Sito+ not fitting on P200E
1977 P200e
nothing at all
what area are you in kev.
where'd you buy it
1977 P200e
nothing at all
hey kev,you are not that far.
the stock pipe is good.
lets keep in touch.
jimmy
Al
nothing at all
nothing at all
1977 P200e
1977 P200e
Ours alike.
Scooting the Ozarks is a scooter rally held in Eureka Springs, Arkansas offering riders scenic twisty rides, poker run, and more.   DoubleGood Vespa T-Shirts   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.2002s ][ Queries: 25 (0.0356s) ][ Debug on ]
