Sito+ not fitting on P200E
1977 P200e
nothing at all
what area are you in kev.
where'd you buy it
1977 P200e
nothing at all
hey kev,you are not that far.
the stock pipe is good.
lets keep in touch.
jimmy
Al
nothing at all
nothing at all
1977 P200e
1977 P200e
Ours alike.
Missouri Loves Company Rally   DoubleGood Vespa T-Shirts   Scooter Parts Company
[ Time: 0.2308s ][ Queries: 23 (0.0551s) ][ Debug on ]
