today i ..... bollox 2.1
Post Reply    Forum -> Not-So-Modern Previous123...71727374Next
Thu Dec 31, 2020 6:42 pm quote
I have this one , which is crazy bright and has held up well for a couple years.
Thu Dec 31, 2020 11:37 pm quote
swiss1939 wrote:
Can you share the link for this? I'm game for a $30 led headlight!
Here you go. It got pricier though (it was on discount till yesterday)...
https://www.aliexpress.com/item/33006979843.html
1978 P150X; 1982 P200e
Fri Jan 01, 2021 7:11 am quote
These all look great. Anything special needs to be done to mount on a P series w battery?
P125X, P200E
Mon Jan 04, 2021 1:27 pm quote
I'd like to see the answer to this too. My 1980 P200 (Spermy) is bone stock but I'd be interested in upgrading to an LED headlight. I'd like something close to Plug & Play but I'm guessing the headlight would have to be converted to DC. How would I do that? What else?
1963 Vespa VBB, 1965 Allstate Cruisaire, 1974 Vespa Super, 2003 Stella 2T
Tue Jan 05, 2021 6:44 pm quote
Painted a picture.
VNB VSC VBC VSX
Tue Jan 05, 2021 7:02 pm quote
Rad.
Tue Jan 05, 2021 7:53 pm quote
It would be difficult on an early P series. From what Iíve found, it canít really be done on a double yellow wire stator. Or maybe it can, but you would also have to swap over to a single yellow wire wire harness? https://scooterlab.uk/convert-your-ac-ignition-to-full-dc-for-pennies-workshop/
Option B is to just wire in an AC to DC converter right before the headlight. PK125 XL disc brake and LED headlight conversion
Tue Jan 05, 2021 8:24 pm quote
You could also tap into the DC wires at the keyswitch. Tie in a jumper to the left side light switch and youíre good to go. Clean DC right off the battery.
Tue Jan 05, 2021 9:12 pm quote
...make it simple whydontcha
1972 Vespa GTR, 1963 Lambretta LI 125
Wed Jan 06, 2021 12:38 pm quote
Chatis wrote:
Painted a picture.
I'm liking that. Well done.
Wed Jan 06, 2021 6:52 pm quote
My neighbor across the alley hooked me up with a motorcycle lift for $20 today. And my missing second roll of flooring finally showed up, so I'll get that down and be able to finish unpacking the new workshop.
And I'm going to take Jim's P200 motor off his hands so I can build a Kill-Myself-Fast motor.
All-in-all, not a bad day for this scooterist.
Hey buddy! Need a lift?
p125x, v90
Fri Jan 08, 2021 2:51 pm quote
stumbled across this on instagram today. Almost didnt notice the engine(s)
https://www.instagram.com/donganz_redscooter/
[/img]
Fri Jan 08, 2021 3:12 pm quote
[/img]
It looks like a whole subculture. It's like the aesthetic opposite of the crazy 20-wheeled, crew-operated multi-engine Vespas we usually see.
I like it
P125x (4KW Hub Motor)
Sat Jan 09, 2021 6:47 am quote
Those should be perfect for the scooters.
Looking good.
Sat Jan 09, 2021 6:50 am quote
[/img]
Interesting how he connected the chain to the hub. I kinda like it, and the others he posted.
Sat Jan 09, 2021 8:14 am quote
[/img]
I'm trying to figure out the two motors, you can see the second head without a shroud.
P125X, P200E
Sat Jan 09, 2021 10:28 am quote
CONVERTING TO LED HEADLIGHT
Option B looks good
Although MJRally's suggestion looks like another good way to go.
Thanks for helping me out with this.
Sat Jan 09, 2021 11:03 am quote
Option B looks good
And Iíll throw one more thing out...
Iím not sure at how many watts the DC side of the stator will charge the battery back up and at what rate. A standard P has a 35 watt headlight that has 12VAC going to it. Iím not sure how many watts are coming off the DC side of the stator. Obvious there is plenty of DC to power the brake/tail light and turn signals, but I donít know how much is left over to power a 12VDC accessory. I was using 40 watt grip heaters on my P2 (wired directly to the battery), and the 9ah battery that I had couldnít quite keep up. I would think that it would be able to handle a 20ish watt LED headlight with no problem.
P125X, P200E
Sat Jan 09, 2021 11:14 am quote
Thanks Whodat. Good to know
Wed Jan 13, 2021 11:24 am quote
Again on discount...
VSX, Stella 177, VNX1T, V9B1T
Wed Jan 13, 2021 2:32 pm quote
SaFiS wrote:
Ordered two!
Thu Jan 14, 2021 5:21 pm quote
Today I....
Painted another picture.
VNB VSC VBC VSX
Thu Jan 14, 2021 6:22 pm quote
again... good stuff
VNB VSC VBC VSX
Thu Jan 14, 2021 6:27 pm quote
A Missouri Survivor in TX (VBC resto ...coming 2022)
I may or may not have grabbed a clean, straight 74 Super for a late 2021 project... ahem ...
(will be on deck well after the SS180 gets done.)
Thu Jan 14, 2021 7:22 pm quote
Re: A Missouri Survivor in TX (VBC resto ...coming 2022)
DUDE!!!! So envious.....
Fri Jan 15, 2021 4:32 pm quote
Installed an original Piaggio front shock on my smallie. I put it together with parts from 3 different shocks. Having that "bug" stamp as Voodoo calls it is what's really important here.
Fri Jan 15, 2021 6:55 pm quote
...started making patterns for a new casting. Exhaust manifold that maintains proper flow for the Imola cylinder.
VNB VSC VBC VSX
Sun Jan 31, 2021 3:06 pm quote
Butts!
And Jackson the Great Dane...
Sun Jan 31, 2021 3:20 pm quote
He's a good boy!
Sun Jan 31, 2021 5:05 pm quote
Very nice! Very, very nice!
'79 P200, '74 VBC Super, '80 100 Sport (sold to new home!)
Mon Feb 01, 2021 12:42 pm quote
finally rode with other humans! The P had an engine refresh and shocks in late 2019 and has been in covid lockdown except for quick round-the-blocks. recently sorted a carb gas leak, and rode with scooterfriends for the first time in a long while! Scoot was happily cruising at 55-60 down the strand to Coronado on a fine San Diego day. The shock change from 40-yr old stock ones did wonders for the ride, fer sure.
Cheers peeps and F-Covid.
VNB VSC VBC VSX
Tue Feb 02, 2021 7:26 am quote
Good on ya.
That's a cool wind screen... hadn't seen that one before.
Wed Feb 03, 2021 4:46 pm quote
Double story here. I finally got rid of my red '62 VNB that nobody seemed interested in and it turned out to be easy. A kid up the street that is into little bitty stand on 2T scooters and pocket bikes, and has a nice Kawasaki 300 Scrambler bike I saw when we met up while I was riding my Vespa.
He was immediately in love with the look and the sound. He followed me home, then saw my herd and I allowed as to how I might not really NEED that old VNB too badly, coz just a 3 speed w/ a tired 150 top end that had 20/20 carb and kickstart lever 'borrowed' over time for more important bikes.
So we dug up a dirty old 20/20 cleaned it up and stole a kickstart lever from another motor. Reward: squirt of gas down the venturi & dang thing started 2nd kick. Now hook up gas tank and some gas in it. So now it just keeps running, nice idle and all. Aired up the tires and tried a ride! Nice, and lots of beans too after just sitting ~5 years! Discovered front wheel nuts loose though, OOPS .
Second story is muff and sidestand conversion and welding lessons, see the pics.
We found that the bike had one of those anti pollution LML type muffs, that's it you see on the right. Also a second ratty RH 200 pipe like the one we converted.
I had a nice PM tuning pipe that bolted right on for much better power and musical customer desired racket
But 1) sorry,can't be include free 2) can't change tire with it on, and worst 3) gonna grind on the road when he corners fast
so what about that ratty looking RH pipe in pic #1? It's for a 200, but maybe, if we changed the inlet somehow...
tack welded while on the bike.
Yeah, this could work and the kid learns how to weld too! WCGW?
he picked it up pretty good too!
center stand no good with these muffs, so we did a RH conversion sidestand as well
so now he loves welding as well as old shifty Vespas....
Wed Feb 03, 2021 5:35 pm quote
Wish you were my neighbour Terry. Legend.
86 T5, 71 Sprint, 63 GL
Wed Feb 03, 2021 5:49 pm quote
Nice work Voodoo!
Wed Feb 03, 2021 6:14 pm quote
I wanna come up and park the RV in front of your house for a week or two! Good one on setting your neighbor up! Great story....
Thu Feb 04, 2021 4:54 am quote
Paying it forward again Terry. Youíre a living lesson to us all.
Thu Feb 04, 2021 5:15 am quote
On all levels;
Brilliant! Absolutely BRILLIANT!!
VNB VSC VBC VSX
Thu Feb 04, 2021 6:17 am quote
Right on!
Thu Feb 04, 2021 7:12 am quote
This x100
  DoubleGood Vespa T-Shirts
[ Time: 0.2148s ][ Queries: 27 (0.0738s) ][ Debug on ]
