Replacing the clock battery GT200
Sun Jan 03, 2010 10:23 am quote
Created article Replacing the clock battery GT200
TB graciously gave permission to add his write up to the Wiki.
I'm still editing it at this point, but I wanted to get started working on it and still run downstairs from time to time to catch the Steelers game.
Sun Jan 03, 2010 11:20 am quote
OK, Done.
I have added the link to it under the DYI heading.
Unfortunately, the link looks out of place reading...
Replacing the Clock Battery GT200
instead of
GT200: Replacing the Clock Battery
which would be more in keeping with the format already established there. My bad. I should have checked first.
In any case, I tried to edit the title and/or the slug to change it with no luck. It wants to revert back. If anyone can fix this or let me know how to fix it myself, It would be appreciated. Thanks.
GTS250 GTS300 MP3 500
Sun Jan 03, 2010 4:47 pm quote
Excellent! Nice work.
That top photo seems eerily familiar...
2004 GT200
Thu Aug 04, 2011 11:21 pm quote
Pics aren't loading
Please help! The links for the pics must be dead or something, as they're not loading. Looking forward to changing the battery to my newly acquired GT200.
Fri Aug 05, 2011 7:03 am quote
Looking into a solution....
2004 GT200
Wed Aug 10, 2011 1:03 am quote
Thanks very much, just getting started with my GT200, really enjoying it so far, hoping start doing some work on it, taking it apart/ getting to know the scooter.
Looks like the battery is pretty deep within the headset. Is it the same procedure as other models like the LX150, etc.?
GTS250 - GT200 - XJR1300
Thu Apr 19, 2012 4:12 pm quote
The pictures seem to have all disappeared again. Is there a chance of reloading them? Or perhaps attaching them to the post? And is this pretty much the same procedure on a GTS250?
Mon May 06, 2013 5:53 am quote
Uploading pictures, courtesy of TB.
Mon May 06, 2013 7:34 am quote
Uploading more pics, these ones cover the removal of the headset.
Mon May 06, 2013 8:02 am quote
Unfortunately, there are still some missing pictures in this narrative. Not sure what to do about that.
2007 GT 200L
Tue May 07, 2013 1:59 am quote
now I know where the battery is
thanks for the heads up on the battery. it would've been nice if they would've put the battery in an easier spot to get to like outside the instrument cluster for easy access.
LX150
Sun Oct 05, 2014 10:03 am quote
External battery / power supply to clock
Getting to the small watch battery in the instrument cluster was a time consuming chore. The second replacement opportunity on my LX150 begged for a more reasonable solution. After the disassembly to access the clock and it's removal from the cluster, I separated the halves of the clock case to expose the circuit board. The wires that I silver soldered to the battery terminals go to a AA battery holder epoxy bonded to the inside of the horn cover on the front of the scooter. This battery will supply power longer and replacement is now a matter of removing the badge and the one screw retaining the cover. If there is another project for the clock, I might add an LED lamp in the cluster to improve night viewing of the clock.
[ Time: 0.1966s ][ Queries: 23 (0.0303s) ][ Debug on ]
