuning Vespas The Norrie Kerr Way. Just came across mention of this book in searching about inlet tuning and it seems like a good book to get through. Gonna try to get my hands on it soon. And also getting through this discussion 6 months ago from chandlerman on the same topic, where it seems for my desired touring slightly optimized stock setup I should be closer to 180-190 admission which is not far off from where it stands as is, but still begs the question of how much overlap helps or detracts from torque.. and if it benefits a touring setup to shoot for more overlap... http://modernvespa.com/forum/post2419515#2419515 Also realized my calculator numbers were off from most recent cylinder measurements. updated images to correct measurements. Here's the calculator attached below with no base packer so the negative PBT is where it sits by default. ![]() Measured as stock. ![]() 0.59mm base to get 1.2mm squish. Grind rotary inlet 5mm wider to get 190 degrees admission. Last edited by swiss1939 on Sun Dec 13, 2020 7:37 am; edited 1 time in total |
![]() Jack221 wrote: 126 transfer is not quite accurate as the ports are slanted. Is 126 for blowdown but not for performance flow. You're going to need more than 20 degrees blowdown though. 28 degrees is nice for what you want. Or are you suggesting just increasing the squish to 28. Cause that would involve grinding exhaust up 4mm making it 180/124 28. Is it really that much of a difference for the effort to modifying the barrel? I'm still leaning against modifying the barrel aside from cleaning it up slightly. Not gonna widen the exhaust as its too close for comfort to the stud holes. I will drop the exhaust port to PBTD though. |
![]() Your new crank is cut for higher rpm. 75 degrees ATDC is quite a bit. Some would say the max. The longer ATDC the more blowback. Not ideal for torque. Obviously you will use this Polini crank. To give enough torque the power will need to be increased a bit more. Go for under 200 degrees total inlet. Approx 195 will do it. If slightly more is ok but keeping under 200 should be the plan.
28 degrees blowdown. 126 duration is a good amount of transfer for this cylinder. Still has the slanted transfers so this isn't like normal 126 degrees. Will be like 126 for blowdown as the reversion will still happen but will be more like 122 or so for performance. No point aiming for really high power as the transfers are just too high velocity and it will just run flat. In summary 126 transfer duration plus 28 blowdown means exhaust should be 182. |
![]() Ahh damn. So the crankshaft choice requires doing some exhaust grinding to make it useful and not run like crap. Sounds like i have to do a little more than desired in order to have the parts chosen result in a useable engine. The result of mismatched parts ordered for intended purposes!
Minimal dremel work needed to make these parts useful: -Widen the rotary inlet pad to achieve 195 degree admission (approx 7mm) -grind exhaust up to 182 and down to pbtd (approx 4mm) -chamfer Time to get the dremel out again. Wondering if something like this crank would have been better choice regarding the blowback mentioned. Mine is 138/6. This one is 125/-5. Guessing the earlier timing on the crank translates to lower rotary times with the same admission? https://www.sip-scootershop.com/en/product/long-stroke-crankshaft-sip-premium_45021510 Also I'm gathering from what you say about ATDC rotary timing being more for higher RPM.. that the position of the rotary timing in relation to the cycle does matter for desired torque or rpm targets. This was something I was wondering and I guess the way I'm trying to understand it is using the graph from that calculator.. the top crescent depicting the rotary timing.. if kept same duration, but rotated more towards ATDC shifts the engine performance towards the RPM end of the spectrum, and conversely, rotating that crescent on the graph backwards towards BTDC shifts the engine performance towards the torque end of the spectrum. Mocked this idea up below: ![]() shift the rotary timing further past ATDC == RPM ![]() shift the rotary timing earlier before BTDC == TORQUE ![]() minimum to make the parts work well together. |
![]() Rotary inlet duration needs to be in tune with the cylinder and exhaust. And even this is not one size fits all.
Generally though the longer the duration the higher the torque but if you go over what the cylinder and exhaust are aiming for, the torque starts to go down again. The one thing you can be sure of is the stock inlet is sized and timed for maximum economy and lower rpm max power delivery. What you're planning only makes yours better. |
![]() Jack221 wrote: Rotary inlet duration needs to be in tune with the cylinder and exhaust. And even this is not one size fits all. Generally though the longer the duration the higher the torque but if you go over what the cylinder and exhaust are aiming for, the torque starts to go down again. The one thing you can be sure of is the stock inlet is sized and timed for maximum economy and lower rpm max power delivery. What you're planning only makes yours better. Exhaust shape.. should i make it more boxy like the example below? Also will grind the rotary inlet to 7mm wider than stock. ![]() p200 stock exhaust profile ![]() p200 modified boxy profile. |
![]() I up and moved my p200 rebuild operation to Florida for a month or so to take advantage of warmer weather and current ability to work from "home". Home being my parents house in port st lucie.
Couldn't wait to get the dremel out on first day down here! Rotary inlet opened up 7mm to achieve the desired 195 degree admission. Just barely broke through the stud hole. I've not had good luck using jb weld putty especially for filling small holes like this stud opening. I'm curious if anyone has used this permatex liquid metal filler? I'm thinking i might try using this to fill the opening between rotary pad and stud hole. https://www.amazon.com/dp/B000ALDYJI/ref=cm_sw_r_cp_apa_fabc_9Zm9Fb315F4F5 ![]() ![]() ![]() |
![]() What's the split on the 195 degrees? Looks like not a lot off at the back.
Did you do the cylinder? What ring thickness you using? |
![]() Jack221 wrote: What's the split on the 195 degrees? Looks like not a lot off at the back. Didn't start on the cylinder yet. That's next. Gs piston with 1.5mm rings. |
![]() swiss1939 wrote: Jack221 wrote: What's the split on the 195 degrees? Looks like not a lot off at the back. Didn't start on the cylinder yet. That's next. Gs piston with 1.5mm rings. I believe that is why most (instructions on Polini cylinder also say) cut the disc on the crank to alter the closing timing as there isn't much room on the closing side of the pad. Hope this helps. |
![]() Ah ok.
121 open (after grinding) and 74 close. Based on the calculator with my target numbers. I'll physically confirm that when i get a chance. |
[ Time: 0.2138s ][ Queries: 25 (0.0600s) ][ Debug on ] |
