Vespa hub studs
'81 Vespa P200e, '93 Vespa PX125e
Thu Nov 19, 2020 5:33 am quote
Anyone every remove or replace these?
I know they are a replaceable part. Everyone just replace one or two bolts on a rim?
I have a brand new rim with a misthreaded stud and I would rather replace the stud than they whole rim.
Any input is appreciated.
N
Thu Nov 19, 2020 5:44 am quote
I had a hub that had a regular hex head bolt bodged into it. I took it out, had the hole welded up, a new hole drilled, and then tapped threads for a proper stud. Drilling the hole correctly is critical. It’s easily messed up even if it’s off a bit. Have a machine shop with a drill press and proper measuring tools to get it right.
If the hole you have is ok, you can remove the stud with a stud remover or a hack job with a Visegrip.
So, yes, it can be done.
Thu Nov 19, 2020 5:55 am quote
So really it’s not as easy it would seem.
Thu Nov 19, 2020 6:21 am quote
It could difficult getting the old stud out. SIP sells a special tool to remove them, but I’ve never used it.
Mine was easy to get out because it had a hardware hex head bolt, which is not original. The problem was that it had an oversized hole. That’s why I went through the trouble of having it welded, drilled, and tapped.
If the hole had been ok, I would have just put in a proper stud.
Thu Nov 19, 2020 6:48 am quote
the back side of the studs are flared out from the factory to keep them from coming out. If you try and remove them without drilling out that flare it will just rip up the existing threads.
so, not really easy but it can be done.
2007 Stella 150
Thu Nov 19, 2020 8:17 am quote
I replaced my rear studs, I wanted to use flanged locknuts. I was able to turn my studs in a turn so the flare stuck out some and ground it off. The screws went in no problem.
Thu Nov 19, 2020 10:59 am quote
This is the way ^^^^^^^
For proper OEM look, use studs; but longer than the factory.
If not concerned about it being factory, you can use Button head hex bolts; which will add some security with the bolt head on the backside. Either way, use longer ones and Red Locktite.
Also, heat can be you're friend for loosening those factory studs! Just like heating the case to pull bearings.
Good luck!
bare metal cafe racer
Thu Nov 19, 2020 11:33 am quote
Probably irrelevant to the OP but FYI on stud bolts...
Those flanged ends just kiss part of my radial caliper. Or did... I let them work it out between them. Guessing that button caps would stick out a little bit further. And if I had longer stud bolts I wouldn’t be able to seat or remove the wide tyre on the back (despite removing the exhaust, shock, and dropping the motor down as far it will go - which I have to do as standard).
The price you pay for custom mods...
Thu Nov 19, 2020 1:09 pm quote
That's definitely the way to do it.
Yes they do, and they hit the caliper.
There is a type of hub where the studs are not screwed and staked. They're staked, but pressed in or something. This was a fairly new hub as well... tried screwing them out but no go. So had a guy drill them out - I was a long way from home at the point. Holes ended up in the wrong spot.
Thu Nov 19, 2020 2:22 pm quote
Timely topic!
I overtightened a lug nut and pulled the stud through. Ultimately, after I realized what was happening, I pulled it all the way out and cleaned it up with a hacksaw and file. I can thread the stud back in, but it doesn't hold securely.
I put in a hex head bolt as a stop gap. It works well with the threads in the drum intact. I don't have the means to press in a new stud. I was thinking about trying JB Weld to see if that holds the stud in place.
I'm sure I'll end up replacing the hub, but in the meanwhile, bodge mode engage.
2007 Stella 150
Thu Nov 19, 2020 2:54 pm quote
jape wrote:
Timely topic!
The factory stud is thread not pressed in.
Thu Nov 19, 2020 3:31 pm quote
jape wrote:
Timely topic!
The back of the stud is peened over. I don't have a means to do that. How do you do it?
2007 Stella 150
Thu Nov 19, 2020 7:12 pm quote
I took the wheel off, then I was able to put two nuts on a stud locking them together. Then I was able to tighten the stud down another turn. That left the premed end sticking my out a little. Then I ground the end of the stud off with a rotary tool. Same thing as a Dremel just a different brand.
jape wrote:
Timely topic!
Fri Nov 20, 2020 4:48 am quote
That sounds like a process for removing a stud -- you grind off the bit that is pressed/peened in. How have you installed a new one?
2007 Stella 150
Fri Nov 20, 2020 5:43 am quote
I'm not sure I understand the question. Can you post a picture of what problem your having exactly?
I didn't put studs back in, I used socket head cap screws, that were longer than original. I threaded the screws in from the back side, if your threads are good they screw in just like any standard screw.
As for putting in a new threaded stud. You can screw a new one in, just like screwing the old one out, after the peened over end is ground off. Everything is threaded, there nothing to press in anywhere. If you ripped a stud out of the hub and damaged the threads in the hub the only easy and correct way to fix it is to buy a new hub. The premed over end could be done with a center punch of some type.
[ Time: 0.1578s ][ Queries: 23 (0.0254s) ][ Debug on ]
