Standard Roller Weights
Sun Apr 11, 2010 8:14 am quote
Created article Standard Roller Weights
Sun Apr 11, 2010 8:56 am quote
I linked this in on the Mantainance Procedures page under see also. not sure where else to link it.
was also playing with resorting the info to group models that use the same roller. That would allow including after market as well. was thinking of sorting it by width, then diameter, then weight.
Sun Apr 11, 2010 12:03 pm quote
That's extremely helpful Patrick, thumbs up. Maintenance procedures seems to be the most logical place to link it from.
GTS250 GTS300 MP3 500
Sun Apr 11, 2010 2:38 pm quote
Do we have a "reference" page? Seems like there are a few pages that could be linked from a central reference page if we had one.
Mon Apr 12, 2010 3:30 am quote
Done, added to the Reference section.
BV500 - GTS250
Mon Apr 12, 2010 10:07 am quote
We should add a column for minimum diameters. On the BV 500 it is 24.5mm
Tue May 11, 2010 7:55 am quote
Re: Standard Roller Weights
Just pulled a set of new stock LX 50 rollers out the bag:- 19x15.5 8g
Perhaps you can add this to your wiki list ?
Tue May 11, 2010 8:16 am quote
Just did. Thanks.
GTV125 & GT60
Location: England, somewhere down in the bottom left bit...
Mon Jun 21, 2010 7:43 am quote
Another one to add - Beedpseed advise standard roller spec for my GTV125 is 19mm x 17mm x 7.4g.
Edited to add... I guess the GTS125 is ditto.
Best,
Mark
Mon Jun 21, 2010 7:44 pm quote
Added, with thanks.
Scooter Pimp
------Piaggio Zip 100------
Sat Sep 13, 2014 4:29 am quote
Added stock roller info for Piaggio 100 4T
GTS 125 2010 - Midnight Blue LB10 VDE - (Stolen)
Fri Oct 28, 2016 2:37 am quote
Best,
Mark
The first time I changed my rollers on my GTS 125 2010 (Bought pre owned) i used the stock weights listed above. What is real funny is since then it revs so much higher then it used to... almost too much and my fuel economy went down by about 10-15% (I didn't pay attention to the ones I removed stupidly). I since replaced them (at the following normal service interval) with 8.5g weights and it felt much more balanced with a lower rpm while cruising at 40-50mph.
Have you had, or heard of any such experiences that stock weights are too light? (I apologise if I sound like a complete idiot, haha I probably am)
Scooter Pimp
Sat Oct 29, 2016 3:44 am quote
Perhaps to do with rider weight/riding style maybe?
Rallies Europe 2016   Vespa Wasp Pin Badges   Yelcome Leather Top Cases and Roll Bags for Piaggio Vespa PX LX LXV GTS GTV
[ Time: 0.3598s ][ Queries: 23 (0.1135s) ][ Debug on ]
