Plug Tool for installing side reflector plugs
Thu May 24, 2007 8:37 am quote
Make your own plug installation tool and this job go's really fast.
After spending 15 min. making this tool it took me less that 5 min to install 8 pre-painted side reflector plugs
Pick a dowl about twice the size of the plug.
The dowl needs to be at least 6" long. 10" would be better
Drill a little domed hole on the end of the dole. So your not going very deep just enough to match the dome of the plug.
Take the dowl out to the street and scrap it on the sidewalk until the extra material around your little drilled dome is removed. Or sand it if you have a fancy shop. Hell whittle it down if you live in the South...
Now take the plug that you painted the day before and center it on your plug tool. Evenly press the plug into place. Use your fingers as a guide.
Special thanks to SF Vespa for the touch up paint. I will donate this amazing tool called the "Lucky Plugger" to T-Bone at SF Vespa.
The wood of the dowl with the even pressure will not hurt your paint!
Slow and steady and you will have a plug installed in less than 30 sec.
Greasy says to put a little Glue on the inside to keep them in place. I was only able to get to get glue to 4 plugs. I put the glue on after installation if they don't hold next time i will put a little glue on the plugs then wipe off the extra right away.
Hope this helps some of you MV'ers out their.
Sorry the pictures are in reverse order.
Moderatore Dedicato
GTS250 Gilera Runner SP180
Thu May 24, 2007 11:57 pm quote
glad that we don't have to bother about this process over here.
But if we did,I'd take comfort in the fact that I have the same "bastard shoes" as Lucky....
2x '06 GT200 ~ '78 P200 ~ '73 Vespa 90
Fri May 25, 2007 2:21 pm quote
Alternate plug tool:
2007 Scarabeo 500ie
Fri May 25, 2007 9:39 pm quote
I'm going to be putting in some plugs on the front fender, after installing a chrome fender guard. Are they really that hard to get in that you need some kind of tool to do it? Or will the "alternate tool", my bare hands and fingers, suffice? Don't want to break a nail or anything!
Fri May 25, 2007 10:03 pm quote
R
GTS250 GTS300 MP3 500
Fri May 25, 2007 11:05 pm quote
Yeah, me too.
Sat May 26, 2007 9:30 am quote
No worries on the nails - you just might need to ream the holes a wee bit larger. Check this thread out:
http://www.modernvespa.com/forum/topic8859.html
Sun May 27, 2007 10:38 am quote
the obvious choice if tool.
the dowel is cool though.
2007 Scarabeo 500ie
Sun May 27, 2007 5:56 pm quote
Those holes left from the reflectors must come in different sizes. I got the plugs in with no problem at all, with just a gentle push. And no, I didn't break any nails!
Sun May 27, 2007 6:46 pm quote
Great!
...um... pictures, please!!!
Mon May 28, 2007 1:47 pm quote
Lucky's plug tool
Once you use Lucky's Plug tool you won't want to use your own fingers again....
2006 Vespa LX150
Wed May 30, 2007 11:01 pm quote
I used my fingers, but a Lucky tool would probably have been a lot easier. Maybe you should patent it.
Team Scooter Trash for Petfinder Foundation   Vespa Wasp Pin Badges   Scooter Parts Company
[ Time: 0.1698s ][ Queries: 25 (0.0301s) ][ Debug on ]
