Malossi O2 Lambda Emulator on GTS HPE
Vespa Supertech
Fri Nov 20, 2020 6:14 pm quote
some observations ...
I had it installed for about 2 months and have temporarily uninstalled for the last several days (will stick it back in soonish).
with installed (not high speed / freeway):
1. lower mileage. 30-32 km/l -> 27-28 km/l This is to be expected
2. more clutch slippage / shudder at lower revs (10-15 km/h in carparks etc)
3. more 'go' when taking off at the lights (with ASR disabled). WIN!
I'm pondering the clutch slippage still. Was able to easily adjust my style. May install a malossi or polini clutch ...
Notes:
* It's a supertech so I can check things like mileage by using the phone app that records the telemetry
* using an Arrow after market exhaust
Blue GTS300 Super 2015, White GTS300 Super 2018
Fri Nov 20, 2020 7:25 pm quote
Lower mileage might be because of the way you take off with the Lambda Emulator installed.
Dr.Pulley HIT clutch is good for locking the clutch and preventing slipping, but this can cause jerks when you open the throttle at low speed. It is expensive. But I don't know anything about tuning the HPE transmission, having only worked on earlier models.
Vespa Supertech
Fri Nov 20, 2020 7:31 pm quote
doubt this as this should be a minor effect when doing enough kms
Rallies Europe 2016   DoubleGood Vespa T-Shirts   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.2656s ][ Queries: 25 (0.0439s) ][ Debug on ]
