Omitting autolube and going premix
'81 Vespa P200e, '93 Vespa PX125e
Fri Nov 13, 2020 6:14 pm quote
Hey folks,
Any of you folks w oil injected vespas disconnect the autolube feature and simply premix your oil and fuel?
I’m breaking in my engine and would like to have a bit more oil in my gas rather than what the autolube mixes the gas at (assuming it’s 2%).
I was thinking of simply removing the oil pump drive shaft and premix my gas manually and riding it.
Thoughts? Things to look out for?
Thank you.
N
2007 Stella 150
Fri Nov 13, 2020 6:26 pm quote
Re: Omitting autolube and going premix
Nelluch125 wrote:
Hey folks,
Thank you.
Why not just pre mix your fuel with how much extra you want?
Fri Nov 13, 2020 6:29 pm quote
Christopher_55934 wrote:
Nelluch125 wrote:
Hey folks,
Thank you.
I could do that. Add an extra percent in for break in.
I’m thinking longevity though. Just omitting autolube all together.
Fri Nov 13, 2020 11:57 pm quote
What tuning spec do you have? I don't see the need to add extra oil unless perhaps you have built a beast. I've rebuilt several P/PX engines, in most cases with different cranks, alloy cylinder kits, porting, bigger/upjetted carbs etc. Apart from those with side draught carbs, I've always retained the autolube and have never added extra oil to the fuel, even for the break in. I've never questioned the autolube's ability to deliver and I've never had lubrication related issues
Sat Nov 14, 2020 4:51 am quote
Thank you for your response.
I rebuilt a px125e. Everything is new inside the cases. Added a dr 180 kit.
I figured I would add a bit more oil to make sure lubrication is at its optimal.
And again, I’m thinking long term. Omit the autolube and premix my gas for future use.
Just added
Px125 2009
Tue Nov 17, 2020 11:55 pm quote
Just added
So the px125 autolube is geared upto a 150cc scooter.
One option is to fit the 200cc gearing autolube but that can be an exspense not needed.
My personal choice on my kitted scooters is to keep the autolube as is and add an extra 1% to the petrol this way you get the best of both worlds.
What I mean by that is when you come off the throttle either at speed or going down hill the petrol flow is cut off, which if you are going to add oil to the petrol only, this means no oil being sent to the crank, where as if you keep the auto lube then there will always be oil sent because its linked to the actual revs of the engine.
Wed Nov 18, 2020 4:11 am quote
Just added
Thank you and everyone for your replies.
This is the option i am going to take.
like you said----best of both worlds.
I will tackle this in the spring since winter is upon us here in Ontario, Canada.
Cheers.
Stella 2T, P200, Rally 180 Euro
Wed Nov 18, 2020 6:13 am quote
More oil doesn’t mean better protection, since you are removing fuel which leans your AF ratio. For such a basic cylinder just keep stock injection and don’t worry about it. I’ve built some big engines and never added extra oil as it’s more of a danger.
Wed Nov 18, 2020 7:55 am quote
Noted. So much information. So many great points.
I’ll just ride it till it blows up. Lol.
2005 et4
Thu Nov 19, 2020 7:15 pm quote
The first notice you'll get when your autolube starts to fail is when the bike seizes up.
I went to premixing my own and that will ever happen.
Thu Nov 19, 2020 7:16 pm quote
Yes. And that’s what I would like to avoid.
What did you do to make the switch? Take out the drive shaft from the under the carb box?
2007 Stella 150
Thu Nov 19, 2020 7:24 pm quote
The autolube system can't forget to add oil when you fill up. There are pro's and cons to both.
2005 et4
Thu Nov 19, 2020 7:39 pm quote
Forgetting to add oil is almost an impossibility.
2007 Stella 150
Thu Nov 19, 2020 7:44 pm quote
My P200 is premix, its the only one of the four motorcycles I own. One day I'm going to fill up and ride away, just like my other three.
Px125 2009
Thu Nov 19, 2020 8:30 pm quote
all you need do is pull the drive shaft, and also its best to remove the cog within the oil pump itself to stop the throttle jamming, then blank off the hole in the casing left behind by the drive shaft, Sip sell a plug, blank off the 2t oil pipe to stop air being drawn in too
Thu Nov 19, 2020 11:01 pm quote
I wonder how many people have had actual autolube failure? I'm not saying it's impossible, but think of the number of P and PX scooters that have been plying their trade around the world since the late '70s, not to mention the US spec oldies that also have autolube. If we were talking about an electric or electronic system, maybe so, but this is a primitive mechanical setup. I'd say there's an extremely slim chance of it ever failing, especially if basic maintenance/cleaning is carried out on a regular basis.
P Series / Li / LML / Motobi
Fri Nov 20, 2020 4:21 am quote
There has been probably one go through my garage that had a worn and chipped / cracked worm drive setup... very high mileage motor and not the most "regular" of oil checks in the gearbox to make sure it splash fed the lube to it
Fri Nov 20, 2020 9:34 am quote
I think failure pretty rare. The vespa design a good one. Fully mechanical. Ive heard of maybe one around here over many years. Also figure in all the lmls etc.
Always jealous of those with it. Because its rpm, not throttle, you always get the oil the engine needs. Top of a big hill, engine hot and down the other side and dont need to fang it to maintain the same speed. The engine is still getting the right oil. On mine, not so much, and getting less oil with less throttle on the premix. Can be disconcerting when you check the temps.
I’d leave it alone and premix 1% if you think that is needed.
Fri Nov 20, 2020 11:12 am quote
Luddites
1980 P200E , 2005 Stella 177
Fri Nov 20, 2020 12:03 pm quote
Jack221 wrote:
Luddites
[ Time: 0.1511s ][ Queries: 23 (0.0381s) ][ Debug on ]
