SteveinSac wrote:
After wrestling around for an hour more, I gave up. I spread the bracket so it cleared the swingarm; however, the holes were still way off. I tried mounting the bracket side first, but I just dont feel comfortable with all that pressure pulling on the exhaust port of the head, Iron or not. When I have some more time and pick up some more new power tools
I'll modify the bracket. For now, it's back to stock, which isn't all that bad.
