today i ..... bollox 2.1 |
Post Reply Forum -> Not-So-Modern | Previous123...71727374Next |
Author | Message |
![]() ![]() 76 Sprint V, 63 GL, 62 VBB, 05 Stella
Posts: 3129 Location: Nashville |
![]() ![]() 1979 P150X, 1983 P200E, 1988 T5, 1995 PX200E, 2011 Yamaha Fazer 600 S2
Posts: 2214 Location: Veria, Greece |
![]() swiss1939 wrote: Can you share the link for this? I'm game for a $30 led headlight! https://www.aliexpress.com/item/33006979843.html |
![]() SaFiS wrote: swiss1939 wrote: Can you share the link for this? I'm game for a $30 led headlight! https://www.aliexpress.com/item/33006979843.html |
![]() Quote: These all look great. Anything special needs to be done to mount on a P series w battery? |
![]() ![]() 1963 Vespa VBB, 1965 Allstate Cruisaire, 1974 Vespa Super, 2003 Stella 2T
Posts: 139 Location: Kansas City |
![]() Fatbear5 wrote: Quote: These all look great. Anything special needs to be done to mount on a P series w battery? Option B is to just wire in an AC to DC converter right before the headlight. PK125 XL disc brake and LED headlight conversion |
![]() ![]() 73 & 74 Rally, 76 ET3, 80 P200, 06 PX150, 61 Ser 2, 65 Silver Special, 86 & 96 Elite 80s, 2015 HD Road Glide Special, 2011 Ural Tourist
Posts: 3924 Location: Oceanside, CA |
![]() whodatschrome wrote: Fatbear5 wrote: Quote: These all look great. Anything special needs to be done to mount on a P series w battery? Option B is to just wire in an AC to DC converter right before the headlight. PK125 XL disc brake and LED headlight conversion |
![]() MJRally wrote: whodatschrome wrote: Fatbear5 wrote: Quote: These all look great. Anything special needs to be done to mount on a P series w battery? Option B is to just wire in an AC to DC converter right before the headlight. PK125 XL disc brake and LED headlight conversion |
![]() ![]() 1972 Vespa GTR, 1963 Lambretta LI 125
Posts: 164 Location: Halifax, England |
![]() My neighbor across the alley hooked me up with a motorcycle lift for $20 today. And my missing second roll of flooring finally showed up, so I'll get that down and be able to finish unpacking the new workshop.
And I'm going to take Jim's P200 motor off his hands so I can build a Kill-Myself-Fast motor. All-in-all, not a bad day for this scooterist. ![]() Hey buddy! Need a lift?
Positive
![]() stumbled across this on instagram today. Almost didnt notice the engine(s)
![]() https://www.instagram.com/donganz_redscooter/ [/img] ![]() |
![]() mor_ wrote: stumbled across this on instagram today. Almost didnt notice the engine(s) ![]() https://www.instagram.com/donganz_redscooter/ [/img] I like it ![]() |
![]() chandlerman wrote: My neighbor across the alley hooked me up with a motorcycle lift for $20 today. And my missing second roll of flooring finally showed up, so I'll get that down and be able to finish unpacking the new workshop. And I'm going to take Jim's P200 motor off his hands so I can build a Kill-Myself-Fast motor. All-in-all, not a bad day for this scooterist. Looking good. |
![]() mor_ wrote: stumbled across this on instagram today. Almost didnt notice the engine(s) ![]() https://www.instagram.com/donganz_redscooter/ [/img] |
![]() ![]() 2007 Stella 225
Posts: 1557 Location: Rochester, Minnesota |
![]() CONVERTING TO LED HEADLIGHT
Quote: Option B is to just wire in an AC to DC converter right before the headlight. PK125 XL disc brake and LED headlight conversion Quote: You could also tap into the DC wires at the keyswitch. Tie in a jumper to the left side light switch and you’re good to go. Clean DC right off the battery. Thanks for helping me out with this. |
![]() Fatbear5 wrote: CONVERTING TO LED HEADLIGHT Quote: Option B is to just wire in an AC to DC converter right before the headlight. PK125 XL disc brake and LED headlight conversion Quote: You could also tap into the DC wires at the keyswitch. Tie in a jumper to the left side light switch and you’re good to go. Clean DC right off the battery. Thanks for helping me out with this. I’m not sure at how many watts the DC side of the stator will charge the battery back up and at what rate. A standard P has a 35 watt headlight that has 12VAC going to it. I’m not sure how many watts are coming off the DC side of the stator. Obvious there is plenty of DC to power the brake/tail light and turn signals, but I don’t know how much is left over to power a 12VDC accessory. I was using 40 watt grip heaters on my P2 (wired directly to the battery), and the 9ah battery that I had couldn’t quite keep up. I would think that it would be able to handle a 20ish watt LED headlight with no problem. |
![]() ![]() VSX, Stella 177, VNX1T, V9B1T
Posts: 2901 Location: Staten Island, NY |
![]() A Missouri Survivor in TX (VBC resto ...coming 2022)
I may or may not have grabbed a clean, straight 74 Super for a late 2021 project... ahem ...
(will be on deck well after the SS180 gets done.) ![]()
Positive
![]() ![]() 79 P200E, 62 Allstate, 2008 Stella
Posts: 2072 Location: Florence, OR |
![]() Re: A Missouri Survivor in TX (VBC resto ...coming 2022)
Birdsnest wrote: I may or may not have grabbed a clean, straight 74 Super for a late 2021 project... ahem ... ![]() |
![]() Installed an original Piaggio front shock on my smallie. I put it together with parts from 3 different shocks. Having that "bug" stamp as Voodoo calls it is what's really important here.
Positive
![]() ...started making patterns for a new casting. Exhaust manifold that maintains proper flow for the Imola cylinder.
![]() ![]() '79 P200, '74 VBC Super, '80 100 Sport (sold to new home!)
Posts: 742 Location: 32° 37' 40" N, 117° 2' 53" W |
![]() finally rode with other humans! The P had an engine refresh and shocks in late 2019 and has been in covid lockdown except for quick round-the-blocks. recently sorted a carb gas leak, and rode with scooterfriends for the first time in a long while! Scoot was happily cruising at 55-60 down the strand to Coronado on a fine San Diego day. The shock change from 40-yr old stock ones did wonders for the ride, fer sure.
Cheers peeps and F-Covid. ![]()
Positive
![]() Good on ya.
That's a cool wind screen... hadn't seen that one before. |
![]() ![]() 74 50s x3 78 P200 x2 84 Cosa PK50XL2 58 AllState 68 Sprint 80 50special '66(?) Super125
Posts: 8121 Location: seattle/athens |
![]() Double story here. I finally got rid of my red '62 VNB that nobody seemed interested in and it turned out to be easy. A kid up the street that is into little bitty stand on 2T scooters and pocket bikes, and has a nice Kawasaki 300 Scrambler bike I saw when we met up while I was riding my Vespa.
He was immediately in love with the look and the sound. He followed me home, then saw my herd and I allowed as to how I might not really NEED that old VNB too badly, coz just a 3 speed w/ a tired 150 top end that had 20/20 carb and kickstart lever 'borrowed' over time for more important bikes. So we dug up a dirty old 20/20 cleaned it up and stole a kickstart lever from another motor. ![]() ![]() Second story is muff and sidestand conversion and welding lessons, see the pics. ![]() We found that the bike had one of those anti pollution LML type muffs, that's it you see on the right. Also a second ratty RH 200 pipe like the one we converted. ![]() I had a nice PM tuning pipe that bolted right on for much better power and musical customer desired racket But 1) sorry,can't be include free 2) can't change tire with it on, and worst 3) gonna grind on the road when he corners fast ![]() so what about that ratty looking RH pipe in pic #1? It's for a 200, but maybe, if we changed the inlet somehow... ![]() tack welded while on the bike. Yeah, this could work and the kid learns how to weld too! WCGW? ![]() he picked it up pretty good too! ![]() center stand no good with these muffs, so we did a RH conversion sidestand as well ![]() so now he loves welding as well as old shifty Vespas....
Positive
![]() ![]() 74 Super, 75 Super, PX project, LML off-roader and new to 2018, '66 Blue Badge Smallframe
Posts: 8066 Location: Victoria, Australia |
![]() 86 T5, 71 Sprint, 63 GL
Posts: 659 Location: Oak Brook, Illinois |
![]() I wanna come up and park the RV in front of your house for a week or two! Good one on setting your neighbor up! Great story....
![]() ![]() Bodgerific 150 Super, 50s in progress
Posts: 331 Location: Melbourne, Way Downunder |
![]() ![]() 79p200e 66smallstate 85pk50xl 84p125ets 63GL
Posts: 275 Location: Flatness, TX |
![]() ![]() 63 GL, 76 Super (x 2), 74 Primavera (x 2), 06 Fly 150
Posts: 5757 Location: So Cal |
[ Time: 0.1932s ][ Queries: 27 (0.0639s) ][ Debug on ] |
