top left is the gt200 airbox, main pic is the gts airbox.
It is exactly the same airbox bar the central pipe.
As far as I can see the u shaped apperture in the 250/300 airbox was designed to have that central pipe in the 200 diagram fit into it. Thats why its the shape it is.
The fact there isnt a central pipe in the 250/300 airbox leads me to think that piaggio in thier wisdom left it out, presumably to allow a larger and smoother airflow into the box for the larger engines.
makes sense to me.
If piaggio had specifically designed the airbox for the 250/300 why cast it with the u shaped apperture? why not cast it with a hole lower and close the u up across the top so the filter is being held even more securely?.
because they used the 200 airbox design, just took the central pipe out and it worked well enough
but with piaggio in thier wisdom leaving out the central pipe in the 250 airbox they themselves have increased the chances of dirty air getting into the engine by having the filter just resting on top of the u shaped cutout, The airbox was not designed to work this way.
The filter in the 200 airbox doesnt have this (admittedly small issue) as it seals against the square end of the central pipe.
If piaggio "designed" the 250 airbox to seal as well as the 200 airbox they would have added a piece to seal the top of the u and added the hole lower.
like this
I think I will add my own bit as above to ensure the filter is 100% sealed as it is on the 200 after all this is the way the airbox was originally designed to work.
This is where I disagree with opening the u aperture at the top as you are significantly increasing the chances of dirty air getting into the engine (sorry Mike, You still take the credit for the mod
