I bought an ET2 that was having trouble starting, it turns over but no fire. I’ve been working through all the recommended steps, I’ll list what I’ve done so far at the bottom. but the only time it has actually got running was when the fuel was not hooked up. I was testing whether the vacuum was working so had the fuel hose off and going into a bucket, the scooter started(!) Then without fuel it started again and again perfectly. I thought maybe the engine was flooded so I rode it down my drive until it burned off whatever fuel was in there (maybe this was big mistake?) and then reconnected everything. The engine hasn’t started since. I’m flummoxed. It seems logical that the fuel is the issue but I’m not wise enough to know what my next steps are.
Oh yes and now when I try and start it sounds much more pathetic than it has done previously like it’s battery is low but I still get a 11.46 on the multimeter at the batt and have one of those external charging things telling me the batt is fully charged. perhaps I need to check the charge is actually reaching the starter? Or somewhere else?
So far I have -
Drained and replaced the fuel
Changed the fuel tap
Tested the vacuum line
Changed the spark plug
Tested the spark
Charged and checked the battery and fuse
Checked the automatic choke
Changed the air filter
Cleaned the carburettor
I think that’s it, there’s probably some key info I’ve missed out.
Hope that makes some form of sense and sorry if I’ve misnamed things.. I am quite good at following internet instructions but this is my first scooter so I am a novice
Thanks so much
Annie
