Progetto 300' 2009 GTS 300 SUPER
GTS 300
Wed Jan 02, 2013 6:03 am quote
Finally i took some pictures of my 2009 GTS 300 ongoing project.
I bought this 300 second hand with only 1800 km on the tacho.
So far i did these mods :
Cosmetical :
*13 inch MP3 500 Business wheels powdercoated in satin black with white reflective rim striping
* Debadged
* Leds all round.
* Daylight "running" lights using bottom front indicators : Running lights for the GTS.
* Osram H4 Night breaker headlight
* Smidsy Brake light modulator : Tailmate brake light flasher
* 70 mm "Fake" Oberon mirrors using original bar ends painted black.
* Piaggio Vespa mono gel saddle : New mono gel saddle for the GTS
* Jettin black short visor
* Ram mount for GPS + power cable : Progetto RAM (for LX & GTS)
* Chrome nose grill painted black
* Dashboard painted black
* Black SIP sport lever set
Mechanical :
* Oil temperature gauge
* Malossi springs front & rear
* Optima 4 battery charger connector (lengthened & repositioned to the rear)
* Remus SS exhaust without cat. DB killer shortened for some extra noise.
* Repositioned the attachment of the spring from the side stand so it remains in it's open position.
* Malossi Vario
* Malossi Torque Drive
* Malossi Torsion controller
* Zelioni type III brake discs
* Malossi MHR synt. brake pads
GTS super
Wed Jan 02, 2013 9:14 am quote
where can we find those Oberon mirrors?
Do you have some manual for installing the mirrors on the original bar ends?
Thanks!
Arnout
Wed Jan 02, 2013 9:46 am quote
http://www.oberon-performance.com/acatalog/Oberon_Mirrors.html
Link to there site
Mark
GTS300 Intermission
Wed Jan 02, 2013 3:02 pm quote
Re: Progetto 300' 2009 GTS 300 SUPER
Progetto 300 wrote:
Hi Kristof,
I envy the look of your Scoot. Clean lines and uncluttered.
Verrry nice.
Cosmetical :
* Oberon mirrors using original bar ends.
I have the same but used the bar ends supplied. 75mm dia are best and offer suprisingly good field of vision. Why did you use the original bar ends?
We've discussed in other posting. Now you've had an opportunity to test the seat how comfortable do you find it? and seating position?
btw I like the look of the Pirate Upholstery "Cafe' Racer GTS lowered" I'll have to add to my wish list for now (limited budget)
Nice, could probably stretch to that.
I might have a go at this when I get some spare time. Looks cool.
* Testing the Dr.Pulley myth...
I'm waiting for my 13g's from SIP. I noticed they sell 13.5's but didn't see these on DR. Pulley's own site!
keep us posted on your testing. I'll do the same.
Chris.
GTS 300
Thu Jan 03, 2013 12:14 am quote
Arthriticdigit wrote:
* Oberon mirrors using original bar ends. Why did you use the original bar ends?
Well, my dealer had those laying around ready to use with the Oberons. Holes drilled and tapped. Also the heavier weights. The Oberons are made of alu.
Very comfortable but i've still have to test it for a longer period of driving.
I'll post the result here.
Maybe i'm going to paint that in the body color, that was my original idea.
Painted in body color looks even better.
I'm waiting for 12 gr's. Not shure if i made the correct decision...
Chris.
[/quote]
orange gts 300 SS & white gts 300 S
Thu Jan 03, 2013 12:38 am quote
nice 300 , how is the view in those mirrors ?
GTS 300
Thu Jan 03, 2013 12:46 am quote
Perfect !
Thu Jan 03, 2013 1:29 am quote
Can you get a closer picture to the bar ends.I want to see how the mirrors are fitted.Thanks.
Thu Jan 03, 2013 1:37 am quote
Progetto 300 wrote:
Perfect !
from where are you in BE ?
2010 Scarabeo 300
Thu Jan 24, 2013 12:56 am quote
That's a lovely looking scoot - nice clean lines
GTS 300
Thu Jan 24, 2013 2:44 am quote
Last week, i changed the mirrors for "fake" Oberons :
http://www.scooter-center.com/scoweb/pages/productdetail.grid?product=325565290863232&category1=A&category2=CAT&lang=de
A friend of mine bought these but would not use them.
Here's a picture of the Oberon and "china" mirror set:
The original Oberons i have are silver (aluminum) 60 mm ones with flat mirror.
The fakes are black 70 mm ones with convex mirror. The bar-ends are made of aluminum
The thicker end of the rod fits in to the bar-end in two ways, at the side or at the end of the bar-end and is hold in place using a M10 Allen bolt.
The mirror goes on, on the other side using a M4 Allen bolt.
You have to cut the smaller end of the bar-and because the steering rod is not hollow and the bar-ends will not fit.
I have not used the original aluminum bar-end of the sets but special made iron ones. (using the original bar-ends).
Thu Jan 24, 2013 8:06 am quote
looks nice , are they firm / don't shake ?
T5 Classic 152. PX 187 in bits. 300ie Supersport
Tue Feb 19, 2013 5:32 am quote
Really like that..............
The cosmetic changes are great. Almost like the "plainness" of the scooter makes it looks so good........
GTS 300
Sat Apr 20, 2013 10:49 am quote
Finally got my 13 inchers shod with Conti Twist Sports & 15 mm white reflective striping.
GTS 300
Sun Apr 21, 2013 11:09 am quote
More pictures :
GTS 300 70th Anniversary
Sun Apr 21, 2013 11:18 am quote
The wheels look great.
Does it feel any different when riding it?
GTS 300
Sun Apr 21, 2013 11:28 am quote
At this moment the ride is harder than usual, maybe because the tires are new and in combo with the low profile.
I'm running 2,0 bar front and rear now but also Malossi's around and adjusted.
GTS 125 I.E.
Sun Apr 21, 2013 9:41 pm quote
very nice !! love the new wheels !
Vespa GTV 250 Cc Via monte napoleone
Fri Apr 26, 2013 2:32 am quote
size
im just wondering if this flasher from superBrightleds has the correct size to fit back of the light for VESPA GTV
I DONT SEE ENOUGH SPACE BACK
GTS 300
Fri Apr 26, 2013 3:41 am quote
If i can fit in the the rear light and the rear lights are both the same on GTS & GTV models....
Fri Apr 26, 2013 4:30 pm quote
question
Hi progetto
i can see that you r using the small one the (black)
The back flasher from superBrightLEDS is almost double size
BUT THE PRICE ON SUPERBRIGHTLEDS IS REALLY ATTRACTIVE
IF 300 AND GTV HAVE THE SAME LIGHTS THE ONLY REMAINING IS THE SIZE
GTS 300
Sat Aug 16, 2014 5:15 am quote
Sold my 13" MP3 Yourban wheels to get these 13" MP3 500 Business wheels powdercoated in satin black with white reflective rimstriping. I also fitted Zellioni brake discs & Malossi MHR Synth pads. Tyres are Michelin Power Pure 140-60/13 back, 130-60/13 front.
2013 Vespa 300 GTS Super Titanium
Tue Apr 28, 2015 11:16 pm quote
Ok below in bold red, how did you customize the stock bar ends to fit those mirrors?? I want to do that! I have a good machinist.
Cosmetical :
* Debadged
* Leds all round.
Mechanical :
* Malossi Vario
GTS 300
Tue Apr 28, 2015 11:29 pm quote
[quote="elsizzle2000"]Ok below in bold red, how did you customize the stock bar ends to fit those mirrors?? I want to do that! I have a good machinist.
Well, i did not, my dealer did this for me using the original heavy weights and as template the original Oberon mirrors is had from my LX.
Tue Apr 28, 2015 11:32 pm quote
Ah ok. Thanks for the inspiration! I'm going to do exactly this. I been on the hunt for clean and sleek bar ends and sat the Oberon (or fakes) but kne they were aluminum so would lighten the bars and may alter handling. With this "mod" I keep my stock weighted bar ends WITH functional and leek mirrors!
[quote="Progetto 300"]
Sat May 02, 2015 11:02 pm quote
How do I get ahold of your dealer? Can he sell me a set?
GTS 300
Sat May 02, 2015 11:43 pm quote
I'll ask him today.
Mon May 04, 2015 11:15 am quote
Thanks!
Progetto 300 wrote:
I'll ask him today.
GTS 300
Wed May 06, 2015 11:49 pm quote
elsizzle2000 wrote:
Thanks!
Progetto 300 wrote:
I'll ask him today.
Just got mail from him.
Unfortunately, he refuses to send the items to Amerika.
Vespa et4 125 special
Fri May 08, 2015 12:56 pm quote
Hi looks verry good
I tuned my et 125 with lot of update
125cc to malossi 140cc
Shockers yss
Sprint 12 inch wheels
Sprint dash spoiler
Sprint 125 logo,S
Sprint carier
Exhaust GPR
Malossi air filter
Malossi vario
Malossi springs and clutch
Malossi belt
Old model sprint claxon shield
Indicators front Clear prepare self led daylight with turn light
Next update lot of exvlusive cnc parts
Gascap
Mirrors
Stearing lock
Wheelcap
Stabilizer
Sun May 10, 2015 7:13 pm quote
Hmmmm how bout I pay YOU to buy a set from him and YOU can ship to AMerica?
Progetto 300 wrote:
elsizzle2000 wrote:
Thanks!
Progetto 300 wrote:
I'll ask him today.
Sun May 10, 2015 10:00 pm quote
Hi check our site we have exclusive Vespa parts like mirrors etc
We can sent worldwide
Www.styleforfashion.nl
Thu Jun 18, 2015 11:09 pm quote
Kris, do you have a picture of your vespa taken from the back?
Is the center of the rear wheel alligned with the center of the scooter?
GTS 300
Thu Jun 18, 2015 11:43 pm quote
No picture of that but the raar wheel sits perfectly center with the center with the scooter.
My dealer machined both wheels to fit perfect.
Thu Jun 18, 2015 11:50 pm quote
Clear! How many mm did he take off?
GTS 300
Thu Jun 18, 2015 11:54 pm quote
I think around 2 mm but i'm not shure...
At the raar there's the problem that the cone will not fit inside the center hole.
He machined the rim to fit but i think it's easier to machine the cone.
Fri Jun 19, 2015 4:19 am quote
clear thanks.
P.S. Saw you in Mantova last year!
GTS 300
Fri Mar 25, 2016 12:35 am quote
[/quote]P.S. Saw you in Mantova last year![/quote]
...and maybe this year in St. Tropez ?
GTS 300
Wed Sep 02, 2020 12:31 am quote
RIP
So far for this project....
Got rear ended on the scooter.
Frame is bend...
Missouri Loves Company Rally   Vespa Wasp Pin Badges   Cool Ass scooter seat cover
[ Time: 0.3417s ][ Queries: 25 (0.0827s) ][ Debug on ]
